Retrieve an FPolicy configuration for an SVM
GET /protocols/fpolicy/{svm.uuid}/policies/{name}
Introduced In: 9.6
Retrieves a particular FPolicy policy configuration for a specified SVM. Cluster-level FPolicy policy configuration details cannot be retrieved for a data SVM.
Related ONTAP commands
fpolicy policy show -
fpolicy policy scope show -
fpolicy show
Learn more
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
allow_privileged_access |
boolean |
Specifies whether privileged access is required for FPolicy servers. Privileged access is used when the FPolicy server requires direct access to the cluster nodes. When this parameter is set to true, FPolicy servers can access files on the cluster using a separate data channel with privileged access. |
enabled |
boolean |
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled. |
engine |
FPolicy external engine |
events |
array[fpolicy_event_reference] |
mandatory |
boolean |
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances. |
name |
string |
Specifies the name of the policy. |
passthrough_read |
boolean |
Specifies whether passthrough-read should be allowed for FPolicy servers registered for the policy. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. Offline files are files that have been moved to secondary storage. |
persistent_store |
string |
Specifies the persistent storage name. This can then be used to enable persistent mode for FPolicy events. |
priority |
integer |
Specifies the priority that is assigned to this policy. |
privileged_user |
string |
Specifies the privileged user name for accessing files on the cluster using a separate data channel with privileged access. The input for this field should be in "domain\username" format. |
scope |
svm |
"engine": {
"href": "/api/resourcelink"
"name": "string"
"events": [
"event_cifs",
"event_open"
"name": "fp_policy_1",
"persistent_store": "ps1",
"priority": 1,
"privileged_user": "mydomain\\testuser",
"scope": {
"exclude_export_policies": [
"string"
"exclude_extension": [
"string"
"exclude_shares": [
"string"
"exclude_volumes": [
"vol1",
"vol_svm1",
"include_export_policies": [
"string"
"include_extension": [
"string"
"include_shares": [
"sh1",
"share_cifs"
"include_volumes": [
"vol1",
"vol_svm1"
"svm": {
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
fpolicy_engine_reference
_links |
name |
string |
The name of the FPolicy external engine. |
FPolicy events
_links |
name |
string |
scope
check_extensions_on_directories |
boolean |
Specifies whether the file name extension checks also apply to directory objects. If this parameter is set to true, the directory objects are subjected to the same extension checks as regular files. If this parameter is set to false, the directory names are not matched for extensions and notifications are sent for directories even if their name extensions do not match. Default is false. |
exclude_export_policies |
array[string] |
exclude_extension |
array[string] |
exclude_shares |
array[string] |
exclude_volumes |
array[string] |
include_export_policies |
array[string] |
include_extension |
array[string] |
include_shares |
array[string] |
include_volumes |
array[string] |
object_monitoring_with_no_extension |
boolean |
Specifies whether the extension checks also apply to objects with no extension. If this parameter is set to true, all objects with or without extensions are monitored. Default is false. |
svm
uuid |
string |
SVM UUID |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
