REST API reference
Write to an existing file with the supplied data
Updates the contents of an existing file, allowing modifications to its size, name, space reservation, QoS policy, or hole range information. Use this endpoint to adjust file properties as needed for your storage management tasks.
HTTP method and endpoint
PATCH /storage/volumes/{volume.uuid}/files/{path}
Introduced in
ONTAP 9.8
Usage notes
Writes to an existing file with the supplied data or modifies the size, name, space reservation information, QoS policy, or hole range information of a file. Query-based PATCH operations are not supported.
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Relative path of a file in the volume. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided.
byte_offset
integer
query
False
How many bytes into the file to begin writing. Use -1 to append (default).
stream_name
string
query
False
Name of stream associated with the file to write data to.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
accessed_time
string
Last access time of the file in date-time format.
analytics
analytics
Additional file system analytics information summarizing all descendents of a directory.
This property is only populated if file system analytics is enabled on the containing volume.
In the context of the records property of a file_info_response , analytics objects will only include properties that may vary between elements within the collection. For example, the analytics objects will not contain histogram labels, since the same histogram labels are used for all elements within the collection. The invariant information is instead available via the analytics property of the file_info_response . This avoids an excessive amount of duplicated information when a GET /storage/volumes/{volume.uuid}/files/{path} call returns a large collection.
bytes_used
integer
The actual number of bytes used on disk by this file. If byte_offset and length parameters are specified, this will return the bytes used by the file within the given range.
changed_time
string
Last time data or attributes changed on the file in date-time format.
constituent
constituent
creation_time
string
Creation time of the file in date-time format.
fill_enabled
boolean
Returns "true" if the space reservation is enabled. The field overwrite_enabled must also be set to the same value as this field.
group_id
integer
The integer ID of the group of the file owner.
hard_links_count
integer
The number of hard links to the file.
inode_generation
integer
Inode generation number.
inode_number
integer
The file inode number.
is_empty
boolean
Specifies whether or not a directory is empty. A directory is considered empty if it only contains entries for "." and "..". This element is present if the file is a directory. In some special error cases, such as when the volume goes offline or when the directory is moved while retrieving this info, this field might not get set.
is_junction
boolean
Returns "true" if the directory is a junction.
is_snapshot
boolean
Returns "true" if the directory is a Snapshot copy.
is_vm_aligned
boolean
Returns true if the file is vm-aligned. A vm-aligned file is a file that is initially padded with zero-filled data so that its actual data starts at an offset other than zero. The amount by which the start offset is adjusted depends on the vm-align setting of the hosting volume.
modified_time
string
Last data modification time of the file in date-time format.
name
string
Name of the file.
overwrite_enabled
boolean
Returns "true" if the space reservation for overwrites is enabled. The field fill_enabled must also be set to the same value as this field.
owner_id
integer
The integer ID of the file owner.
path
string
Path of the file.
qos_policy
qos_policy
The QoS policy for the file. Both traditional and adaptive QoS policies are supported. If both qos_policy.uuid and qos_policy.name properties are specified in the same request, they must refer to the same QoS policy. To remove the file from a QoS policy, set the property qos_policy.name in a PATCH request to an empty string "" or "none".
Note Files which are in use as a LUN cannot be assigned to a QoS policy, instead use PATCH on /storage/luns to assign a QoS policy for such files.
Note that a QoS policy can be set on a file, or a file's volume, but not on both.
size
integer
The size of the file, in bytes.
target
string
The relative or absolute path contained in a symlink, in the form /.
unique_bytes
integer
Number of bytes uniquely held by this file. If byte_offset and length parameters are specified, this will return bytes uniquely held by the file within the given range.
unix_permissions
integer
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write), and 1 (execute). The first digit selects the set user ID(4), set group ID (2), and sticky (1) attributes. The second digit selects permissions for the owner of the file; the third selects permissions for other users in the same group; the fourth selects permissions for other users not in the group.
