View NVMe subsystem controllers
Explore NVMe subsystem controllers to understand dynamic connections between hosts and your storage solution. This API provides detailed information about the connections, helping you monitor and manage NVMe interactions effectively.
Overview
Non-Volatile Memory Express (NVMe) subsystem controllers represent dynamic connections between hosts and a storage solution.
The NVMe subsystem controllers REST API provides information about connected hosts.
Retrieving the NVMe subsystem controllers for the entire system
# The API:
GET /api/protocols/nvme/subsystem-controllers
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/subsystem-controllers' -H 'Accept: application/hal+json'
# The response:
"records": [
"svm": {
"uuid": "f0f5b928-2593-11e9-94c4-00a0989a1c8e",
"name": "symmcon_fcnvme_vserver_0",
"href": "/api/svm/svms/f0f5b928-2593-11e9-94c4-00a0989a1c8e"
"subsystem": {
"uuid": "14875240-2594-11e9-abde-00a098984313",
"name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_0",
"href": "/api/protocols/nvme/subsystems/14875240-2594-11e9-abde-00a098984313"
"id": "0040h",
"href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0040h"
"svm": {
"subsystem": {
"id": "0041h",
"href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0041h"
"svm": {
"subsystem": {
"uuid": "1489d0d5-2594-11e9-94c4-00a0989a1c8e",
"name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_1",
"href": "/api/protocols/nvme/subsystems/1489d0d5-2594-11e9-94c4-00a0989a1c8e"
"id": "0040h",
"href": "/api/protocols/nvme/subsystem-controllers/1489d0d5-2594-11e9-94c4-00a0989a1c8e/0040h"
"svm": {
"subsystem": {
"id": "0041h",
"href": "/api/protocols/nvme/subsystem-controllers/1489d0d5-2594-11e9-94c4-00a0989a1c8e/0041h"
"num_records": 4,
"href": "/api/protocols/nvme/subsystem-controllers"
Retrieving the NVMe subsystem controllers for a specific subsystem
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/subsystem-controllers?subsystem.uuid=14875240-2594-11e9-abde-00a098984313' -H 'Accept: application/hal+json'
# The response:
"records": [
"svm": {
"subsystem": {
"id": "0040h",
"svm": {
"subsystem": {
"id": "0041h",
"num_records": 2,
"href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313"
Retrieving a specific NVMe subsystem controller
# The API:
GET /api/protocols/nvme/subsystem-controllers/{subsystem.uuid}/{id}
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0040h' -H 'Accept: application/hal+json'
# The response:
"svm": {
"subsystem": {
"id": "0040h",
"interface": {
"name": "symmcon_lif_fcnvme_symmcon_fcnvme_vserver_0_3a_0",
"uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e",
"transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
"href": "/api/protocols/nvme/interfaces/fa1c5941-2593-11e9-94c4-00a0989a1c8e"
"node": {
"name": "ssan-8040-94a",
"uuid": "ebf66f05-2590-11e9-abde-00a098984313",
"href": "/api/cluster/nodes/ebf66f05-2590-11e9-abde-00a098984313"
"host": {
"transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806",
"nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
"id": "b8546ca6097349e5b1558dc154fc073b"
"io_queue": {
"count": 4,
"depth": [
32,
32,
32,
32
"admin_queue": {
"depth": 32
"dh_hmac_chap": {
"mode": "none"
"keep_alive_timeout": 4000,
"digest.header": true,
"digest.data": false,
