REST API reference
Create a consistency group
Creates a consistency group that can include new SAN volumes or existing SAN, NVMe, or NAS FlexVol volumes. This operation is useful when you need to manage multiple volumes as a single unit within a storage virtual machine (SVM).
HTTP method and endpoint
POST /application/consistency-groups
Introduced in
ONTAP 9.10
Usage notes
Creates a consistency group with one or more consistency groups having:
  • new SAN volumes,
  • existing SAN, NVMe or NAS FlexVol volumes in a new or existing consistency group
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the group.
  • volumes, luns or namespaces
Naming Conventions
Consistency groups
  • name or consistency_groups[].name, if specified
  • derived from volumes[0].name, if only one volume is specified, same as volume name
Volume
  • volumes[].name, if specified
  • derived from volume prefix in luns[].name
  • derived from cg[].name, suffixed by "_#" where "#" is a system generated unique number
  • suffixed by "_#" where "#" is a system generated unique number, if provisioning_options.count is provided
LUN
  • luns[].name, if specified
  • derived from volumes[].name, suffixed by "_#" where "#" is a system generated unique number
NVMe Namespace
  • namespaces[].name, if specified
There are no ONTAP commands for managing consistency group.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
application
application
clone
clone
Creates a clone of an existing consistency group from the current contents or an existing Snapshot copy.
consistency_groups
array[consistency_groups]
A consistency group is a mutually exclusive aggregation of volumes or other consistency groups. A consistency group can only be associated with one direct parent consistency group.
luns
array[luns]
The LUNs array can be used to create or modify LUNs in a consistency group on a new or existing volume that is a member of the consistency group. LUNs are considered members of a consistency group if they are located on a volume that is a member of the consistency group.
name
string
Name of the consistency group. The consistency group name must be unique within an SVM.
If not provided and the consistency group contains only one volume, the name will be generated based on the volume name. If the consistency group contains more than one volume, the name is required.
namespaces
array[namespaces]
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the SVM using the NVMe over Fabrics protocol. In ONTAP, an NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
An NVMe namespace is created to a specified size using thin or thick provisioning as determined by the volume on which it is created. NVMe namespaces support being cloned. An NVMe namespace cannot be renamed, resized, or moved to a different volume. NVMe namespaces do not support the assignment of a QoS policy for performance management, but a QoS policy can be assigned to the volume containing the namespace. See the NVMe namespace object model to learn more about each of the properties supported by the NVMe namespace REST API.
An NVMe namespace must be mapped to an NVMe subsystem to grant access to the subsystem's hosts. Hosts can then access the NVMe namespace and perform I/O using the NVMe over Fabrics protocol.
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
  • Introduced in: 9.10
parent_consistency_group
The parent consistency group.
Options that are applied to the operation.
qos
qos
replicated
boolean
Indicates whether or not replication has been enabled on this consistency group.
replication_relationships
array[replication_relationships]
Indicates the SnapMirror relationship of this consistency group.
replication_source
boolean
Since support for this field is to be removed in the next release, use replication_relationships.is_source instead.
restore_to
restore_to
Use to restore a consistency group to a previous Snapshot copy
snapshot_policy
snapshot_policy_reference
This is a reference to the Snapshot copy policy.
svm
svm
The Storage Virtual Machine (SVM) in which the consistency group is located.
tiering
tiering
The tiering placement and policy definitions for volumes in this consistency group.
uuid
string
The unique identifier of the consistency group. The UUID is generated by ONTAP when the consistency group is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
  • x-nullable: true
volumes
array[volumes]
A consistency group is a mutually exclusive aggregation of volumes or other consistency groups. A volume can only be associated with one direct parent consistency group.
The volumes array can be used to create new volumes in the consistency group, add existing volumes to the consistency group, or modify existing volumes that are already members of the consistency group.
The total number of volumes across all child consistency groups contained in a consistency group is constrained by the same limit.
