REST API reference
Update privileges for a local, or Active Directory user or group and SVM
Updates the privileges for a specified local or Active Directory user or group and SVM. Use this endpoint to modify access permissions by replacing existing privileges with new ones.
HTTP method and endpoint
PATCH /protocols/cifs/users-and-groups/privileges/{svm.uuid}/{name}
Introduced in
ONTAP 9.10
Usage notes
Updates privileges of the specified local or Active Directory user or group and SVM.
Important note
  • Specified privileges will replace all the existing privileges associated with the user or group.
  • To reset privileges associated with the user or group, specify the privileges list as empty.
  • vserver cifs users-and-groups privilege reset-privilege
name
string
path
True
Local or Active Directory user or group name.
svm.uuid
string
path
True
Request Body
Name Type Description
privileges
array[string]
An array of privileges associated with the local or Active Directory user or group. The available values are:
  • SeTcbPrivilege - Allows user to act as part of the operating system
  • SeBackupPrivilege - Allows user to back up files and directories, overriding any ACLs
  • SeRestorePrivilege - Allows user to restore files and directories, overriding any ACLs
  • SeTakeOwnershipPrivilege - Allows user to take ownership of files or other objects
  • SeSecurityPrivilege - Allows user to manage auditing and viewing/dumping/clearing the security log
  • SeChangeNotifyPrivilege - Allows user to bypass traverse checking
svm
svm
Example request
  "privileges": [
    "string"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655673
Failed to resolve the user or group.
655730
The specified local user to which privileges are to be associated to does not exist.
string
svm
name
string
uuid
string
user_group_privileges
privileges
array[string]
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
