REST API reference
Apply an SD to a path
Applies a security descriptor (SD) to a specified path to manage access control for files and directories. Use this when you need to configure access permissions for specific resources within your storage environment.
HTTP method and endpoint
POST /protocols/file-security/permissions/{svm.uuid}/{path}
Introduced in
ONTAP 9.9
Usage notes
Applies an SD to the given path. You must keep the following points in mind while using these endpoints:
  • Either SLAG ACL/s or file-directory ACL/s can be configured in one API call. Both cannot be configured in the same API call.
  • SLAG applies to all files and/or directories in a volume hence, inheritance is not required to be propagated.
  • Set access_control field to slag while configuring SLAG ACLs.
  • Set access_control field to file_directory while configuring file-directory ACLs. By Default access_control field is set to file_directory.
  • For SLAG, valid apply_to combinations are "this-folder, sub-folders", "files", "this-folder, sub-folders, files".
  • vserver security file-directory ntfs create
  • vserver security file-directory ntfs dacl add
  • vserver security file-directory ntfs sacl add
  • vserver security file-directory policy create
  • vserver security file-directory policy task add
  • vserver security file-directory apply
path
string
path
True
target path
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
access_control
string
An Access Control Level specifies the access control of the task to be applied. Valid values are "file-directory" or "Storage-Level Access Guard (SLAG)". SLAG is used to apply the specified security descriptors with the task for the volume or qtree. Otherwise, the security descriptors are applied on files and directories at the specified path. The value SLAG is not supported on FlexGroups volumes. The default value is "file-directory" ('-' and '_' are interchangeable).
acls
array[acl]
A discretionary access security list (DACL) identifies the trustees that are allowed or denied access to a securable object. When a process tries to access a securable object, the system checks the access control entries (ACEs) in the object's DACL to determine whether to grant access to it.
control_flags
string
Specifies the control flags in the SD. It is a Hexadecimal Value.
dos_attributes
string
Specifies the file attributes on this file or directory.
effective_style
string
Specifies the effective style of the SD. The following values are supported:
  • unix - UNIX style
  • ntfs - NTFS style
  • mixed - Mixed style
  • unified - Unified style
group
string
Specifies the owner's primary group. You can specify the owner group using either a group name or SID.
group_id
string
Specifies group ID on this file or directory.
ignore_paths
array[string]
Specifies that permissions on this file or directory cannot be replaced.
inode
integer
Specifies the File Inode number.
mode_bits
integer
Specifies the mode bits on this file or directory.
owner
string
Specifies the owner of the SD. You can specify the owner using either a user name or security identifier (SID). The owner of the SD can modify the permissions on the file (or folder) or files (or folders) to which the SD is applied and can give other users the right to take ownership of the object or objects to which the SD is applied.
propagation_mode
string
Specifies how to propagate security settings to child subfolders and files. This setting determines how child files/folders contained within a parent folder inherit access control and audit information from the parent folder. The available values are:
  • propagate - propagate inheritable permissions to all subfolders and files
  • ignore - ignore inheritable permissions
  • replace - replace existing permissions on all subfolders and files with inheritable permissions
security_style
string
Specifies the security style of the SD. The following values are supported:
  • unix - UNIX style
  • ntfs - NTFS style
text_dos_attr
string
Specifies the textual format of file attributes on this file or directory.
text_mode_bits
string
Specifies the textual format of mode bits on this file or directory.
user_id
string
Specifies user ID of this file or directory.
Example request
  "access_control": "file_directory",
  "acls": [
      "access": "access_allow",
      "inherited": 1,
      "rights": "full_control",
      "user": "S-1-5-21-2233347455-2266964949-1780268902-69304"
  "control_flags": "8014",
  "dos_attributes": "10",
  "effective_style": "mixed",
  "group": "S-1-5-21-2233347455-2266964949-1780268902-69700",
  "group_id": "2",
  "ignore_paths": [
    "/dir1/dir2/",
    "/parent/dir3"
  "inode": 64,
  "mode_bits": 777,
  "owner": "S-1-5-21-2233347455-2266964949-1780268902-69304",
  "propagation_mode": "propagate",
  "security_style": "ntfs",
  "text_dos_attr": "---A----",
  "text_mode_bits": "rwxrwxrwx",
  "user_id": "10"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
655865
The specified file or directory does not exist.
10485813
All values corresponding to rights cannot be false.
10485815
The field "acls.access_control" is not allowed with POST method.
10485810
User is a required field.
1260882
Specified SVM not found.
6691623
User is not authorized.
4849676
The specified Windows user or group does not exist.
4849677
Failed to convert SID to a Windows name. Reason: "SecD Error: object not found".
10485814
The value provided for field control_flags is invalid.
10485813
All values cannot be false.
advanced_rights
Specifies the advanced access right controlled by the ACE for the account specified. You can specify more than one "advanced-rights" value by using a comma-delimited list.
append_data
boolean
Append DAta
delete
boolean
Delete
delete_child
boolean
Delete Child
execute_file
boolean
Execute File
full_control
boolean
Full Control
read_attr
boolean
Read Attributes
read_data
boolean
Read Data
read_ea
boolean
Read Extended Attributes
read_perm
boolean
Read Permissions
synchronize
boolean
Synchronize
write_attr
boolean
Write Attributes
write_data
boolean
Write Data
write_ea
boolean
Write Extended Attributes
write_owner
boolean
Write Owner
write_perm
boolean
Write Permission
apply_to
Specifies where to apply the DACL or SACL entries. You can specify more than one value by using a comma-delimited list.
files
boolean
Apply to Files
sub_folders
boolean
Apply to all sub-folders
this_folder
boolean
Apply only to this folder
acl
An ACE is an element in an access control list (ACL). An ACL can have zero or more ACEs. Each ACE controls or monitors access to an object by a specified trustee.
access
string
Specifies whether the ACL is for DACL or SACL. The available values are:
  • access_allow - DACL for allow access
  • access_deny - DACL for deny access
  • access_allowed_callback - CALLBACK for allowed access
  • access_denied_callback - CALLBACK for denied access
  • access_allowed_callback_object - CALLBACK OBJECT for allowed access
  • access_denied_callback_object - CALLBACK OBJECT for denied access
  • system_audit_callback - SYSTEM Audit Callback ace
  • system_audit_callback_object - SYSTEM Audit Callback Object ace
  • system_resource_attribute - SYSTEM Resource Attribute
  • system_scoped_policy_id - SYSTEM Scope Policy ID
  • audit_success - SACL for success access
  • audit_failure - SACL for failure access
  • audit_success_and_failure - SACL for both success and failure access
access_control
string
advanced_rights
advanced_rights
apply_to
apply_to
inherited
boolean
Indicates whether or not the ACE flag is inherited.
rights
string
Specifies the access rights controlled by the ACE for the account specified. The "rights" parameter is mutually exclusive with the "advanced_rights" parameter. If you specify the "rights" parameter, you can specify one of the following "rights" values ("-" or "_" is accepted as the delimiter).
user
string
Specifies the account to which the ACE applies. You can specify either name or SID.
file_directory_security
Manages New Technology File System (NTFS) security and NTFS audit policies.
access_control
string
acls
array[acl]
control_flags
string
dos_attributes
string
effective_style
string
  • unix - UNIX style
  • ntfs - NTFS style
group
string
group_id
string
ignore_paths
array[string]
inode
integer
mode_bits
integer
owner
string
propagation_mode
string
security_style
string
  • unix - UNIX style
  • ntfs - NTFS style
text_dos_attr
string
text_mode_bits
string
user_id
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
