REST API reference
Retrieve quota policy rules for all FlexVol and FlexGroup volumes
Retrieves the quota policy rules configured for all FlexVol and FlexGroup volumes. This helps you understand the storage usage limits and ensure compliance with your storage policies.
HTTP method and endpoint
GET /storage/quota/rules
Introduced in
ONTAP 9.6
Usage notes
Retrieves quota policy rules configured for all FlexVol volumes and FlexGroup volumes.
  • quota policy rule show
qtree.id
integer
query
False
Filter by qtree.id
qtree.name
string
query
False
Filter by qtree.name
user_mapping
boolean
query
False
Filter by user_mapping
group.name
string
query
False
Filter by group.name
group.id
string
query
False
Filter by group.id
space.hard_limit
integer
query
False
Filter by space.hard_limit
space.soft_limit
integer
query
False
Filter by space.soft_limit
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
users.name
string
query
False
Filter by users.name
users.id
string
query
False
Filter by users.id
type
string
query
False
Filter by type
uuid
string
query
False
Filter by uuid
volume.uuid
string
query
False
Filter by volume.uuid
volume.name
string
query
False
Filter by volume.name
files.hard_limit
integer
query
False
Filter by files.hard_limit
files.soft_limit
integer
query
False
Filter by files.soft_limit
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[quota_rule]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "group": {
        "id": "string",
        "name": "string"
      "qtree": {
        "id": 1,
        "name": "qt1"
      "svm": {
        "name": "svm1",
      "type": "string",
      "users": [
          "id": "string",
          "name": "string"
      "uuid": "5f1d13a7-f401-11e8-ac1a-005056a7c3b9",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
files
hard_limit
integer
This parameter specifies the hard limit for files. This is valid in POST or PATCH.
soft_limit
integer
This parameter specifies the soft limit for files. This is valid in POST or PATCH.
group
This parameter specifies the target group to which the group quota policy rule applies. This parameter takes a group name or identifier. This parameter is only valid for the POST operation of a group quota policy rule. The POST operation will fail with an appropriate error if this parameter is used as an input to create a user or a tree quota policy rule. This input parameter for POST takes either a group name or a group identifier, but not both. For default quota rules, the group name must be chosen and should be specified as "". For explicit group quota rules, this parameter can contain a UNIX group name or a UNIX group identifier.
id
string
Quota target group ID
name
string
Quota target group name
qtree
This parameter specifies the target qtree to which the user/group/tree quota policy rule applies. For a user/group quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST. For a user/group quota policy rule at volume level, this parameter is not valid in GET or POST. For a tree quota policy rule, this parameter is mandatory and is valid in both POST and GET. For a default tree quota policy rule, this parameter needs to be specified as "". For a tree quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST.
_links
_links
id
integer
The unique identifier for a qtree.
name
string
The name of the qtree.
space
hard_limit
integer
This parameter specifies the space hard limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit.
soft_limit
integer
This parameter specifies the space soft limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit.
svm
_links
_links
name
string
uuid
string
users
id
string
Quota target user ID
name
string
Quota target user name
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
quota_rule
_links
_links
files
files
group
group
qtree
qtree
space
space
svm
svm
type
string
This parameter specifies the quota policy rule type. This is required in POST only and can take either one of the "user", "group" or "tree" values.
user_mapping
boolean
This parameter enables user mapping for user quota policy rules. This is valid in POST or PATCH for user quota policy rules only.
users
array[users]
This parameter specifies the target user to which the user quota policy rule applies. This parameter takes single or multiple user names or identifiers. This parameter is valid only for the POST operation of a user quota policy rule. If this parameter is used as an input to create a group or a tree quota policy rule, the POST operation will fail with an appropriate error. For POST, this input parameter takes either a user name or a user identifier, not both. For default quota rules, the user name must be chosen and specified as "". For explicit user quota rules, this parameter can indicate either a user name or user identifier. The user name can be a UNIX user name or a Windows user name. If a name contains a space, enclose the entire value in quotes. A UNIX user name cannot include a backslash () or an @ sign; user names with these characters are treated as Windows names. The user identifer can be a UNIX user identifier or a Windows security identifier. For multi-user quota, this parameter can contain multiple user targets separated by a comma.
uuid
string
Unique identifier for the quota policy rule. This field is generated when the quota policy rule is created.
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
