Manage SVMs
Manage SVMs to control volumes, protocols, and services within your cluster. Cluster administrators handle creation, modification, and deletion of SVMs, while SVM administrators manage resources based on assigned capabilities.
Managing SVMs
Cluster administrators can manage any SVM bound to the cluster. In addition, SVMs can also be managed by their SVM administrators. The SVM administrator manages the SVM resources, such as volumes, protocols and services, depending on the capabilities assigned by the cluster administrator. SVM administrators cannot create, modify, or delete SVMs. The cluster administrator manages SVM create, modify, or delete operations.
While configuring CIFS, you must also configure IP interfaces and DNS. No other protocol configuration is allowed when configuring NVMe. NFS, FCP, CIFS and iSCSI protocols can be configured together.
SVM administrators might have all or some of the following administration capabilities:
Data access protocol configuration Configures data access protocols, such as NFS, CIFS, iSCSI, and Fibre Channel (FC) protocol (Fibre Channel over Ethernet included).
Services configuration Configures services such as LDAP, NIS, and DNS.
Monitoring SVM Monitors jobs, network connections, network interfaces, and SVM health.
Updating the TLS certificate for this SVM.
