Update administrative audit settings for GET requests
Updates the administrative audit settings related to GET requests to adjust how those requests are tracked and logged.
HTTP method and endpoint
PATCH /security/audit
Introduced in
ONTAP 9.6
Usage notes
Updates administrative audit settings for GET requests. All of the fields are optional. An empty body will make no changes.
Request Body
| Name | Type | Description |
cli |
boolean |
Enable auditing of CLI GET Operations. Valid in PATCH |
http |
boolean |
Enable auditing of HTTP GET Operations. Valid in PATCH |
ontapi |
boolean |
Enable auditing of ONTAP API GET operations. Valid in PATCH
Status: 200, Ok
cli |
boolean |
http |
boolean |
ontapi |
boolean |
Status: Default, Error
href |
string |
_links
security_audit
cli |
boolean |
http |
boolean |
ontapi |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
