Manage storage file clones
Use these endpoints to create and manage file clones within a volume efficiently, minimizing additional space usage. Retrieve split status, manage split loads, and update clone token validity to maintain space reservation for cloning operations.
Overview
You can use these API's to create file clones, retrieve split status and manage split loads. These endpoints are used for cloning files within a volume, without taking much of extra space. Child and parent clones shares the unchanged blocks of data.
A file clone split operation detach child clone from its parent. Split operations use space. To ensure that file clone create operation is not affected by split, file clone tokens are use to reserve space. API endpoints can be used to update the validity and space reserved by token.
File clone APIs
The following APIs are used to perform the following operations:
– POST /api/storage/file/clone
– GET /api/storage/file/clone/split-status
– PATCH /api/storage/file/clone/split-loads/{node.uuid}
– GET /api/storage/file/clone/split-loads/{node.uuid}
– GET /api/storage/file/clone/tokens/
– DELETE /api/storage/file/clone/tokens/{node.uuid}/{token.uuid}
– PATCH /api/storage/file/clone/tokens/{node.uuid}/{token.uuid}
