REST API reference
Retrieve specific iSCSI credentials
GET /protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
Introduced In: 9.6
Retrieves specified iSCSI credentials.
  • vserver iscsi security show
svm.uuid
string
path
True
The unique identifier of an SVM.
initiator
string
path
True
The iSCSI initiator of the credentials object.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication_type
string
The iSCSI authentication type. Required in POST; optional in PATCH.
chap
chap
Challenge-Handshake Authentication Protocol (CHAP) credentials.
initiator
string
The iSCSI initiator to which the credentials apply. Required in POST.
initiator_address
initiator_address
Initiator address ranges.
svm
svm
      "href": "/api/resourcelink"
  "authentication_type": "string",
  "chap": {
    "inbound": {
      "user": "string"
    "outbound": {
      "user": "string"
  "initiator": "iqn.1998-01.com.corp.iscsi:name1",
  "initiator_address": {
    "masks": [
        "address": "10.10.10.7",
        "family": "string",
        "netmask": "24"
    "ranges": [
        "end": "10.10.10.7",
        "family": "string",
        "start": "10.10.10.7"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
inbound
Inbound CHAP credentials.
user
string
The inbound CHAP user name. Optional in POST and PATCH.
outbound
Output CHAP credentials.
To clear previously set outbound CHAP credentials, set property chap.outbound.user to an empty string in PATCH.
user
string
The outbound CHAP user name. Optional in POST and PATCH.
To clear previously set outbound CHAP credentials, set this property to an empty string in PATCH.
chap
inbound
inbound
outbound
outbound
ip_info
IP information
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
ip_address_range
IP address range
end
string
family
string
IPv4 or IPv6
start
string
initiator_address
masks
array[ip_info]
ranges
array[ip_address_range]
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