Example request
  "_tags": [
    "team:csi",
    "environment:test"
  "application": {
    "component_type": "string",
    "type": "string"
  "clone": {
    "guarantee": {
      "type": "string"
    "parent_consistency_group": {
      "name": "my_consistency_group",
    "parent_snapshot": {
      "name": "this_snapshot",
    "parent_svm": {
      "name": "svm1",
    "split_complete_percent": 0,
    "split_estimate": 0,
    "volume": {
      "prefix": "string",
      "suffix": "string"
  "consistency_groups": [
      "_tags": [
        "team:csi",
        "environment:test"
      "application": {
        "type": "string"
      "luns": [
          "clone": {
            "source": {
              "name": "/vol/volume1/lun1",
          "comment": "string",
          "create_time": "2018-06-04 15:00:00 -0400",
          "lun_maps": [
              "igroup": {
                "igroups": [
                    "name": "igroup1",
                "initiators": [
                    "comment": "my comment",
                    "name": "iqn.1998-01.com.corp.iscsi:name1"
                "name": "igroup1",
                "os_type": "string",
                "protocol": "string",
          "provisioning_options": {
            "action": "string"
          "qos": {
            "policy": {
              "max_throughput_iops": 10000,
              "max_throughput_mbps": 500,
              "min_throughput_iops": 2000,
              "min_throughput_mbps": 500,
              "name": "performance",
          "serial_number": "string",
          "space": {
            "size": 1073741824,
            "used": 0
      "name": "string",
      "namespaces": [
          "name": "/vol/volume1/qtree1/namespace1",
            "action": "string"
          "space": {
            "block_size": 512,
            "size": 1073741824,
            "used": 0
          "subsystem_map": {
            "anagrpid": "00103050h",
            "nsid": "00000001h",
            "subsystem": {
              "hosts": [
                  "dh_hmac_chap": {
                    "controller_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
                    "group_size": "string",
                    "hash_function": "string",
                    "host_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:"
                  "nqn": "nqn.1992-01.example.com:string",
                  "priority": "string"
              "name": "subsystem1",
        "action": "string",
        "name": "string",
        "storage_service": {
          "name": "string"
      "qos": {
        "policy": {
      "restore_to": {
        "snapshot": {
          "name": "string",
          "uuid": "string"
      "snapshot_policy": {
        "name": "default",
      "svm": {
        "name": "svm1",
      "tiering": {
        "control": "string",
        "object_stores": [
            "name": "string"
        "policy": "string"
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "volumes": [
          "name": "vol_cs_dept",
          "nas": {
            "cifs": {
              "shares": [
                  "acls": [
                      "permission": "string",
                      "type": "string",
                      "user_or_group": "ENGDOMAIN\\ad_user"
                  "comment": "HR Department Share",
                  "dir_umask": 18,
                  "file_umask": 18,
                  "name": "HR_SHARE",
                  "offline_files": "string",
                  "unix_symlink": "string",
                  "vscan_profile": "string"
            "export_policy": {
              "id": 0,
              "name": "string",
              "rules": [
                  "anonymous_user": "string",
                  "chown_mode": "string",
                  "clients": [
                      "match": "0.0.0.0/0"
                  "ntfs_unix_security": "string",
                  "protocols": [
                    "string"
                  "ro_rule": [
                    "string"
                  "rw_rule": [
                    "string"
                  "superuser": [
                    "string"
            "junction_parent": {
              "name": "vs1_root",
              "uuid": "75c9cfb0-3eb4-11eb-9fb4-005056bb088a"
            "path": "/user/my_volume",
            "security_style": "string",
            "unix_permissions": 493
            "action": "string",
              "name": "string"
          "qos": {
            "policy": {
            "name": "default",
          "space": {
            "available": 0,
            "used": 0
