Manage Vscan scanner-pool configuration
Configure scanner-pools to define which Vscan servers and privileged users can connect to SVMs, and manage their roles to determine activation status. Utilize these endpoints to set up scanner-pools on local clusters or across clusters in a multi-cluster configuration or disaster recovery setup.
Overview
A scanner-pool defines the Vscan servers and privileged users that can connect to SVMs and a scanner policy or role determines whether a scanner-pool is active. You can configure a scanner-pool to be used on the local cluster or any other cluster in an MCC/DR setup.
Retrieving all fields for all scanner-pools of an SVM
# The API:
/api/protocols/vscan/{svm.uuid}/scanner-pools
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/<svm-uuid>/scanner-pools?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "0e2f7c91-f227-11e8-9601-0050568ecc06"
"name": "scanner-1",
"servers": [
"1.1.1.1",
"10.72.204.27"
"privileged_users": [
"cifs\\u1",
"cifs\\u2"
"role": "primary"
"svm": {
"name": "scanner-2",
"servers": [
"1.1.1.1",
"10.72.204.27"
"cifs\\u1",
"cifs\\u2"
"role": "secondary"
"num_records": 2
Retrieving all scanner-pools with role set as secondary
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/<svm-uuid>/scanner-pools?role=secondary&fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "0e2f7c91-f227-11e8-9601-0050568ecc06",
"name": "vs1"
"servers": [
"1.1.1.1",
"10.72.204.27"
"cifs\\u1",
"cifs\\u2"
"role": "secondary",
"cluster": {
"uuid": "0933f9b5-f226-11e8-9601-0050568ecc06",
"name": "Cluster3"
"num_records": 1
Retrieving the specified scanner-pool associated with an SVM
# The API:
/api/protocols/vscan/{svm.uuid}/scanner-pools/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/0e2f7c91-f227-11e8-9601-0050568ecc06/scanner-pools/scanner-1?fields=*" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1"
"servers": [
"1.1.1.1",
"10.72.204.27"
"cifs\\u1",
"cifs\\u2"
"role": "primary",
"cluster": {
"name": "Cluster3"
Creating a scanner-pool for an SVM with all fields specified
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan/b103be27-17b8-11e9-b451-0050568ecd85/scanner-pools?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"cluster\": { \"name\": \"Cluster1\", \"uuid\": \"ab746d77-17b7-11e9-b450-0050568ecd85\" }, \"name\": \"test-scanner\", \"privileged_users\": [ \"cifs\\\\u1\", \"cifs\\\\u2\" ], \"role\": \"primary\", \"servers\": [ \"1.1.1.1\", \"10.72.204.27\" ]}"
# The response:
"num_records": 1,
"records": [
"name": "test-scanner",
"servers": [
"1.1.1.1",
"10.72.204.27"
"cifs\\u1",
"cifs\\u2"
"role": "primary",
"cluster": {
"uuid": "ab746d77-17b7-11e9-b450-0050568ecd85",
"name": "Cluster1"
Creating a scanner-pool for an SVM with an unspecified role and cluster
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan/b103be27-17b8-11e9-b451-0050568ecd85/scanner-pools" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"name\": \"test-scanner-1\", \"privileged_users\": [ \"cifs\\\\u1\", \"cifs\\\\u2\" ], \"servers\": [ \"1.1.1.1\", \"10.72.204.27\" ]}"
# The response:
"num_records": 1,
"records": [
"name": "test-scanner-1",
"servers": [
"1.1.1.1",
"10.72.204.27"
"cifs\\u1",
"cifs\\u2"
Updating a scanner-pool for an SVM with all of the fields specified
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/vscan/0e2f7c91-f227-11e8-9601-0050568ecc06/scanner-pools/test-scanner-1" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"cluster\": { \"name\": \"Cluster3\", \"uuid\": \"0933f9b5-f226-11e8-9601-0050568ecc06\" }, \"privileged_users\": [ \"cifs\\\\u1\", \"cifs\\\\u2\" ], \"role\": \"secondary\", \"servers\": [ \"1.1.1.1\", \"10.72.204.27\" ]}"
Updating the "role" of a scanner-pool for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/vscan/0e2f7c91-f227-11e8-9601-0050568ecc06/scanner-pools/test-scanner-1" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"cluster\": { \"name\": \"Cluster3\", \"uuid\": \"0933f9b5-f226-11e8-9601-0050568ecc06\" }, \"role\": \"primary\"}"
Deleting a scanner-pool for a specified SVM
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/vscan/0e2f7c91-f227-11e8-9601-0050568ecc06/scanner-pools/test-scanner-1" -H "accept: application/json"
