Retrieve historical performance metrics for the FC protocol service of an SVM
Retrieves historical performance metrics for the FC protocol service of a storage virtual machine (SVM). This helps you analyze past performance trends and optimize your network configurations.
HTTP method and endpoint
GET /protocols/san/fcp/services/{svm.uuid}/metrics
Introduced in
ONTAP 9.7
Usage notes
Retrieves historical performance metrics for the FC Protocol service of an SVM.
timestamp |
string |
query |
False |
Filter by timestamp |
throughput.total |
integer |
query |
False |
Filter by throughput.total |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
iops.other |
integer |
query |
False |
Filter by iops.other |
iops.read |
integer |
query |
False |
Filter by iops.read |
iops.total |
integer |
query |
False |
Filter by iops.total |
iops.write |
integer |
query |
False |
Filter by iops.write |
duration |
string |
query |
False |
Filter by duration |
status |
string |
query |
False |
Filter by status |
latency.other |
integer |
query |
False |
Filter by latency.other |
latency.read |
integer |
query |
False |
Filter by latency.read |
latency.total |
integer |
query |
False |
Filter by latency.total |
latency.write |
integer |
query |
False |
Filter by latency.write |
svm.uuid |
string |
path |
True |
interval |
string |
query |
False |
The time range for the data. Examples can be 1h, 1d, 1m, 1w, 1y. The period for each time range is as follows:
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"svm": {
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 06:20:13 -0500"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8585947 |
No metrics are available for the requested object. |
8586225 |
An unexpected error occurred retrieving metrics for the requested object. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
svm
uuid |
string |
throughput
read |
integer |
total |
integer |
write |
integer |
records
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
svm |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
