REST API reference
Retrieve the remote syslog or splunk server information
GET /security/audit/destinations/{address}/{port}
Introduced In: 9.6
Defines a remote syslog/splunk server for sending audit information to.
address
string
path
True
IP address of remote syslog/splunk server.
port
integer
path
True
Port number of remote syslog/splunk server.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
address
string
Destination syslog|splunk host to forward audit records to. This can be an IP address (IPv4|IPv6) or a hostname.
facility
string
This is the standard Syslog Facility value that is used when sending audit records to a remote server.
hostname_format_override
string
Syslog Hostname Format Override
ipspace
ipspace
message_format
string
Syslog message format to be used. legacy_netapp format (variation of RFC-3164) is default message format.
port
integer
Destination Port. The default port depends on the protocol chosen: For un-encrypted destinations the default port is 514. For encrypted destinations the default port is 6514.
protocol
string
Log forwarding protocol
timestamp_format_override
string
Syslog Timestamp Format Override.
verify_server
boolean
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate.
  "address": "1.1.1.1",
  "facility": "string",
  "hostname_format_override": "string",
  "ipspace": {
        "href": "/api/resourcelink"
    "name": "Default",
  "message_format": "string",
  "port": 514,
  "protocol": "string",
  "timestamp_format_override": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
