Retrieve the cluster software profile
Retrieves the software profile of a cluster to understand its current software configuration.
HTTP method and endpoint
GET /cluster/software
Introduced in
ONTAP 9.6
Related ONTAP commands
cluster image show -
cluster image show-update-progress -
system node image package show
Learn more
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
action |
string |
User triggered action to apply to the install operation |
elapsed_duration |
integer |
Elapsed time during the upgrade or validation operation |
estimated_duration |
integer |
Overall estimated time for completion of the upgrade or validation operation. |
metrocluster |
nodes |
array[software_node_reference] |
List of nodes, active versions, and firmware update progressions. |
pending_version |
string |
Version being installed on the system.
post_update_checks |
List of failed post-update checks' warnings, errors, and advice. |
state |
string |
Operational state of the upgrade |
status_details |
Display status details. |
update_details |
Display update progress details. |
validation_results |
List of validation warnings, errors, and advice. |
version |
string |
Version of ONTAP installed and currently active on the system. During PATCH, using the 'validate_only' parameter on the request executes pre-checks, but does not perform the full installation.
"href": "/api/resourcelink"
"action": "pause",
"elapsed_duration": 2140,
"estimated_duration": 5220,
"metrocluster": {
"clusters": [
"estimated_duration": 3480,
"name": "cluster_A",
"state": "in_progress"
"progress_details": {
"message": "Switchover in progress"
"progress_summary": {
"message": "MetroCluster updated successfully."
"nodes": [
"firmware": {
"cluster_fw_progress": [
"job": {
"uuid": "string"
"update_state": [
"attempts": 3,
"code": 2228325,
"message": "Cannot open local staging ZIP file disk_firmware.zip",
"status": "string",
"worker_node": {
"name": "node1",
"update_type": "string",
"zip_file_name": "disk_firmware.zip"
"disk": {
"average_duration_per_disk": 120,
"num_waiting_download": 0,
"total_completion_estimate": 0,
"update_status": "running"
"dqp": {
"file_name": "qual_devices_v3",
"record_count": {
"alias": 200,
"device": 29,
"drive": 680,
"system": 3
"revision": "20200117",
"version": "3.18"
"shelf": {
"in_progress_count": 2,
"sp_bmc": {
"autoupdate": "",
"end_time": "2020-05-17 16:00:00 -0400",
"fw_type": "SP",
"image": "primary",
"is_current": 1,
"last_update_state": "passed",
"percent_done": 100,
"running_version": "1.2.3.4",
"start_time": "2020-05-17 16:00:00 -0400",
"state": "installed"
"name": "node1",
"software_images": [
"package": "image.tgz"
"version": "ONTAP_X"
"pending_version": "ONTAP_X_1",
"post_update_checks": [
"action": {
"message": "Use NFS hard mounts, if possible."
"issue": {
"message": "Cluster HA is not configured in the cluster."
"status": "warning",
"update_check": "nfs_mounts"
"state": "completed",
"status_details": [
"action": {
"message": "string"
"end_time": "2019-02-02 14:00:00 -0500",
"issue": {
"code": 10551399,
"message": "Image update complete"
"name": "initialize",
"node": {
"name": "node1"
"start_time": "2019-02-02 14:00:00 -0500",
"state": "failed"
"update_details": [
"elapsed_duration": 2100,
"estimated_duration": 4620,
"node": {
"name": "node1"
"phase": "Post-update checks",
"state": "failed"
"validation_results": [
"action": {
"issue": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1048576 |
Error initializing software image information. |
1048577 |
Software image information not initialized. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
software_mcc_reference
elapsed_duration |
integer |
Elapsed duration of update time (in seconds) of MetroCluster. |
integer |
Estimated duration of update time (in seconds) of MetroCluster. |
name |
string |
Name of the site in MetroCluster. |
state |
Upgrade state of MetroCluster. |
progress_details
message |
string |
MetroCluster update progress details. |
progress_summary
message |
string |
MetroCluster update progress summary. |
metrocluster
clusters |
array[software_mcc_reference] |
List of MetroCluster sites, statuses, and active ONTAP versions.
progress_details |
progress_summary |
job_link
_links |
uuid |
string |
worker_node
_links |
name |
string |
uuid |
string |
firmware_update_progress_state
attempts |
integer |
code |
integer |
Code corresponding to the status message. |
message |
string |
Error message returned when a cluster firmware update job fails. |
status |
string |
worker_node |
job |
update_state |
update_type |
string |
Specifies the type of update. |
zip_file_name |
string |
firmware_disk
average_duration_per_disk |
integer |
Average firmware update duration per disk (in seconds). |
num_waiting_download |
integer |
The number of disks waiting to download the firmware update. |
total_completion_estimate |
integer |
Estimated firmware update duration to completion (in minutes). |
update_status |
Status of the background disk firmware update. |
firmware_dqp_record_count
alias |
integer |
Alias record count |
device |
integer |
Device record count |
drive |
integer |
Drive record count |
system |
integer |
System record count |
firmware_dqp
file_name |
string |
Firmware file name |
record_count |
revision |
string |
Firmware revision |
version |
string |
Firmware version |
firmware_shelf
in_progress_count |
integer |
update_status |
Status of the shelf firmware update. |
firmware_sp_bmc
autoupdate |
boolean |
end_time |
string |
fw_type |
string |
image |
string |
in_progress |
boolean |
is_current |
boolean |
last_update_state |
string |
percent_done |
integer |
running_version |
string |
start_time |
string |
state |
string |
firmware
cluster_fw_progress |
array[firmware_update_progress] |
disk |
dqp |
shelf |
sp_bmc |
software_images
package |
string |
Package file name. |
firmware |
name |
string |
Name of the node. |
software_images |
array[software_images] |
List of software image information. |
version |
string |
ONTAP version of the node.
action
message |
string |
Specifies the corrective action to take to resolve an error. |
issue
message |
string |
Details of the error or warning encountered by the update checks. |
software_validation_reference
action |
issue |
status |
string |
Status of the update check. |
update_check |
string |
Name of the update check. |
action
code |
integer |
Error code corresponding the status error |
message |
string |
Corrective action to be taken to resolve the status error. |
issue
code |
integer |
Error code corresponding to update status |
message |
string |
Update status details |
node
name |
string |
Name of the node to be retrieved for status details. |
software_status_details_reference
action |
end_time |
string |
End time for each status phase. |
issue |
name |
string |
Name of the phase to be retrieved for status details. |
node |
start_time |
string |
Start time for each status phase. |
state |
string |
Status of the phase |
node
name |
string |
Name of the node to be retrieved for update details. |
software_update_details_reference
elapsed_duration |
integer |
Elapsed duration for each update phase |
integer |
Estimated duration for each update phase |
node |
phase |
string |
Phase details |
state |
string |
State of the update phase |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
