Protocols Vscan svm.uuid on-access-policies endpoint overview
Overview
Use Vscan On-Access scanning to actively scan file objects for viruses when clients access files over SMB. To control which file operations trigger a vscan, use Vscan File-Operations Profile (vscan-fileop-profile) option in the CIFS share. The Vscan On-Access policy configuration defines the scope and status of On-Access scanning on file objects. Use this API to retrieve and manage Vscan On-Access policy configurations and Vscan On-Access policy statuses for the SVM.
Retrieving all fields for all policies of an SVM
# The API:
/api/protocols/vscan/{svm.uuid}/on-access-policies/
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/{svm.uuid}/on-access-policies?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "179d3c85-7053-11e8-b9b8-005056b41bd1",
"name": "vs1",
"href": "/api/svm/svms/179d3c85-7053-11e8-b9b8-005056b41bd1"
"name": "default_CIFS",
"enabled": true,
"mandatory": true,
"scope": {
"max_file_size": 2147483648,
"include_extensions": [
"scan_without_extension": true,
"scan_readonly_volumes": false,
"only_execute_access": false
"href": "/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies/default_CIFS"
"svm": {
"name": "vs1",
"name": "on-access-policy",
"enabled": false,
"mandatory": true,
"scope": {
"max_file_size": 3221225472,
"exclude_paths": [
"\\vol\\a b\\",
"\\vol\\a,b\\"
"mp*",
"tx*"
"exclude_extensions": [
"mp3",
"txt"
"only_execute_access": true
"href": "/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies/on-access-policy"
"num_records": 2,
"href": "/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies?fields=*"
Retrieving the specific On-Access policy associated with the specified SVM
# The API:
/api/protocols/vscan/{svm.uuid}/on-access-policies/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies/on-access-policy" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1",
"enabled": true,
"mandatory": true,
"scope": {
"exclude_paths": [
"\\vol\\a b\\",
"\\vol\\a,b\\"
"mp*",
"tx*"
"mp3",
"txt"
"href": "/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies/task1"
Creating a Vscan On-Access policy
The Vscan On-Access policy POST endpoint creates an On-Access policy for the specified SVM. Set enabled to "true" to enable scanning on the created policy.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-access-policies?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"enabled\": false, \"mandatory\": true, \"name\": \"on-access-policy\", \"scope\": { \"exclude_extensions\": [ \"txt\", \"mp3\" ], \"exclude_paths\": [ \"\\\\dir1\\\\dir2\\\\ame\", \"\\\\vol\\\\a b\" ], \"include_extensions\": [ \"mp*\", \"txt\" ], \"max_file_size\": 3221225472, \"only_execute_access\": true, \"scan_readonly_volumes\": false, \"scan_without_extension\": true }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"enabled": false,
"mandatory": true,
"scope": {
"exclude_paths": [
"\\dir1\\dir2\\ame",
"\\vol\\a b"
"mp*",
"txt"
"txt",
"mp3"
Creating a Vscan On-Access policy where a number of optional fields are not specified
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-access-policies?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"enabled\": false, \"mandatory\": true, \"name\": \"on-access-policy\", \"scope\": { \"exclude_paths\": [ \"\\\\vol\\\\a b\", \"\\\\vol\\\\a,b\\\\\" ], \"max_file_size\": 1073741824, \"scan_without_extension\": true }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"enabled": false,
"mandatory": true,
"scope": {
"max_file_size": 1073741824,
"exclude_paths": [
"\\vol\\a b",
"\\vol\\a,b\\"
Updating a Vscan On-Access policy
The policy being modified is identified by the UUID of the SVM and the policy name.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-access-policies/on-access-policy" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"scope\": { \"include_extensions\": [ \"txt\" ], \"only_execute_access\": true, \"scan_readonly_volumes\": false, \"scan_without_extension\": true }}"
Deleting a Vscan On-Access policy
The policy to be deleted is identified by the UUID of the SVM and the policy name.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-access-policies/on-access-policy" -H "accept: application/hal+json"
