Manage Azure Key Vaults
Utilize Azure Key Vault endpoints to securely manage and store encryption keys for your ONTAP environment. These endpoints help you set up and maintain configurations between ONTAP and Azure Key Vault, ensuring secure communication and access to keys necessary for encryption processes.
Overview
Azure Key Vault (AKV) is a cloud key management service (KMS) that provides a secure store for secrets. This feature allows ONTAP to securely store its encryption keys using AKV. In order to use AKV with ONTAP, you must first deploy an Azure application with the appropriate access to an AKV and then provide ONTAP with the necessary details, such as key vault name, application ID so that ONTAP can communicate with the deployed Azure application. The properties "state", "azure_reachability" and "ekmip_reachability" are considered advanced properties and are populated only when explicitly requested.
Enabling an AKV configuration for an SVM using the certificate authentication method
The example AKV configuration is enabled for a specific SVM. Note the return_records=true query parameter is used to obtain the newly created key-manager keystore configuration.
# The API:
POST /api/security/azure-key-vaults
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/azure-key-vaults?return_records=true' -H 'accept: application/hal+json' -d "{ \"svm\": { \"uuid\": \"4f7abf4c-9a07-11ea-8d52-005056bbeba5\" }, \"client_id\": \"client1\", \"tenant_id\": \"tenant1\", \"name\": \"https:://mykeyvault.azure.vault.net/\", \"key_id\": \"https://keyvault-test.vault.azure.net/keys/key1/a8e619fd8f234db3b0b95c59540e2a74\", \"client_certificate\" : \"<CERTIFICATE-CONTENT>\" }"
# The response:
"num_records": 1,
"records": [
"uuid": "024cd3cf-9a08-11ea-8d52-005056bbeba5",
"svm": {
"uuid": "4f7abf4c-9a07-11ea-8d52-005056bbeba5",
"name": "vs0"
"client_id": "client1",
"tenant_id": "tenant1",
"name": "https:://mykeyvault.azure.vault.net/",
"key_id": "https://keyvault-test.vault.azure.net/keys/key1/a8e619fd8f234db3b0b95c59540e2a74",
"href": "/api/security/azure-key-vaults/024cd3cf-9a08-11ea-8d52-005056bbeba5"
Creating an inactive AKV configuration for an SVM using the client secret authentication method
The example AKV configuration is created for a specific SVM but is not enabled. Note the create_inactive=true paramater that is used to indicate that the configuration should be created but not enabled. Note the return_records=true query parameter is used to obtain the newly created key-manager keystore configuration.
# The API:
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/azure-key-vaults?create_inactive=true&return_records=true' -H 'accept: application/hal+json' -d "{ \"svm\": { \"uuid\": \"4f7abf4c-9a07-11ea-8d52-005056bbeba5\" }, \"configuration\": {\"name\": \"myConfiguration\"}, \"client_id\": \"client1\", \"tenant_id\": \"tenant1\", \"name\": \"https:://mykeyvault.azure.vault.net/\", \"key_id\": \"https://keyvault-test.vault.azure.net/keys/key1/a8e619fd8f234db3b0b95c59540e2a74\", \"client_secret\" : \"myclientPwd\" }"
# The response:
"num_records": 1,
"records": [
"uuid": "85619643-9a06-11ea-8d52-005056bbeba5",
"configuration": {"name": "myConfiguration"},
"href": "/api/security/azure-key-vaults/85619643-9a06-11ea-8d52-005056bbeba5"
Retrieving the AKVs configured for all clusters and SVMs
The following example shows how to retrieve all configured AKVs along with their configurations.
# The API:
GET /api/security/azure-key-vaults
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/azure-key-vaults?fields=*'
# The response:
"records": [
"configuration": {
"name" : "default"
"scope": "svm",
"svm": {
"name": "vs0"
"authentication_method": "client_secret",
"enabled": true,
"configuration": {
"name" : "new-config"
"scope": "cluster",
"authentication_method": "certificate",
"enabled": false,
"num_records": 2,
"href": "/api/security/azure-key-vaults?fields=*"
Retrieving a specific AKV configuration
The following example retrieves a specific AKV configuration.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/azure-key-vaults/85619643-9a06-11ea-8d52-005056bbeba5?fields=*'
# The response:
"configuration": {
"name" : "default"
"scope": "cluster",
"enabled": true,
Retrieving the advanced properties of a specific, enabled AKV configuration
The following example retrieves the advanced properties of a specific enabled AKV configuration (inactive AKV configurations do not have these advanced properties).
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/azure-key-vaults/85619643-9a06-11ea-8d52-005056bbeba5?fields=state,azure_reachability,ekmip_reachability"'
"configuration": {
"name" : "default"
"name": "https://10.234.237.18",
"state": {
"cluster_state": true,
"message": "",
"code": "0"
"azure_reachability": {
"reachable": true,
"message": "",
"code": "0"
"ekmip_reachability": [
"node": {
"uuid": "d208115f-7721-11eb-bf83-005056bb150e",
"name": "node1",
"href": "/api/cluster/nodes/d208115f-7721-11eb-bf83-005056bb150e"
"reachable": true,
"message": "",
"code": "0"
"node": {
"uuid": "e208115f-7721-11eb-bf83-005056bb150e",
"name": "node2",
"href": "/api/cluster/nodes/e208115f-7721-11eb-bf83-005056bb150e"
"reachable": true,
"message": "",
"code": "0"
Updating the client secret of a specific AKV configuration
The following example updates the client secret of a specific AKV configuration.
# The API:
PATCH /api/security/azure-key-vaults
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/azure-key-vaults/85619643-9a06-11ea-8d52-005056bbeba5' -d "{ \"client_secret\": \"<NEW-SECRET>\" }"
Updating the client certificate and key of a specific AKV configuration
The following example updates the client certificate and key of a configured AKV for a specific AKV configuration.
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/azure-key-vaults/85619643-9a06-11ea-8d52-005056bbeba5' -d "{ \"client_certificate\": \"<CERTIFICATE-CONTENT>\" }"
Deleting a specific AKV configuration
The following example deletes a specific, enabled AKV.
# The API: DELETE /api/security/azure-key-vaults # The call: curl -X DELETE 'https://<mgmt-ip>/api/security/azure-key-vaults/85619643-9a06-11ea-8d52-005056bbeba5'
Restoring the keys for a specific AKV configuration
The following example restores all the keys of a specific AKV configuration.
# The API:
POST security/azure-key-vaults/{uuid}/restore
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/azure-key-vaults/85619643-9a06-11ea-8d52-005056bbeba5/restore'
# The response:
"job": {
"uuid": "6ab6946f-9a0c-11ea-8d52-005056bbeba5",
"href": "/api/cluster/jobs/6ab6946f-9a0c-11ea-8d52-005056bbeba5"
Rekeying the internal key for a specific AKV configuration
The following example rekeys the internal key of a specific AKV configuration.
# The API:
POST security/azure-key-vaults/{uuid}/rekey-internal
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/azure-key-vaults/85619643-9a06-11ea-8d52-005056bbeba5/rekey-internal'
# The response:
"job": {
