View iSCSI sessions
Access the iSCSI sessions REST API to gather detailed information about iSCSI initiators that have successfully logged in to ONTAP. Use these endpoints to monitor session details such as connections and target portal group associations.
Overview
An iSCSI session is one or more TCP connections that link an iSCSI initiator with an iSCSI target. TCP connections can be added and removed from an iSCSI session by the iSCSI initiator. Across all TCP connections within an iSCSI session, an initiator sees one and the same target. After the connection is established, iSCSI control, data, and status messages are communicated over the session.
The iSCSI sessions REST API provides information about iSCSI initiators that have successfully logged in to ONTAP.
Retrieving all iSCSI sessions
# The API:
GET /api/protocols/san/iscsi/sessions
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/san/iscsi/sessions" -H "Accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "a009a9e7-4081-b576-7575-ada21efcaf16",
"name": "svm1",
"href": "/api/svm/svms/a009a9e7-4081-b576-7575-ada21efcaf16"
"target_portal_group": "iscsi_lif1",
"tsih": 10,
"href": "/api/protocols/san/iscsi/sessions/a009a9e7-4081-b576-7575-ada21efcaf16/iscsi_lif1/10"
"svm": {
"uuid": "b009a9e7-4081-b576-7575-ada21efcaf16",
"name": "svm2",
"href": "/api/svm/svms/b009a9e7-4081-b576-7575-ada21efcaf16"
"target_portal_group": "iscsi_lif2",
"tsih": 11,
"href": "/api/protocols/san/iscsi/sessions/b009a9e7-4081-b576-7575-ada21efcaf16/iscsi_lif2/11"
"num_records": 2,
"href": "/api/protocols/san/iscsi/sessions"
Retrieving all of the iSCSI sessions under the target portal group iscsi_lif1
The tpgroup query parameter is used to perform the query.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/san/iscsi/sessions?tpgroup=iscsi_lif1" -H "Accept: application/hal+json"
# The response:
"records": [
"svm": {
"name": "svm1",
"tsih": 10,
"num_records": 1,
Retrieving an iSCSI session
# The API:
GET /api/protocols/san/iscsi/sessions/{svm.uuid}/{target_portal_group}/{tsih}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/san/iscsi/sessions/a009a9e7-4081-b576-7575-ada21efcaf16/iscsi_lif1/10" -H "Accept: application/hal+json"
# The response:
"svm": {
"name": "svm1",
"tsih": 10,
"initiator": {
"name": "iqn.1994-05.com.example:string",
"comment": "Example information about this initiator"
"isid": "61:62:63:64:65:00",
"target_portal_group_tag": 1027,
"connections": [
"cid": 1,
"authentication_type": "chap",
"initiator_address": {
"address": "10.224.123.85",
"port": 43827
"interface": {
"name": "iscsi_lif1",
"uuid": "c15439b4-dbb4-11e8-90ac-005056bba882",
"ip": {
"address": "192.168.0.1",
"port": 3260
"href": "/api/network/ip/interfaces/c15439b4-dbb4-11e8-90ac-005056bba882"
"igroups": [
"uuid": "af7838cd-f993-4faf-90b7-5524787ae1e8",
"name": "igroup1",
"href": "/api/protocols/san/igroups/af7838cd-f993-4faf-90b7-5524787ae1e8"
"uuid": "bf7838cd-f993-4faf-90b7-5524787ae1e8",
"name": "igroup2",
"href": "/api/protocols/san/igroups/bf7838cd-f993-4faf-90b7-5524787ae1e8"
