REST API reference
View SSH SVMs
Overview
This endpoint is used to retrieve the SSH security configuration for all data SVMs. The configuration consists of SSH security parameters. The security algorithms include SSH key exchange algorithms, ciphers for payload encryption, MAC algorithms, and the maximum authentication retry attempts allowed before closing the connection. The SSH configuration for a newly created SVM is the same as the SSH configuration at cluster level. When the cluster SSH configuration is updated using /security/ssh endpoint, the SSH configuration of existing SVMs is not impacted. To customize the SSH security parameters for a particular data SVM, perform a PATCH operation on the api/security/ssh/svms/{svm.uuid} endpoint.
Example
Retrieving the SSH security configuration of all SVMs.
Retrieves the SSH security configurations associated with the owners or filtered list (for a specific data SVM and so on).
# The API:
GET "/api/security/ssh/svms"
# The call:
curl -X GET "https://<mgmt-ip>/api/security/ssh/svms?fields=*"
# The response
"records": [
    "svm": {
      "uuid": "739e5da5-1a50-11ee-9cb0-005056bb97dc",
      "name": "svm1",
          "href": "/api/svm/svms/739e5da5-1a50-11ee-9cb0-005056bb97dc"
     "ciphers": [
       "aes256_ctr",
       "aes192_ctr",
       "aes128_ctr",
       "aes128_gcm",
       "aes256_gcm"
     "key_exchange_algorithms": [
       "diffie_hellman_group_exchange_sha256",
       "ecdh_sha2_nistp256",
       "ecdh_sha2_nistp384",
       "ecdh_sha2_nistp521",
       "curve25519_sha256"
     "mac_algorithms": [
       "hmac_sha2_256",
       "hmac_sha2_512",
       "hmac_sha2_256_etm",
       "hmac_sha2_512_etm",
       "umac_64",
       "umac_128",
       "umac_64_etm",
       "umac_128_etm"
     "max_authentication_retry_count": 6,
         "href": "/api/security/ssh/svms/739e5da5-1a50-11ee-9cb0-005056bb97dc"
 "num_records": 1,
       "href": "/api/security/ssh/svms?fields=*"
# The call:
curl -X GET "https://<mgmt-ip>/api/security/ssh/svms"
# The response:
"records": [
    "svm": {
      "uuid": "02c9e252-41be-11e9-81d5-00a0986138f7",
      "name": "svm1",
          "href": "/api/svm/svms/02c9e252-41be-11e9-81d5-00a0986138f7"
        "href": "/api/security/ssh/svms/02c9e252-41be-11e9-81d5-00a0986138f7"
"num_records": 1,
      "href": "/api/security/ssh/svms"