          "tiering": {
            "object_stores": [
                "name": "string"
            "policy": "string"
  "luns": [
      "clone": {
        "source": {
      "lun_maps": [
          "igroup": {
            "igroups": [
                "name": "igroup1",
            "initiators": [
            "name": "igroup1",
        "action": "string"
      "qos": {
        "policy": {
      "space": {
        "size": 1073741824,
        "used": 0
  "name": "string",
  "namespaces": [
        "action": "string"
      "space": {
        "block_size": 512,
        "size": 1073741824,
        "used": 0
      "subsystem_map": {
        "subsystem": {
          "hosts": [
              "dh_hmac_chap": {
    "action": "string",
    "name": "string",
      "name": "string"
  "qos": {
    "policy": {
  "replication_relationships": [
  "restore_to": {
    "snapshot": {
      "name": "string",
      "uuid": "string"
    "name": "default",
  "svm": {
    "name": "svm1",
  "tiering": {
    "object_stores": [
        "name": "string"
    "policy": "string"
  "volumes": [
      "nas": {
        "cifs": {
          "shares": [
              "acls": [
                  "type": "string",
              "dir_umask": 18,
              "file_umask": 18,
              "name": "HR_SHARE",
        "export_policy": {
          "id": 0,
          "name": "string",
          "rules": [
              "clients": [
              "protocols": [
                "string"
              "ro_rule": [
                "string"
              "rw_rule": [
                "string"
              "superuser": [
                "string"
          "name": "vs1_root",
        "action": "string",
          "name": "string"
      "qos": {
        "policy": {
        "name": "default",
      "space": {
        "available": 0,
        "used": 0
      "tiering": {
        "object_stores": [
            "name": "string"
        "policy": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
5440509
No suitable storage can be found for the specified requirements.
53411842
Consistency group does not exist.
53411843
A consistency group with specified UUID was not found.
53411844
Specified consistency group was not found in the specified SVM.
53411845
The specified UUID and name refer to different consistency groups.
53411846
Either name or UUID must be provided.
53411853
Fields provided in the request conflict with each other.
53411856
Field provided is only supported when provisioning new objects.
53411857
LUNs that are not members of the application are not supported by this API. LUNs can be added to an application by adding the volume containing the LUNs to the application.
53411860
An object with the same identifier in the same scope exists.
53411861
Volume specified does not exist in provided volume array.
53411862
Modifying existing igroups is not supported using this API.
53411864
Request content insufficient to add an existing volume to an application.
53411865
Volumes contained in one consistency group can not be added to a different consistency group.
53411866
LUNs are not supported on FlexGroups volumes.
53411867
LUN name is too long after appending a unique suffix.
53411869
Volume name is too long after appending a unique suffix.
53411870
When using the "round_robin" layout, the volume count must not be greater than the LUN count.
53411959
Volumes with Snapshot copy locking enabled cannot be added to a consistency group.
string
application
component_type
string
Nested consistency group tag.
type
string
Top level consistency group tag.
guarantee
type
string
The type of space guarantee of this volume in the aggregate.
Consistency group that is to be cloned.
name
string
The name of the consistency group.
uuid
string
parent_snapshot
name
string
uuid
string
parent_svm
name
string
uuid
string
volume
Volume name suffix/prefix for the cloned volumes.
prefix
string
Volume name prefix for cloned volumes.
suffix
string
Volume name suffix for cloned volumes.
clone
guarantee
guarantee
is_flexclone
boolean
Specifies if this consistency group is a FlexClone of a consistency group.
parent_snapshot
parent_snapshot
parent_svm
parent_svm
integer
Percentage of FlexClone blocks split from its parent consistency group.
split_estimate
integer
Space required to split the FlexClone consistency group.
split_initiated
boolean
Splits volumes after cloning. Default is false.
volume
volume
source
The source LUN for a LUN clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST to create a new LUN as a clone of the source.
