REST API reference
Retrieve EMS role-based configurations
Accesses EMS role-based configurations to view the available settings for managing roles in your environment.
HTTP method and endpoint
GET /support/ems/role-configs
Introduced in
ONTAP 9.13
Usage notes
Retrieves a collection of the EMS role-based configurations.
  • event role-config show
event_filter.name
string
query
False
Filter by event_filter.name
limit_access_to_global_configs
boolean
query
False
Filter by limit_access_to_global_configs
access_control_role.name
string
query
False
Filter by access_control_role.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "access_control_role": {
        "name": "admin"
      "event_filter": {
        "name": "important-events"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
access_control_role
Access control role that the event filter is assigned to.
_links
_links
name
string
Role name
event_filter
Event filter that is assigned to the access control role.
_links
_links
name
string
records
_links
_links
access_control_role
access_control_role
event_filter
event_filter
boolean
Indicates whether the access control has limited access to global EMS configurations.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
