Manage Snapshot copy policies
Use the Snapshot copy policy APIs to manage policies that automate the creation and retention of Snapshot copies. These endpoints help you define schedules and retention periods for your Snapshot copies, ensuring efficient data protection and storage management.
Overview
In ONTAP, scheduled Snapshot copy creation works based on Snapshot copy policies. ONTAP provides three cluster-wide Snapshot copy policies: "default", "default-1weekly" and "none". A Snapshot copy policy can have more than one schedule associated with it. A Snapshot copy policy can be linked to a storage object and based on the schedule in the policy, Snapshot copies will be created on the object at that interval. Each schedule in a Snapshot copy policy has a Snapshot copy name prefix attached to it. Every Snapshot copy created using this policy will have this prefix in its name. There is also a retention count associated with every schedule. This count indicates the maximum number of Snapshot copies that can exist for a given schedule. Once the Snapshot copy count reaches the retention count, on the next create operation, the oldest Snapshot copy is deleted. A retention period can be associated with every schedule. During Snapshot copy creation, this period is set as SnapLock expiry time on Snapshot copy locking enabled volumes.
The following APIs are used to perform operations related to Snapshot copy policy information:
– POST /api/storage/snapshot-policies
– GET /api/storage/snapshot-policies
– GET /api/storage/snapshot-policies/{uuid}
– PATCH /api/storage/snapshot-policies/{uuid}
– DELETE /api/storage/snapshot-policies/{uuid}
Creating a Snapshot copy policy
The POST operation is used to create a Snapshot copy policy with the specified attributes.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/snapshot-policies" -H "accept: application/hal+json" -d '{"name": "new_policy", "enabled": "true", "comment": "policy comment", "copies": [{ "schedule": { "name": "5min" }, "count": "5", "prefix": "xyz" , "retention_period": "PT20M" }], "svm": { "name": "vs0"}}'
# The response:
HTTP/1.1 201 Created
Date: Tue, 12 Mar 2019 21:20:24 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/storage/snapshot-policies/a69d8173-450c-11e9-aa44-005056bbc848
Content-Length: 369
Content-Type: application/json
"num_records": 1,
"records": [
"uuid": "a69d8173-450c-11e9-aa44-005056bbc848",
"svm": {
"name": "vs0"
"comment": "This is a 5min schedule policy",
"enabled": true,
"copies": [
"count": 5,
"snapmirror_label": "-",
"retention_period": "PT20M",
"schedule": {
"name": "5min"
Retrieving Snapshot copy policy attributes
The GET operation is used to retrieve Snapshot copy policy attributes.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/snapshot-policies/" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Tue, 12 Mar 2019 21:17:17 GMT
Content-Length: 686
"records": [
"uuid": "0fa7a554-348d-11e9-b55e-005056bbf1c8",
"name": "spsv0",
"href": "/api/storage/snapshot-policies/0fa7a554-348d-11e9-b55e-005056bbf1c8"
"uuid": "3c112527-2fe8-11e9-b55e-005056bbf1c8",
"name": "default",
"href": "/api/storage/snapshot-policies/3c112527-2fe8-11e9-b55e-005056bbf1c8"
"uuid": "3c1c1656-2fe8-11e9-b55e-005056bbf1c8",
"name": "default-1weekly",
"href": "/api/storage/snapshot-policies/3c1c1656-2fe8-11e9-b55e-005056bbf1c8"
"uuid": "3c228b82-2fe8-11e9-b55e-005056bbf1c8",
"name": "none",
"href": "/api/storage/snapshot-policies/3c228b82-2fe8-11e9-b55e-005056bbf1c8"
"num_records": 4,
"href": "/api/storage/snapshot-policies/"
Retrieving the attributes of a specific Snapshot copy policy
The GET operation is used to retrieve the attributes of a specific Snapshot copy policy.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/snapshot-policies/3c112527-2fe8-11e9-b55e-005056bbf1c8" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Tue, 12 Mar 2019 21:24:48 GMT
Content-Length: 381
"name": "default",
"comment": "Default policy with hourly, daily & weekly schedules.",
"enabled": true,
"scope": "cluster",
"copies": [
"count": 6,
"prefix": "hourly",
"schedule": {
"name": "hourly"
"count": 2,
"prefix": "daily",
"schedule": {
"name": "daily"
"count": 2,
"prefix": "weekly",
"schedule": {
"name": "weekly"
Updating a Snapshot copy policy
The PATCH operation is used to update the specific attributes of a Snapshot copy policy.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/snapshot-policies/ae9e65c4-4506-11e9-aa44-005056bbc848" -d '{"enabled": "false" }' -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Tue, 12 Mar 2019 21:27:04 GMT
Content-Length: 3
Deleting a Snapshot copy policy
The DELETE operation is used to delete a Snapshot copy policy.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/snapshot-policies/ae9e65c4-4506-11e9-aa44-005056bbc848" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Tue, 12 Mar 2019 21:19:04 GMT
Content-Length: 3