Valid in PATCH to overwrite an existing LUN's data as a clone of another.
name
string
The fully qualified path name of the clone source LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH.
uuid
string
The unique identifier of the clone source LUN. Valid in POST and PATCH.
clone
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: auto_delete, qos_policy, space.guarantee.requested and space.scsi_thin_provisioning_support_enabled.
When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: class, auto_delete, lun_maps, serial_number, status.state, and uuid.
Persistent reservations for the patched LUN are also preserved.
source
source
igroups
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiators
The initiators that are members of the initiator group.
comment
string
A comment available for use by the administrator.
name
string
Name of initiator that is a member of the initiator group.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
igroups
array[igroups]
Separate igroup definitions to include in this igroup.
initiators
array[initiators]
The initiators that are members of the group.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed.
The protocol of an initiator group cannot be changed after creation of the group.
uuid
string
lun_maps
A LUN map is an association between a LUN and an initiator group.
When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup
igroup
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through the Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
  • Introduced in: 9.6
  • readCreate: 1
  • x-nullable: true
action
string
Operation to perform
count
integer
Number of elements to perform the operation on.
policy
The QoS policy
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos
policy
policy
The QoS policy
guarantee
Properties that request and report the space guarantee for the LUN.
requested
boolean
The requested space reservation policy for the LUN. If true, a space reservation is requested for the LUN; if false, the LUN is thin provisioned. Guaranteeing a space reservation request for a LUN requires that the volume in which the LUN resides is also space reserved and that the fractional reserve for the volume is 100%. Valid in POST and PATCH.
reserved
boolean
Reports if the LUN is space guaranteed.
If true, a space guarantee is requested and the containing volume and aggregate support the request. If false, a space guarantee is not requested or a space guarantee is requested and either the containing volume or aggregate do not support the request.
space
The storage space related properties of the LUN.
guarantee
guarantee
size
integer
The total provisioned size of the LUN. The LUN size can be increased but not reduced using the REST interface. The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The actual minimum and maxiumum sizes vary depending on the ONTAP version, ONTAP platform, and the available space in the containing volume and aggregate. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
  • example: 1073741824
  • format: int64
  • Max value: 140737488355328
  • Min value: 4096
  • x-nullable: true
used
integer
The amount of space consumed by the main data stream of the LUN.
This value is the total space consumed in the volume by the LUN, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways SAN filesystems and applications utilize blocks within a LUN, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the LUN blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
  • x-nullable: true
luns
A LUN is the logical representation of storage in a storage area network (SAN).
In ONTAP, a LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
A LUN can be created to a specified size using thin or thick provisioning. A LUN can then be renamed, resized, cloned, and moved to a different volume. LUNs support the assignment of a quality of service (QoS) policy for performance management or a QoS policy can be assigned to the volume containing the LUN. See the LUN object model to learn more about each of the properties supported by the LUN REST API.
A LUN must be mapped to an initiator group to grant access to the initiator group's initiators (client hosts). Initiators can then access the LUN and perform I/O over a Fibre Channel (FC) fabric using the Fibre Channel Protocol or a TCP/IP network using iSCSI.
clone
clone
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
create_time
string
The time the LUN was created.
enabled
boolean
The enabled state of the LUN. LUNs can be disabled to prevent access to the LUN. Certain error conditions also cause the LUN to become disabled. If the LUN is disabled, you can consult the state property to determine if the LUN is administratively disabled (offline) or has become disabled as a result of an error. A LUN in an error condition can be brought online by setting the enabled property to true or brought administratively offline by setting the enabled property to false. Upon creation, a LUN is enabled by default. Valid in PATCH.
lun_maps
array[lun_maps]
An array of LUN maps.
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
name
string
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the qtree name (optional), and the base name of the LUN. Valid in POST and PATCH.
os_type
string
The operating system type of the LUN.
Required in POST when creating a LUN that is not a clone of another. Disallowed in POST when creating a LUN clone.
qos
qos
serial_number
string
The LUN serial number. The serial number is generated by ONTAP when the LUN is created.
