REST API reference
ONTAP REST API Resource-tags endpoints
Overview
You can use this endpoint to list all of the tags that have been used on resources in the API. See the section labelled Tagging Resources for Tracking Purposes to find out more information about how to tag a resource.
The following examples show some ways that this endpoint can be used.
List all of the used tags
# The API:
/api/resource-tags
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags"
# The response:
"records": [
    "value": "team:accounting",
    "num_resources": 2,
        "href": "/api/resource-tags/team%3Aaccounting"
    "value": "environment:test",
    "num_resources": 5,
        "href": "/api/resource-tags/environment%3Atest"
"num_records": 2,
    "href": "/api/resource-tags"
Find tags that are being used by at least 3 resources
# The API:
/api/resource-tags
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags?num_resources=>=3"
# The response:
"records": [
    "num_resources": 5,
"num_records": 1,
    "href": "/api/resource-tags?num_resources=>=3"
