REST API reference
Retrieve NVMe services
Retrieves NVMe services to access the current configurations and operations available for NVMe protocols. Use this information to review or manage NVMe services in your environment.
HTTP method and endpoint
GET /protocols/nvme/services
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • statistics.*
  • metric.*
  • vserver nvme show
enabled
boolean
query
False
Filter by enabled
metric.latency.other
integer
query
False
Filter by metric.latency.other
  • Introduced in: 9.7
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.latency.write
integer
query
False
Filter by metric.latency.write
metric.status
string
query
False
Filter by metric.status
metric.duration
string
query
False
Filter by metric.duration
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.write
integer
query
False
Filter by metric.iops.write
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.fc.duration
string
query
False
Filter by metric.fc.duration
  • Introduced in: 9.10
metric.fc.status
string
query
False
Filter by metric.fc.status
metric.fc.timestamp
string
query
False
Filter by metric.fc.timestamp
metric.fc.latency.other
integer
query
False
Filter by metric.fc.latency.other
metric.fc.latency.read
integer
query
False
Filter by metric.fc.latency.read
metric.fc.latency.total
integer
query
False
Filter by metric.fc.latency.total
metric.fc.latency.write
integer
query
False
Filter by metric.fc.latency.write
metric.fc.throughput.total
integer
query
False
Filter by metric.fc.throughput.total
metric.fc.throughput.read
integer
query
False
Filter by metric.fc.throughput.read
metric.fc.throughput.write
integer
query
False
Filter by metric.fc.throughput.write
metric.fc.iops.other
integer
query
False
Filter by metric.fc.iops.other
metric.fc.iops.read
integer
query
False
Filter by metric.fc.iops.read
metric.fc.iops.total
integer
query
False
Filter by metric.fc.iops.total
metric.fc.iops.write
integer
query
False
Filter by metric.fc.iops.write
metric.tcp.duration
string
query
False
Filter by metric.tcp.duration
metric.tcp.status
string
query
False
Filter by metric.tcp.status
metric.tcp.timestamp
string
query
False
Filter by metric.tcp.timestamp
metric.tcp.latency.other
integer
query
False
Filter by metric.tcp.latency.other
metric.tcp.latency.read
integer
query
False
Filter by metric.tcp.latency.read
metric.tcp.latency.total
integer
query
False
Filter by metric.tcp.latency.total
metric.tcp.latency.write
integer
query
False
Filter by metric.tcp.latency.write
metric.tcp.throughput.total
integer
query
False
Filter by metric.tcp.throughput.total
metric.tcp.throughput.read
integer
query
False
Filter by metric.tcp.throughput.read
metric.tcp.throughput.write
integer
query
False
Filter by metric.tcp.throughput.write
metric.tcp.iops.other
integer
query
False
Filter by metric.tcp.iops.other
metric.tcp.iops.read
integer
query
False
Filter by metric.tcp.iops.read
metric.tcp.iops.total
integer
query
False
Filter by metric.tcp.iops.total
metric.tcp.iops.write
integer
query
False
Filter by metric.tcp.iops.write
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.status
string
query
False
Filter by statistics.status
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.tcp.iops_raw.other
integer
query
False
Filter by statistics.tcp.iops_raw.other
statistics.tcp.iops_raw.read
integer
query
False
Filter by statistics.tcp.iops_raw.read
statistics.tcp.iops_raw.total
integer
query
False
Filter by statistics.tcp.iops_raw.total
statistics.tcp.iops_raw.write
integer
query
False
Filter by statistics.tcp.iops_raw.write
statistics.tcp.latency_raw.other
integer
query
False
Filter by statistics.tcp.latency_raw.other
statistics.tcp.latency_raw.read
integer
query
False
Filter by statistics.tcp.latency_raw.read
statistics.tcp.latency_raw.total
integer
query
False
Filter by statistics.tcp.latency_raw.total
statistics.tcp.latency_raw.write
integer
query
False
Filter by statistics.tcp.latency_raw.write
statistics.tcp.throughput_raw.total
integer
query
False
Filter by statistics.tcp.throughput_raw.total
statistics.tcp.throughput_raw.read
integer
query
False
Filter by statistics.tcp.throughput_raw.read
statistics.tcp.throughput_raw.write
integer
query
False
Filter by statistics.tcp.throughput_raw.write
statistics.tcp.timestamp
string
query
False
Filter by statistics.tcp.timestamp
statistics.tcp.status
string
query
False
Filter by statistics.tcp.status