  • maxLength: 12
  • minLength: 12
  • readOnly: 1
  • x-nullable: true
space
space
uuid
string
The unique identifier of the LUN. The UUID is generated by ONTAP when the LUN is created.
  • readOnly: 1
  • x-nullable: true
guarantee
Properties that request and report the space guarantee for the NVMe namespace.
requested
boolean
The requested space reservation policy for the NVMe namespace. If true, a space reservation is requested for the namespace; if false, the namespace is thin provisioned. Guaranteeing a space reservation request for a namespace requires that the volume in which the namespace resides also be space reserved and that the fractional reserve for the volume be 100%.
The space reservation policy for an NVMe namespace is determined by ONTAP.
  • x-nullable: true
reserved
boolean
Reports if the NVMe namespace is space guaranteed.
This property is true if a space guarantee is requested and the containing volume and aggregate support the request. This property is false if a space guarantee is not requested or if a space guarantee is requested and either the containing volume and aggregate do not support the request.
space
The storage space related properties of the NVMe namespace.
block_size
integer
The size of blocks in the namespace, in bytes.
Valid in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone. Valid in POST.
guarantee
guarantee
size
integer
The total provisioned size of the NVMe namespace. Valid in POST and PATCH. The NVMe namespace size can be increased but not reduced using the REST interface.
The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The maximum size is variable with respect to large NVMe namespace support in ONTAP. If large namespaces are supported, the maximum size is 128 TB (140737488355328 bytes) and if not supported, the maximum size is just under 16 TB (17557557870592 bytes). The minimum size supported is always 4096 bytes.
  • format: int64
  • Min value: 4096
  • x-nullable: true
used
integer
The amount of space consumed by the main data stream of the NVMe namespace.
This value is the total space consumed in the volume by the NVMe namespace, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways NVMe filesystems and applications utilize blocks within a namespace, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the namespace blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
  • x-nullable: true
status
Status information about the NVMe namespace.
container_state
string
The state of the volume and aggregate that contain the NVMe namespace. Namespaces are only available when their containers are available.
mapped
boolean
Reports if the NVMe namespace is mapped to an NVMe subsystem.
There is an added computational cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
read_only
boolean
Reports if the NVMe namespace allows only read access.
state
string
The state of the NVMe namespace. Normal states for a namespace are online and offline. Other states indicate errors.
consistency_group_nvme_host_dh_hmac_chap
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol.
string
The controller secret for NVMe in-band authentication. The value of this property is used by the NVMe host to authenticate the NVMe controller while establishing a connection. If unset, the controller is not authenticated. When supplied, the property host_secret_key must also be supplied. Optional in POST.
This property is write-only. The mode property can be used to identify if a controller secret has been set for the host, but the controller secret value cannot be read. To change the value, the host must be deleted from the subsystem and re-added.
group_size
string
The Diffie-Hellman group size for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to 2048_bit. When supplied, the property host_secret_key must also be supplied. Optional in POST.
hash_function
string
The hash function for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to sha_256. When supplied, the property host_secret_key must also be supplied. Optional in POST.
host_secret_key
string
The host secret for NVMe in-band authentication. The value of this property is used by the NVMe controller to authenticate the NVMe host while establishing a connection. If unset, no authentication is performed by the host or controller. This property must be supplied if any other NVMe in-band authentication properties are supplied. Optional in POST.
This property is write-only. The mode property can be used to identify if a host secret has been set for the host, but the host secret value cannot be read. To change the value, the host must be deleted from the subsystem and re-added.
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
dh_hmac_chap
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the records property is used.
priority
string
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies io_queue count and I/O queue depth are being used.
consistency_group_nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
comment
string
A configurable comment for the NVMe subsystem. Optional in POST and PATCH.
hosts
array[consistency_group_nvme_host]
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST.
name
string
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Required in POST.
os_type
string
The host operating system of the NVMe subsystem's hosts. Required in POST.
uuid
string
The unique identifier of the NVMe subsystem.
subsystem_map
The NVMe subsystem with which the NVMe namespace is associated. A namespace can be mapped to zero (0) or one (1) subsystems.
