REST API reference
Retrieve UNIX user information for a user and SVM
Retrieves UNIX user information for a specific user and SVM to access their configuration details.
HTTP method and endpoint
GET /name-services/unix-users/{svm.uuid}/{name}
Introduced in
ONTAP 9.9
Usage notes
Retrieves UNIX user information for the specified user and SVM.
  • vserver services name-service unix-user show
name
string
path
True
UNIX user name
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
full_name
string
User's full name.
id
integer
UNIX user ID of the specified user.
name
string
UNIX user name to be added to the local database.
primary_gid
integer
Primary group ID to which the user belongs.
svm
svm
      "href": "/api/resourcelink"
  "full_name": "Full User Name for user1",
  "name": "user1",
  "skip_name_validation": true,
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
