REST API reference
ONTAP REST API Storage shelves endpoints
Retrieving storage shelf information
The storage shelf GET API retrieves all of the shelves in the cluster.
1) Retrieve a list of shelves from the cluster
The following example shows the response with a list of shelves in the cluster:
# The API:
/api/storage/shelves
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/shelves" -H "accept: application/hal+json"
# The response:
"records": [
    "uid": "3109174803597886800",
        "href": "/api/storage/shelves/3109174803597886800"
    "uid": "9237728366621690448",
        "href": "/api/storage/shelves/9237728366621690448"
    "uid": "9946762738829886800",
        "href": "/api/storage/shelves/9946762738829886800"
    "uid": "10318311901725526608",
        "href": "/api/storage/shelves/10318311901725526608"
    "uid": "13477584846688355664",
        "href": "/api/storage/shelves/13477584846688355664"
"num_records": 5,
    "href": "/api/storage/shelves/"
2) Retrieve a specific shelf from the cluster
The following example shows the response of the requested shelf. If there is no shelf with the requested uid, an error is returned.
# The API:
/api/storage/shelves/{uid}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/shelves/3109174803597886800" -H "accept: application/hal+json"
# The response:
"name": "6.10",
"id": "10",
"serial_number": "SHU0954292N0HAH",
"model": "DS4246",
"module_type": "iom6",
"internal": false,
"local": true,
"manufacturer": {
  "name": "NETAPP"
"state": "ok",
"connection_type": "sas",
"disk_count": 24,
"location_led": "off",
"paths": [
    "name": "0e",
    "node": {
      "uuid": "0530d6c1-8c6d-11e8-907f-00a0985a72ee",
      "name": "node-1",
          "href": "/api/cluster/nodes/0530d6c1-8c6d-11e8-907f-00a0985a72ee"
        "href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0e"
    "name": "0g",
    "node": {
      "name": "node-1",
        "href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0g"
"bays": [
    "id": 0,
    "has_disk": true,
    "type": "single_disk",
    "state": "ok"
    "id": 1,
    "has_disk": true,
    "state": "ok"
    "id": 2,
    "has_disk": true,
    "state": "ok"
    "id": 3,
    "has_disk": true,
    "state": "ok"
    "id": 4,
    "has_disk": true,
    "state": "ok"
    "id": 5,
    "has_disk": true,
    "state": "ok"
    "id": 6,
    "has_disk": true,
    "state": "ok"
    "id": 7,
    "has_disk": true,
    "state": "ok"
    "id": 8,
    "has_disk": true,
    "state": "ok"
    "id": 9,
    "has_disk": true,
    "state": "ok"
    "id": 10,
    "has_disk": true,
    "state": "ok"
    "id": 11,
    "has_disk": true,
    "state": "ok"
    "id": 12,
    "has_disk": true,
    "state": "ok"
    "id": 13,
    "has_disk": true,
    "state": "ok"
    "id": 14,
    "has_disk": true,
    "state": "ok"
    "id": 15,
    "has_disk": true,
    "state": "ok"
    "id": 16,
    "has_disk": true,
    "state": "ok"
    "id": 17,
    "has_disk": true,
    "state": "ok"
    "id": 18,
    "has_disk": true,
    "state": "ok"
    "id": 19,
    "has_disk": true,
    "state": "ok"
    "id": 20,
    "has_disk": true,
    "state": "ok"
    "id": 21,
    "has_disk": true,
    "state": "ok"
    "id": 22,
    "has_disk": true,
    "state": "ok"
    "id": 23,
    "has_disk": true,
    "state": "ok"
"frus": [
    "type": "module",
    "id": 0,
    "state": "ok",
    "part_number": "111-00690+B2",
    "serial_number": "8001900099",
    "firmware_version": "0191",
    "installed": true
    "type": "module",
    "id": 1,
    "state": "ok",
    "part_number": "111-00190+B0",
    "serial_number": "7903785183",
    "installed": true
    "type": "psu",
    "id": 1,
    "state": "ok",
    "part_number": "0082562-12",
    "serial_number": "PMW82562007513E",
    "firmware_version": "0311",
    "installed": true,
    "psu": {
      "model": "9C"
    "type": "psu",
    "id": 2,
    "state": "ok",
    "serial_number": "PMW825620075138",
    "installed": true,
    "psu": {
      "model": "9C"
    "type": "psu",
    "id": 3,
    "state": "ok",
    "serial_number": "PMW8256200750BA",
    "installed": true,
    "psu": {
      "model": "9C"
    "type": "psu",
    "id": 4,
    "state": "ok",
    "serial_number": "PMW8256200750A2",
    "installed": true,
    "psu": {
      "model": "9C"
"ports": [
    "id": 0,
    "module_id": "a",
    "designator": "square",
    "state": "connected",
    "internal": false,
    "wwn": "500A098000C9EDBF",
    "cable": {
      "identifier": "5001086000702488-500a098000c9edbf",
      "part_number": "112-00430+A0",
      "length": "2m",
      "serial_number": "APF16510229807"
    "remote": {
      "wwn": "5001086000702488",
      "phy": "08"
    "id": 1,
    "module_id": "a",
    "designator": "circle",
    "internal": false,
    "cable": {
      "identifier": "500a098000d5c4bf-500a098000c9edbf",
      "part_number": "112-00176+A0",
      "length": "0.5-1.0m",
      "serial_number": "APF133917610YT"
    "remote": {
      "wwn": "500A098000D5C4BF",
      "phy": "00"
    "id": 2,
    "module_id": "b",
    "internal": false,
    "wwn": "500A098004F208BF",
    "cable": {
      "identifier": "5001086000702648-500a098004f208bf",
      "length": "2m",
