Manage UNIX group users
Manage UNIX group users by retrieving, adding, or deleting UNIX user accounts associated with an SVM's UNIX group. Use these endpoints to maintain user access controls and group memberships within your system.
Overview
You can use this API to retrieve, add or delete UNIX users for an SVM's UNIX group.
Retrieving UNIX users from an SVM's UNIX group
The UNIX group users GET endpoint retrieves UNIX users of the specified UNIX group and the SVM.
Retrieving all users from the group 'pcuser'
# The API:
/api/name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/unix-groups/f06686a2-c901-11eb-94b4-0050568e9f2c/pcuser/users" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "f06686a2-c901-11eb-94b4-0050568e9f2c",
"name": "svm1"
"unix_group": {
"name": "pcuser"
"name": "user1",
"href": "/api/name-services/unix-groups/f06686a2-c901-11eb-94b4-0050568e9f2c/pcuser/users/user1"
"num_records": 1,
"href": "/api/name-services/unix-groups/f06686a2-c901-11eb-94b4-0050568e9f2c/pcuser/users/?fields=*"
Retrieving user 'user1' from the group 'pcuser'
# The API:
/api/name-services/unix-groups/{svm.uuid}/{unix_group.name}/users/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/unix-groups/f06686a2-c901-11eb-94b4-0050568e9f2c/pcuser/users/user1" -H "accept: application/hal+json"
# The response:
"svm": {
"name": "svm1"
"unix_group": {
"name": "pcuser"
"name": "user1",
Adding users to a UNIX group
The UNIX group users POST endpoint adds UNIX users to the specified UNIX group and the SVM. Multiple users can be added in a single call using the "records" parameter.
Adding a single user to the group 'group1'
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/unix-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/group1/users" -H "accept: application/hal+json" -H "Content-Type: application/json" -d '{ "name": "user4" }'
Adding multiple users to the group 'group1' in a single REST call
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/unix-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/group1/users" -H "accept: application/hal+json" -H "Content-Type: application/json" -d '{ "records": [{"name":"user1"}, {"name":"user2"}, {"name":"user3"}]}'
Deleting a user from a group of a specific SVM
Example
Delete the user 'user1' from group 'group1' in SVM 'vs1'
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/name-services/unix-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/group1/users/user1" -H "accept: application/hal+json"