There is an added computational cost to retrieving property values for subsystem_map. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter.
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
namespaces
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the storage virtual machine using the NVMe over Fabrics protocol.
auto_delete
boolean
This property marks the NVMe namespace for auto deletion when the volume containing the namespace runs out of space. This is most commonly set on namespace clones.
When set to true, the NVMe namespace becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the namespace is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new NVMe namespace is false.
comment
string
create_time
string
The time the NVMe namespace was created.
enabled
boolean
The enabled state of the NVMe namespace. Certain error conditions cause the namespace to become disabled. If the namespace is disabled, you can check the state property to determine what error disabled the namespace. An NVMe namespace is enabled automatically when it is created.
name
string
The fully qualified path name of the NVMe namespace composed of a "/vol" prefix, the volume name, the (optional) qtree name and base name of the namespace. Valid in POST.
NVMe namespaces do not support rename, or movement between volumes.
os_type
string
The operating system type of the NVMe namespace.
Required in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone.
space
space
subsystem_map
subsystem_map
uuid
string
The unique identifier of the NVMe namespace.
name
string
uuid
string
storage_service
Determines the placement of any storage object created during this operation.
name
string
Storage service name. If not specified, the default value is the most performant for the platform.
action
string
name
string
New name for consistency group. Required to resolve naming collisions.
storage_service
storage_service
policy
The QoS policy
name
string
uuid
string
snapshot
A consistency group's Snapshot copy
name
string
The name of the consistency group's Snapshot copy to restore to.
uuid
string
The UUID of the consistency group's Snapshot copy to restore to.
restore_to
snapshot
snapshot
name
string
uuid
string
space
Space information for the consistency group.
available
integer
The amount of space available in the consistency group, in bytes.
size
integer
The total provisioned size of the consistency group, in bytes.
used
integer
The amount of space consumed in the consistency group, in bytes.
svm
name
string
uuid
string
object_stores
name
string
The name of the object store to use. Used for placement.
tiering
control
string
Storage tiering placement rules for the object.
object_stores
array[object_stores]
Object stores to use. Used for placement.
policy
string
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold.
FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH.
all ‐ Allows tiering of both Snapshot copies and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks.
auto ‐ Allows tiering of both snapshot and active file system user data to the cloud store
none ‐ Volume blocks are not be tiered to the cloud store.
snapshot_only ‐ Allows tiering of only the volume Snapshot copies not associated with the active file system.
The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy it is 31 days.
acls
The permissions that users and groups have on a CIFS share.
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
type
string
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
  • windows - Windows user or group
  • unix_user - UNIX user
  • unix_group - UNIX group
user_or_group
string
Specifies the user or group name to add to the access control list of a CIFS share.
consistency_group_cifs_share
CIFS share is a named access point in a volume. Before users and applications can access data on the CIFS server over SMB, a CIFS share must be created with sufficient share permission. CIFS shares are tied to the CIFS server on the SVM. When a CIFS share is created, ONTAP creates a default ACL for the share with Full Control permissions for Everyone.
access_based_enumeration
boolean
Specifies whether all folders inside this share are visible to a user based on that individual user's access right; prevents the display of folders or other shared resources that the user does not have access to.
acls
array[acls]
allow_unencrypted_access
boolean
Specifies whether or not the SMB2 clients are allowed to access the encrypted share.
change_notify
boolean
Specifies whether CIFS clients can request for change notifications for directories on this share.
comment
string
Specify the CIFS share descriptions.
continuously_available
boolean
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback.
dir_umask
integer
Directory mode creation mask to be viewed as an octal number.
encryption
boolean
Specifies whether SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share.
