REST API reference
Retrieve broadcast domain details
Accesses broadcast domain details to view configuration specifics and operational settings.
HTTP method and endpoint
GET /network/ethernet/broadcast-domains/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves details of a broadcast domain.
  • network port broadcast-domain show
uuid
string
path
True
Broadcast domain UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
mtu
integer
Maximum transmission unit, largest packet size on this network
name
string
Name of the broadcast domain, scoped to its IPspace
ports
array[ports]
Ports that belong to the broadcast domain
uuid
string
      "href": "/api/resourcelink"
  "ipspace": {
    "name": "Default",
  "mtu": 1500,
  "name": "bd1",
  "ports": [
      "name": "e1b",
      "node": {
        "name": "node1"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
node
name
string
Name of node on which the port is located.
ports
Port UUID along with readable names
_links
_links
name
string
node
node
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