volume
volume
Example request
  "accessed_time": "2019-06-12 11:00:16 -0400",
  "analytics": {
    "by_accessed_time": {
      "bytes_used": {
        "labels": [
          "2019-07",
          "2019-06",
          "2019-05",
          "2019",
          "2018",
          "--2017",
          "unknown"
        "newest_label": "2019-07",
        "oldest_label": "2019-07",
        "percentages": [
          0.1,
          11.24,
          0.18,
          15.75,
          0.75,
          83.5,
          0
        "values": [
          15925248,
          1735569408,
          27672576,
          2430595072,
          116105216,
          12889948160,
          0
    "by_modified_time": {
      "bytes_used": {
        "labels": [
          "2019-07",
          "2019-06",
          "2019-05",
          "2019",
          "2018",
          "--2017",
          "unknown"
        "percentages": [
          0.1,
          11.24,
          0.18,
          15.75,
          0.75,
          83.5,
          0
        "values": [
          15925248,
          1735569408,
          27672576,
          2430595072,
          116105216,
          12889948160,
          0
    "bytes_used": 15436648448,
    "file_count": 21134,
    "subdir_count": 35
  "bytes_used": 4096,
  "changed_time": "2019-06-12 11:00:16 -0400",
  "constituent": {
    "name": "fg__0001",
  "creation_time": "2019-06-12 11:00:16 -0400",
  "group_id": 30,
  "hard_links_count": 1,
  "inode_generation": 214753547,
  "inode_number": 1695,
  "is_empty": "",
  "is_junction": "",
  "is_snapshot": "",
  "is_vm_aligned": "",
  "modified_time": "2019-06-12 11:00:16 -0400",
  "name": "test_file",
  "owner_id": 54738,
  "path": "d1/d2/d3",
  "qos_policy": {
    "name": "qos1",
  "size": 200,
  "target": "some_directory/some_other_directory/some_file",
  "unique_bytes": 4096,
  "unix_permissions": 493,
  "volume": {
    "name": "volume1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
918235
A volume with UUID {volume.uuid} was not found.
6488081
The {field} field is not supported for PATCH operations.
6488082
Failed to rename {path}.
6488083
Failed to rename {path} to {path} because a directory named {path} already exists.
6488111
The fields 'fill_enabled' and 'overwrite_enabled' are not supported in the directory modify operation.
6488117
Permission denied.
6488119
Operation not supported.
string
bytes_used
Number of bytes used on-disk, broken down by date of last access.
labels
array[string]
Labels for this histogram
newest_label
string
Each label indicates the period of time the corresponding data is associated with. A label can take one of the following forms:<ul> a partial date in an extended ISO8601 representation an interval between partial dates in an extended ISO8601 representation, where "--" is used to separate the beginning and end of the interval the string literal "unknown"
</ul>For partial dates and partial date intervals where components of a date are unspecified, the label allows for any valid normalized values the unspecified components might take. For example, the label "2017" allows for any time within the year 2017. Essentially, this is the fully specified interval 2017-01-01T00:00:00—​2017-12-31T23:59:59. Similarly, the interval "2018-05—​2018-07" allows for any time within the months of May, June, and July in 2018, corresponding to the fully specified interval 2018-05-01T00:00:00—​2018-07-31T23:59:59.
The following extensions to ISO8601 are used:<ul> Quarters may be specified. The form yyyy-Qq is used to represent the qth quarter of the year yyyy. Q1 consists of the months January, February, and March; Q2 consists of April, May, and June; Q3 consists of July, August, and September; Q4 consists of October, November, and December. For example, the label "2019-Q2" represents the second quarter of the year 2019, which corresponds to the interval 2019-04-01T00:00:00—​2019-06-30T23:59:59. Either the beginning or end of an interval may be omitted. When the beginning is omitted, the interval includes points in time arbitrarily far in the past. When the end is omitted, the interval includes points in time through the end of the current week.
</ul>The "unknown" label tracks data that could not be associated with any other time period. This usually occurs when the data was at some point associated with a time in the future.
oldest_label
string
percentages
array[number]
Percentages for this histogram
values
array[integer]
Values for this histogram
by_accessed_time
File system analytics information, broken down by date of last access.
bytes_used
bytes_used
bytes_used
Number of bytes used on-disk, broken down by date of last modification.
labels
array[string]
newest_label
string
oldest_label
string
percentages
array[number]
values
array[integer]
by_modified_time
File system analytics information, broken down by date of last modification.
bytes_used
bytes_used
analytics
by_accessed_time
by_accessed_time
by_modified_time
by_modified_time
bytes_used
integer
file_count
integer
Number of descendants
incomplete_data
boolean
Returns true if data collection is incomplete for this directory tree.
subdir_count
integer
Number of sub directories
constituent
name
string
FlexGroup volume constituent name.
uuid
string
FlexGroup volume constituent UUID.
qos_policy
name
string
The name of the QoS policy. To remove the file from a QoS policy, set this property to an empty string "" or set it to "none" in a PATCH request.
uuid
string
The unique identifier of the QoS policy. Valid in PATCH.
volume
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
file_info
Information about a single file.
accessed_time
string
analytics
analytics
bytes_used
integer
changed_time
string
constituent
constituent
creation_time
string
fill_enabled
boolean
group_id
integer
hard_links_count
integer
inode_generation
integer
inode_number
integer
is_empty
boolean
is_junction
boolean
is_snapshot
boolean
is_vm_aligned
boolean
modified_time
string
name
string
Name of the file.
overwrite_enabled
boolean
owner_id
integer
path
string
Path of the file.
qos_policy
qos_policy
size
integer
target
string
unique_bytes
integer
unix_permissions
integer
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
