Delete an external-role-mapping entry
Deletes an external role mapping entry to remove an association between an external role and ONTAP, which helps manage access permissions effectively.
HTTP method and endpoint
DELETE /security/external-role-mappings/{external_role}/{provider}
Introduced in
ONTAP 9.16
Usage notes
Deletes an external-role-mapping entry.
Related ONTAP commands
security login external-role-mapping delete
external_role |
string |
path |
True |
provider |
string |
path |
True |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
