REST API reference
Forward audit logs to syslog/splunk servers
Control the forwarding of audit log information to remote syslog and Splunk servers using this API. You can configure multiple destinations to ensure all audit records are sent to each location.
Overview
This API controls the forwarding of audit log information to remote syslog/splunk servers. Multiple destinations can be configured and all audit records are forwarded to all destinations.
A GET operation retrieves information about remote syslog/splunk server destinations. A POST operation creates a remote syslog/splunk server destination. A GET operation on /security/audit/destinations/{address}/{port} retrieves information about the syslog/splunk server destination given its address and port number. A PATCH operation on /security/audit/destinations/{address}/{port} updates information about the syslog/splunk server destination given its address and port number. A DELETE operation on /security/audit/destinations/{address}/{port} deletes a syslog/splunk server destination given its address and port number.
Overview of fields used for creating a remote syslog/splunk destination
The fields used for creating a remote syslog/splunk destination fall into the following categories
Required properties
All of the following fields are required for creating a remote syslog/splunk destination
  • address
Optional properties
All of the following fields are optional for creating a remote syslog/splunk destination
  • port
  • ipspace
  • protocol
  • facility
  • verify_server
  • message_format (Can be either "legacy_netapp" or "rfc_5424")
  • timestamp_format_override (Can be either "no_override", "rfc_3164", "iso_8601_utc" or "iso_8601_local_time")
  • hostname_format_override (Can be either "no_override", "fqdn" or "hostname_only") +
Retrieving remote syslog/splunk server destinations
The following example shows remote syslog/splunk server destinations
# The API:
/api/security/audit/destinations
# The call:
curl -X GET "https://<cluster-ip>/api/security/audit/destinations"
# The response:
"records": [
    "address": "1.1.1.1",
    "port": 514,
        "href": "/api/security/audit/destinations/1.1.1.1/514"
 "num_records": 1,
     "href": "/api/security/audit/destinations"
Creating remote syslog/splunk server destinations
The following example creates remote syslog/splunk server destinations.
# The API:
# The call:
curl -X POST "https://<cluster-ip>/api/security/audit/destinations?force=true" -d '{ "address": "1.1.1.1", "port": 514, "protocol": "udp_unencrypted", "facility": "kern"}'
Retrieving a remote syslog/splunk server destination given its destination address and port number
The following example retrieves a remote syslog/splunk server destination given its destination address and port number.
# The API:
/api/security/audit/destinations/{address}/{port}
# The call:
curl -X GET "https://<cluster-ip>/api/security/audit/destinations/1.1.1.1/514"
# The response:
"port": 514,
"ipspace": {
  "name": "Default",
  "uuid": "a97a3549-f7ae-11ec-b6bc-005056a7c8ff"
"facility": "kern",
"verify_server": false,
"message_format": "legacy_netapp",
"timestamp_format_override": "no_override",
"hostname_format_override": "no_override",
Updating a remote syslog/splunk server destination given its destination address and port number
The following example updates a remote syslog/splunk server destination configuration given its destination address and port number.
# The API:
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/audit/destinations/1.1.1.1/514" -d '{"facility":  "user"}'
Deleting a remote syslog/splunk server destination given its destination address and port number
The following example deletes a remote syslog/splunk server destination configuration given its destination address and port number.
# The API:
# The call:
curl -X DELETE "https://<cluster-ip>/api/security/audit/destinations/1.1.1.1/514"