file_umask
integer
File mode creation mask to be viewed as an octal number.
home_directory
boolean
Specifies whether or not the share is a home directory share, where the share and path names are dynamic. ONTAP home directory functionality automatically offer each user a dynamic share to their home directory without creating an individual SMB share for each user. The ONTAP CIFS home directory feature enable us to configure a share that maps to different directories based on the user that connects to it. Instead of creating a separate shares for each user, a single share with a home directory parameters can be created. In a home directory share, ONTAP dynamically generates the share-name and share-path by substituting %w, %u, and %d variables with the corresponding Windows user name, UNIX user name, and domain name, respectively.
  • Default value: 1
  • Introduced in: 9.12
  • readCreate: 1
  • x-nullable: true
name
string
Specifies the name of the CIFS share that you want to create. If this is a home directory share then the share name includes the pattern as %w (Windows user name), %u (UNIX user name) and %d (Windows domain name) variables in any combination with this parameter to generate shares dynamically.
namespace_caching
boolean
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers.
no_strict_security
boolean
Specifies whether or not CIFS clients can follow Unix symlinks outside the share boundaries.
offline_files
string
Offline Files The supported values are:
  • none - Clients are not permitted to cache files for offline access.
  • manual - Clients may cache files that are explicitly selected by the user for offline access.
  • documents - Clients may automatically cache files that are used by the user for offline access.
  • programs - Clients may automatically cache files that are used by the user for offline access and may use those files in an offline mode even if the share is available.
oplocks
boolean
Specifies whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations.
show_snapshot
boolean
Specifies whether or not the Snapshot copies can be viewed and traversed by clients.
unix_symlink
string
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
  • local - Enables only local symbolic links which is within the same CIFS share.
  • widelink - Enables both local symlinks and widelinks.
  • disable - Disables local symlinks and widelinks.
vscan_profile
string
Vscan File-Operations Profile The supported values are:
  • no_scan - Virus scans are never triggered for accesses to this share.
  • standard - Virus scans can be triggered by open, close, and rename operations.
  • strict - Virus scans can be triggered by open, read, close, and rename operations.
  • writes_only - Virus scans can be triggered only when a file that has been modified is closed.
cifs
shares
array[consistency_group_cifs_share]
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rules
allow_device_creation
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
export_policy
The policy associated with volumes to export them for protocol access.
id
integer
Identifier for the export policy.
name
string
Name of the export policy.
rules
array[export_rules]
The set of rules that govern the export policy.
junction_parent
name
string
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume.
uuid
string
Unique identifier for the parent volume.
nas
The CIFS share policy and/or export policies for this volume.
cifs
cifs
export_policy
export_policy
gid
integer
The UNIX group ID of the volume. Valid in POST or PATCH.
junction_parent
junction_parent
path
string
The fully-qualified path in the owning SVM's namespace at which the volume is mounted. The path is case insensitive and must be unique within an SVM's namespace. Path must begin with '/' and must not end with '/'. Only one volume can be mounted at any given junction path. An empty path in POST creates an unmounted volume. An empty path in PATCH deactivates and unmounts the volume. Taking a volume offline or restricted state removes its junction path. This attribute is reported in GET only when the volume is mounted.
security_style
string
Security style associated with the volume. Valid in POST or PATCH. mixed ‐ Mixed-style security ntfs ‐ NTFS/WIndows-style security unified ‐ Unified-style security, unified UNIX, NFS and CIFS permissions unix ‐ UNIX-style security.
uid
integer
The UNIX user ID of the volume. Valid in POST or PATCH.
