Retrieve a Duo profile configured for an SVM or cluster
GET /security/authentication/duo/profiles/{owner.uuid}
Introduced In: 9.14
Retrieves the Duo profile configured for the cluster or an SVM.
Related ONTAP commands
security login duo show
owner.uuid |
string |
path |
True |
Account owner UUID. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
api_host |
string |
The URL at which the Duo API is hosted. |
auto_push |
boolean |
Automatically sends a push notification for authentication when using Duo. |
comment |
string |
Comment for the Duo profile. |
fail_mode |
string |
Determines the behavior of the system when it cannot communicate with the Duo service. |
fingerprint |
string |
The SHA fingerprint corresponding to the Duo secret key. |
http_proxy |
string |
Specifies the HTTP proxy server to be used when connecting to the Duo service. |
integration_key |
string |
The Integration Key associated with the Duo profile. |
is_enabled |
boolean |
Indicates whether the Duo authentication feature is active or inactive. |
max_prompts |
integer |
The maximum number of authentication attempts allowed for a user before the process is terminated. |
owner |
SVM name and UUID for which the Duo profile is configured. |
push_info |
boolean |
Additional information sent along with the push notification for Duo authentication. |
status |
string |
Information on the reachability status of Duo. |
"next": {
"href": "/api/resourcelink"
"api_host": "api-****.duo.com",
"auto_push": 1,
"comment": "string",
"fail_mode": "safe",
"fingerprint": "string",
"http_proxy": "IPaddress:port",
"integration_key": "string",
"is_enabled": 1,
"max_prompts": 1,
"owner": {
"name": "svm1",
"push_info": 1,
"status": "OK"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
owner
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
