Retrieve a Kerberos realm
Retrieves information about a Kerberos realm, which is essential for configuring secure communications in your network environment.
HTTP method and endpoint
GET /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a Kerberos realm.
vserver nfs kerberos realm show
Learn more
svm.uuid |
string |
path |
True |
SVM UUID |
name |
string |
path |
True |
Kerberos realm |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
ad_server |
admin_server |
clock_skew |
integer |
Specifies the allowed time of clock-skew between the server and clients, in minutes. |
comment |
string |
Comment |
encryption_types |
array[string] |
kdc |
name |
string |
Kerberos realm |
password_server |
svm |
"href": "/api/resourcelink"
"ad_server": {
"address": "1.2.3.4",
"name": "string"
"admin_server": {
"comment": "string",
"encryption_types": [
"string"
"kdc": {
"ip": "1.2.3.4",
"port": 88,
"vendor": "string"
"name": "string",
"password_server": {
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ad_server
address |
string |
Active Directory server IP address |
name |
string |
Active Directory server name |
admin_server
address |
string |
Admin server IP address. |
port |
integer |
Specifies the port number of admin server. |
kdc
ip |
string |
KDC IP address |
port |
integer |
KDC port |
vendor |
string |
Key Distribution Center (KDC) vendor. Following values are suported:
password_server
address |
string |
Password server IP address. |
port |
integer |
Specifies the port number of password server. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
