REST API reference
Manage application Snapshot copies
Manage application Snapshot copies across storage elements to ensure data protection and consistency. Create and restore Snapshot copies at any time or as part of a schedule, with options for application or crash consistency. For accurate coordination with host applications, consider using the SnapCenter Backup Management suite.
Overview
Applications support Snapshot copies across all member storage elements. These Snapshot copies can be created and restored at any time or as scheduled. Most applications have hourly Snapshot copies enabled by default, unless the RPO setting is overridden during the creation of the application. An application Snapshot copy can be flagged as either application consistent, or crash consistent. From an ONTAP perspective, there is no difference between these two consistency types. These types are available for record keeping so that Snapshot copies taken after the application is quiesced (application consistent) can be tracked separately from those Snapshot copies taken without first quiescing the application (crash consistent). By default, all application Snapshot copies are flagged to be crash consistent, and Snapshot copies taken at a scheduled time are also considered crash consistent.
The functionality provided by these APIs is not integrated with the host application. Snapshot copies have limited value without host coordination, so the use of the SnapCenter Backup Management suite is recommended to ensure correct interaction between host applications and ONTAP.
