REST API reference
Retrieve configured Duo profiles
Retrieves the configured Duo profiles to review the current authentication settings. This helps ensure that your security setup aligns with your organizational policies.
HTTP method and endpoint
GET /security/authentication/duo/profiles
Introduced in
ONTAP 9.14
  • security login duo show
http_proxy
string
query
False
Filter by http_proxy
api_host
string
query
False
Filter by api_host
max_prompts
integer
query
False
Filter by max_prompts
  • Max value: 3
  • Min value: 1
owner.name
string
query
False
Filter by owner.name
owner.uuid
string
query
False
Filter by owner.uuid
push_info
boolean
query
False
Filter by push_info
auto_push
boolean
query
False
Filter by auto_push
fail_mode
string
query
False
Filter by fail_mode
status
string
query
False
Filter by status
integration_key
string
query
False
Filter by integration_key
fingerprint
string
query
False
Filter by fingerprint
is_enabled
boolean
query
False
Filter by is_enabled
comment
string
query
False
Filter by comment
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[duo]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
        "next": {
      "api_host": "api-****.duo.com",
      "auto_push": 1,
      "comment": "string",
      "fail_mode": "safe",
      "fingerprint": "string",
      "http_proxy": "IPaddress:port",
      "integration_key": "string",
      "is_enabled": 1,
      "max_prompts": 1,
      "owner": {
        "name": "svm1",
      "push_info": 1,
      "status": "OK"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
SVM name and UUID for which the Duo profile is configured.
_links
_links
name
string
uuid
string
duo
Duo profile for the SVM or cluster-management server (Cserver).
_links
_links
api_host
string
The URL at which the Duo API is hosted.
auto_push
boolean
Automatically sends a push notification for authentication when using Duo.
comment
string
Comment for the Duo profile.
fail_mode
string
Determines the behavior of the system when it cannot communicate with the Duo service.
fingerprint
string
The SHA fingerprint corresponding to the Duo secret key.
http_proxy
string
Specifies the HTTP proxy server to be used when connecting to the Duo service.
integration_key
string
The Integration Key associated with the Duo profile.
is_enabled
boolean
Indicates whether the Duo authentication feature is active or inactive.
max_prompts
integer
The maximum number of authentication attempts allowed for a user before the process is terminated.
owner
owner
push_info
boolean
Additional information sent along with the push notification for Duo authentication.
status
string
Information on the reachability status of Duo.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