statistics.fc.iops_raw.other
integer
query
False
Filter by statistics.fc.iops_raw.other
statistics.fc.iops_raw.read
integer
query
False
Filter by statistics.fc.iops_raw.read
statistics.fc.iops_raw.total
integer
query
False
Filter by statistics.fc.iops_raw.total
statistics.fc.iops_raw.write
integer
query
False
Filter by statistics.fc.iops_raw.write
statistics.fc.latency_raw.other
integer
query
False
Filter by statistics.fc.latency_raw.other
statistics.fc.latency_raw.read
integer
query
False
Filter by statistics.fc.latency_raw.read
statistics.fc.latency_raw.total
integer
query
False
Filter by statistics.fc.latency_raw.total
statistics.fc.latency_raw.write
integer
query
False
Filter by statistics.fc.latency_raw.write
statistics.fc.throughput_raw.total
integer
query
False
Filter by statistics.fc.throughput_raw.total
statistics.fc.throughput_raw.read
integer
query
False
Filter by statistics.fc.throughput_raw.read
statistics.fc.throughput_raw.write
integer
query
False
Filter by statistics.fc.throughput_raw.write
statistics.fc.timestamp
string
query
False
Filter by statistics.fc.timestamp
statistics.fc.status
string
query
False
Filter by statistics.fc.status
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[nvme_service]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "metric": {
        "duration": "PT15S",
        "fc": {
          "iops": {
            "read": 200,
            "total": 1000,
            "write": 100
          "latency": {
            "read": 200,
            "total": 1000,
            "write": 100
          "status": "ok",
          "throughput": {
            "read": 200,
            "total": 1000,
            "write": 100
          "timestamp": "2017-01-25 06:20:13 -0500"
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "tcp": {
          "iops": {
            "read": 200,
            "total": 1000,
            "write": 100
          "latency": {
            "read": 200,
            "total": 1000,
            "write": 100
          "status": "ok",
          "throughput": {
            "read": 200,
            "total": 1000,
            "write": 100
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
      "statistics": {
        "fc": {
          "iops_raw": {
            "read": 200,
            "total": 1000,
            "write": 100
          "latency_raw": {
            "read": 200,
            "total": 1000,
            "write": 100
          "status": "ok",
          "throughput_raw": {
            "read": 200,
            "total": 1000,
            "write": 100
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "tcp": {
          "iops_raw": {
            "read": 200,
            "total": 1000,
            "write": 100
          "latency_raw": {
            "read": 200,
            "total": 1000,
            "write": 100
          "status": "ok",
          "throughput_raw": {
            "read": 200,
            "total": 1000,
            "write": 100
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
fc
The NVMe/FC portion of the aggregated metrics.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
tcp
The NVMe/TCP portion of the aggregated metrics.
_links
_links
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
_links
_links
duration
string
fc
fc
iops
iops
latency
latency
status
string
tcp
tcp
throughput
throughput
timestamp
string
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
fc
The NVMe/FC portion of the aggregated statistics.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
tcp
The NVMe/TCP portion of the aggregated statistics.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
fc
fc
iops_raw
iops_raw
latency_raw
latency_raw
status
string
tcp
tcp
throughput_raw
throughput_raw
timestamp
string
svm
_links
_links
name
string
uuid
string
nvme_service
A Non-Volatile Memory Express (NVMe) service defines the properties of the NVMe controller target for an SVM. There can be at most one NVMe service for an SVM. An SVM's NVMe service must be created before NVMe host initiators can connect to the SVM.
An NVMe service is identified by the UUID of its SVM.
_links
_links
enabled
boolean
The administrative state of the NVMe service. The NVMe service can be disabled to block all NVMe connectivity to the SVM.
This is optional in POST and PATCH. The default setting is true (enabled) in POST.
metric
metric
statistics
statistics
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
