REST API reference
Retrieve an OAuth 2.0 configuration with the specified name
Retrieves the OAuth 2.0 configuration for a specific name, helping you manage authentication settings efficiently.
HTTP method and endpoint
GET /security/authentication/cluster/oauth2/clients/{name}
Introduced in
ONTAP 9.14
Usage notes
Retrieves the OAuth 2.0 configuration with the specified name.
  • security oauth2 client show
name
string
path
True
OAuth 2.0 configuration name.
outgoing_proxy
string
query
False
Filter by outgoing_proxy
audience
string
query
False
Filter by audience
issuer
string
query
False
Filter by issuer
use_mutual_tls
string
query
False
Filter by use_mutual_tls
hashed_client_secret
string
query
False
Filter by hashed_client_secret
provider
string
query
False
Filter by provider
  • Introduced in: 9.16
remote_user_claim
string
query
False
Filter by remote_user_claim
application
string
query
False
Filter by application
use_local_roles_if_present
boolean
query
False
Filter by use_local_roles_if_present
jwks.provider_uri
string
query
False
Filter by jwks.provider_uri
jwks.refresh_interval
string
query
False
Filter by jwks.refresh_interval
client_id
string
query
False
Filter by client_id
introspection.endpoint_uri
string
query
False
Filter by introspection.endpoint_uri
introspection.interval
string
query
False
Filter by introspection.interval
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
application
string
The name of the application using OAuth 2.0. Required for POST operations.
audience
string
The OAuth 2.0 Audience.
client_id
string
The OAuth 2.0 client ID. Required in POST operations for remote introspection.
string
The OAuth 2.0 client secret as a SHA256 HMAC hashed value created with the cluster UUID as its HMAC secret key.
introspection
introspection
issuer
string
The OAuth 2.0 Issuer.
jwks
jwks
name
string
The configuration name. Required for POST operations.
outgoing_proxy
string
Outgoing proxy to access external identity providers (IdPs). If not specified, no proxy is configured.
provider
string
The Identity Provider type.
remote_user_claim
string
The remote user claim.
boolean
Indicates whether or not to use locally configured roles, if present. Default value is false.
use_mutual_tls
string
OAuth 2.0 mutual TLS authentication setting. Set this value to "none" to disable mutual TLS authentication. Set this value to "required" to enforce mutual TLS authentication for all access tokens and reject any token that does not have x5t#S256 property in the cnf section. The default value is "request" which means mutual TLS authentication is enforced only if the x5t#S256 property is present in the cnf section of the access token.
      "href": "/api/resourcelink"
  "application": "string",
  "audience": "string",
  "client_id": "string",
  "hashed_client_secret": "string",
  "introspection": {
    "endpoint_uri": "https://examplelab.customer.com/token/introspect",
    "interval": "PT1H"
  "issuer": "https://examplelab.customer.com",
  "jwks": {
    "provider_uri": "https://examplelab.customer.com/pf/JWKS",
    "refresh_interval": "PT2H"
  "name": "auth0",
  "outgoing_proxy": "https://johndoe:secretpass@proxy.example.com:8080",
  "provider": "entra",
  "remote_user_claim": "string",
  "skip_uri_validation": true,
  "use_mutual_tls": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
introspection
endpoint_uri
string
The token introspection endpoint URI.
interval
string
The refresh interval for caching tokens, in ISO-8601 format. This can be set to the value "disabled" to disable caching of tokens. When set to 0, tokens are cached according to the expiry period in them. Otherwise, it can be set to a value from 1 second to 2147483647 seconds.
jwks
provider_uri
string
The URI on which the JSON Web Key Set (JWKS) are hosted.
refresh_interval
string
The refresh interval for the JSON Web Key Set (JWKS), in ISO-8601 format. This can be set to a value from 300 seconds to 2147483647 seconds.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