unix_permissions
integer
UNIX permissions to be viewed as an octal number, consisting of 4 digits derived by adding up bits 4 (read), 2 (write), and 1 (execute). First digit selects the set user ID (4), set group ID (2), and sticky (1) attributes. Second digit selects permission for the owner of the file. Third selects permissions for other users in the same group while the fourth selects permissions for other users not in the group. Valid in POST or PATCH. For security style "mixed" or "unix", the default setting is 0755 in octal (493 in decimal) and for security style "ntfs", the default setting is 0000. In cases where only owner, group, and other permissions are given (as in 755, representing the second, third and fourth digit), the first digit is assumed to be zero.
action
string
count
integer
storage_service
storage_service
qos
The QoS policy for this volume.
policy
policy
The QoS policy
space
available
integer
The available space, in bytes.
size
integer
Total provisioned size, in bytes.
used
integer
The virtual space used (includes volume reserves) before storage efficiency, in bytes.
tiering
The tiering placement and policy definitions for this volume.
control
string
object_stores
policy
string
volumes
comment
string
A comment for the volume. Valid in POST or PATCH.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroups, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
nas
nas
qos
qos
snapshot_policy
space
space
tiering
tiering
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
consistency_groups
_tags
array[string]
application
application
luns
array[luns]
name
string
namespaces
array[namespaces]
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
qos
qos
restore_to
restore_to
snapshot_policy
svm
svm
tiering
tiering
uuid
string
  • readOnly: 1
  • x-nullable: true
volumes
array[volumes]
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
The round trip latency observed at the storage object, in microseconds.
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
Performance and capacity numbers, such as, IOPS, latency, throughput, used space, and available space.
available_space
integer
The total space available in the consistency group, in bytes.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
size
integer
The total size of the consistency group, in bytes.
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance and capacity data.
used_space
integer
The total space used in the consistency group, in bytes.
is_protected_by_svm_dr
boolean
Indicates whether or not this consistency group is protected by SVM DR.
is_source
boolean
Indicates whether or not this consistency group is the source for replication.
uuid
string
The unique identifier of the SnapMirror relationship.
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency observed at the storage object, in microseconds. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
These are raw performance and space numbers, such as, IOPS, latency, throughput, used space, and available space. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
available_space
integer
iops_raw
iops_raw
latency_raw
latency_raw
size
integer
status
string
throughput_raw
throughput_raw
timestamp
string
The timestamp of the performance data.
used_space
integer
The total used space in the consistency group, in bytes.
boolean
acls
array[acls]
boolean
change_notify
boolean
comment
string
boolean
dir_umask
integer
encryption
boolean
file_umask
integer
home_directory
boolean
  • Default value: 1
  • readCreate: 1
  • x-nullable: true
name
string
namespace_caching
boolean
no_strict_security
boolean
offline_files
string
oplocks
boolean
show_snapshot
boolean
unix_symlink
string
vscan_profile
string
export_clients
match
string
consistency_group
_tags
array[string]
application
application
clone
clone
consistency_groups
luns
array[luns]
name
string
namespaces
array[namespaces]
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
qos
qos
replicated
boolean
replication_source
boolean
restore_to
restore_to
snapshot_policy
svm
svm
tiering
tiering
uuid
string
  • readOnly: 1
  • x-nullable: true
volumes
array[volumes]
boolean
acls
array[acls]
boolean
change_notify
boolean
comment
string
boolean
dir_umask
integer
encryption
boolean
file_umask
integer
home_directory
boolean
  • Default value: 1
  • readCreate: 1
  • x-nullable: true
name
string
namespace_caching
boolean
no_strict_security
boolean
offline_files
string
oplocks
boolean
show_snapshot
boolean
unix_symlink
string
vscan_profile
string
export_clients
match
string
boolean
acls
array[acls]
boolean
change_notify
boolean
comment
string
boolean
dir_umask
integer
encryption
boolean
file_umask
integer
home_directory
boolean
  • Default value: 1
  • readCreate: 1
  • x-nullable: true
name
string
namespace_caching
boolean
no_strict_security
boolean
offline_files
string
oplocks
boolean
show_snapshot
boolean
unix_symlink
string
vscan_profile
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