      "serial_number": "APF16510229540"
    "remote": {
      "wwn": "5001086000702648",
      "phy": "08"
    "id": 3,
    "module_id": "b",
    "internal": false,
    "cable": {
      "identifier": "500a0980062ba33f-500a098004f208bf",
      "part_number": "112-00176+20",
      "serial_number": "832210017"
    "remote": {
      "wwn": "500A0980062BA33F",
      "phy": "00"
"fans": [
    "id": 1,
    "location": "rear of the shelf on the upper left power supply",
    "rpm": 3150,
    "state": "ok",
    "installed": true
    "id": 2,
    "rpm": 3000,
    "state": "ok",
    "installed": true
    "id": 3,
    "location": "rear of the shelf on the upper right power supply",
    "rpm": 3220,
    "state": "ok",
    "installed": true
    "id": 4,
    "rpm": 3000,
    "state": "ok",
    "installed": true
    "id": 5,
    "location": "rear of the shelf on the lower left power supply",
    "rpm": 3000,
    "state": "ok",
    "installed": true
    "id": 6,
    "rpm": 3150,
    "state": "ok",
    "installed": true
    "id": 7,
    "location": "rear of the shelf on the lower right power supply",
    "rpm": 3150,
    "state": "ok",
    "installed": true
    "id": 8,
    "rpm": 3000,
    "state": "ok",
    "installed": true
"temperature_sensors": [
    "id": 1,
    "location": "front of the shelf on the left, on the OPS panel",
    "temperature": 20,
    "ambient": true,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 42,
        "warning": 40
      "low": {
        "critical": 0,
        "warning": 5
    "id": 2,
    "location": "inside of the shelf on the midplane",
    "temperature": 29,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 3,
    "temperature": 33,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 4,
    "temperature": 41,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 70,
        "warning": 65
      "low": {
        "critical": 5,
        "warning": 10
    "id": 5,
    "temperature": 32,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 6,
    "temperature": 41,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 70,
        "warning": 65
      "low": {
        "critical": 5,
        "warning": 10
    "id": 7,
    "temperature": 34,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 8,
    "temperature": 45,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 70,
        "warning": 65
      "low": {
        "critical": 5,
        "warning": 10
    "id": 9,
    "temperature": 30,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 10,
    "temperature": 40,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 70,
        "warning": 65
      "low": {
        "critical": 5,
        "warning": 10
    "id": 11,
    "location": "rear of the shelf at the top left, on shelf module A",
    "temperature": 30,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 60,
        "warning": 55
      "low": {
        "critical": 5,
        "warning": 10
    "id": 12,
    "location": "rear of the shelf at the top right, on shelf module B",
    "temperature": 33,
    "ambient": false,
    "state": "ok",
    "installed": true,
    "threshold": {
      "high": {
        "critical": 60,
        "warning": 55
      "low": {
        "critical": 5,
        "warning": 10
"voltage_sensors": [
    "id": 1,
    "voltage": 5.11,
    "state": "ok",
    "installed": true
    "id": 2,
    "voltage": 12.38,
    "state": "ok",
    "installed": true
    "id": 3,
    "voltage": 5.11,
    "state": "ok",
    "installed": true
    "id": 4,
    "voltage": 12.26,
    "state": "ok",
    "installed": true
    "id": 5,
    "voltage": 5.7,
    "state": "ok",
    "installed": true
    "id": 6,
    "voltage": 12.26,
    "state": "ok",
    "installed": true
    "id": 7,
    "voltage": 5.15,
    "state": "ok",
    "installed": true
    "id": 8,
    "voltage": 12.3,
    "state": "ok",
    "installed": true
"current_sensors": [
    "id": 1,
    "current": 6990,
    "state": "ok",
    "installed": true
    "id": 2,
    "current": 5150,
    "state": "ok",
    "installed": true
    "id": 3,
    "current": 4600,
    "state": "ok",
    "installed": true
    "id": 4,
    "current": 4800,
    "state": "ok",
    "installed": true
    "id": 5,
    "current": 4140,
    "state": "ok",
    "installed": true
    "id": 6,
    "current": 7770,
    "state": "ok",
    "installed": true
    "id": 7,
    "current": 4140,
    "state": "ok",
    "installed": true
    "id": 8,
    "current": 4720,
    "state": "ok",
    "installed": true
"acps": [
    "enabled": true,
    "channel": "in_band",
    "connection_state": "active",
    "node": {
      "uuid": "cf62d23c-6100-11eb-9852-00a098fd725d",
      "name": "cat33-01",
          "href": "/api/cluster/nodes/cf62d23c-6100-11eb-9852-00a098fd725d"
    "enabled": true,
    "node": {
      "uuid": "d0892dd7-6100-11eb-9cdb-d039ea010238",
      "name": "cat33-02",
          "href": "/api/cluster/nodes/d0892dd7-6100-11eb-9cdb-d039ea010238"
Modifying storage shelf
The storage shelf PATCH API modifies the shelf location LED.
Example
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/shelves/3109174803597886800" -H "accept: application/hal+json" -H "Content-Type: application/hal+json" -d '{"location_led": "on"}'
# The response:
