REST API reference
Retrieve key managers
Retrieves information about key managers, which can include specific details and configurations relevant to active setups.
HTTP method and endpoint
GET /security/key-managers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves key managers.
Examples:
  • To retrieve basic information about a key server:
  • To retrieve specific fields, including expensive properties:
GET /security/key-managers/{uuid}?fields=connectivity.cluster_availability,connectivity.node_states.node.name
Note:
These fields are not available for inactive configurations due to the additional computational cost and the relevance of these fields is exclusive to active configurations.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • connectivity.cluster_availability
  • connectivity.node_states.node.name
  • connectivity.node_states.node.uuid
  • connectivity.node_states.state
  • status.message
  • status.code
  • security key-manager show-key-store
  • security key-manager external show
  • security key-manager external show-status
  • security key-manager onboard show-backup
uuid
string
path
True
Key manager UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
configuration
configuration
Security keystore object reference.
enabled
boolean
Indicates whether the configuration is enabled.
external
external
Configures external key management
is_default_data_at_rest_encryption_disabled
boolean
Indicates whether default data-at-rest encryption is disabled in the cluster. This field is deprecated in ONTAP 9.8 and later. Use the "software_data_encryption.disabled_by_default" of /api/security endpoint.
  • Default value: 1
  • Introduced in: 9.7
  • x-ntap-readModify: true
  • x-nullable: true
onboard
onboard
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation.
policy
string
Security policy associated with the key manager. This value is currently ignored if specified for the onboard key manager.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
status
status
Optional status information on the current state of the key manager indicating if it is fully setup or requires more action.
svm
svm
uuid
string
volume_encryption
volume_encryption
Indicates whether volume encryption is supported in the cluster.
      "href": "/api/resourcelink"
  "configuration": {
    "name": "default",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
  "external": {
    "client_certificate": {
      "name": "string",
    "server_ca_certificates": [
        "name": "string",
    "servers": [
        "connectivity": {
          "node_states": [
              "node": {
                "name": "node1",
              "state": "not_responding"
        "secondary_key_servers": "secondary1.com, 10.2.3.4",
        "server": "keyserver1.com:5698",
        "timeout": 60,
        "username": "admin"
  "onboard": {
    "existing_passphrase": "The cluster password of length 32-256 ASCII characters.",
    "key_backup": "'--------------------------BEGIN BACKUP-------------------------- TmV0QXBwIEtleSBCbG9iAAEAAAAEAAAAcAEAAAAAAAAxBFWWAAAAACEAAAAAAAAA QAAAAAAAAABzDyyVAAAAALI5Jsjvy6gUxnT78KoDKXHYb6sSeraM00quOULY6BeV n6dMFxuErCD1lbERaOQZSuaYy1p8oQHtTEfGMLZM4TYiAAAAAAAAACgAAAAAAAAA 3WTh7gAAAAAAAAAAAAAAAAIAAAAAAAgAZJEIWvdeHr5RCAvHGclo+wAAAAAAAAAA IgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAAAAAAAAAAAAACAAAAAAAJAGr3tJA/LRzU QRHwv+1aWvAAAAAAAAAAACQAAAAAAAAAgAAAAAAAAADV1Vd/AAAAAMFM9Q229Bhp mDaTSdqku5DCd8wG+fOZSr4bx4JT5WHvV/r5gJnXDQQAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOZXRBcHAgS2V5IEJsb2IA AQAAAAMAAAAYAQAAAAAAALgePkcAAAAAIgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAA AAAAAAAAAAACAAAAAAAJAGr3tJA/LRzUQRHwv+1aWvAAAAAAAAAAACIAAAAAAAAA KAAAAAAAAACIlCHZAAAAAAAAAAAAAAAAAgAAAAAAAQCafcabsxRXMM7gxhLRrzxh AAAAAAAAAAAkAAAAAAAAAIAAAAAAAAAA2JjQBQAAAACt4IqXcNpVggahl0axLsN4 yQjnNVKWY7mANB29O42hI7b70DTGCTaVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAE5ldEFwcCBLZXkgQmxvYgABAAAAAwAAABgBAAAAAAAA 7sbaoQAAAAAiAAAAAAAAACgAAAAAAAAAQ5NxHQAAAAAAAAAAAAAAAAIAAAAAAAkA ave0kD8tHNRBEfC/7Vpa8AAAAAAAAAAAIgAAAAAAAAAoAAAAAAAAALOHfWkAAAAA AAAAAAAAAAACAAAAAAABAMoI9UxrHOGthQm/CB+EHdAAAAAAAAAAACQAAAAAAAAA gAAAAAAAAACnMmUtAAAAAGVk8AtPzENFgsGdsFvnmucmYrlQCsFew0HDSFKaZqK6 W8IEVzBAhPoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ---------------------------END BACKUP---------------------------'",
    "synchronize": true
  "policy": "string",
  "scope": "string",
  "status": {
    "code": 346758,
    "message": "This cluster is part of a MetroCluster configuration. Use the REST API POST method security/key_managers/ with the synchronize option and the same passphrase on the partner cluster before proceeding with any key manager operations.  Failure to do so could lead to switchover or switchback failure."
  "svm": {
    "name": "svm1",
  "uuid": "string",
  "volume_encryption": {
    "code": 346758,
    "message": "No platform support for volume encryption in following nodes - node1, node2."
Status: Default
ONTAP Error Response Codes
Error Code Description
65536894
This cluster is part of a MetroCluster configuration. Configure an external key manager on the partner cluster providing the same key servers before proceeding with any key manager operations.
65537201
There are no key servers configured for this SVM in the local cluster.
65537202
There are no key servers configured for this SVM in the remote cluster.
65537203
Internal error. Failed to check for key servers on partner cluster.
65537204
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
configuration
_links
_links
name
string
Name of the configuration.
uuid
string
Keystore UUID.
client_certificate
Client certificate (name and UUID)
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
Security certificate object reference
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
self
node
_links
_links
name
string
uuid
string
key_server_state
The connectivity state of the key server for a specific node.
node
node
state
string
Key server connectivity state
connectivity
This property contains the key server connectivity state of all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
boolean
Set to true when key server connectivity state is available on all nodes of the cluster.
node_states
array[key_server_state]
An array of key server connectivity states for each node.
key_server_readcreate
_links
self_link
connectivity
connectivity
string
A comma delimited string of the secondary key servers associated with the primary key server.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
Username credentials for connecting with the key server.
external
client_certificate
client_certificate
array[server_ca_certificates]
The array of certificates that are common for all the keyservers per SVM.
servers
array[key_server_readcreate]
The set of external key servers.
onboard
enabled
boolean
Is the onboard key manager enabled?
existing_passphrase
string
The cluster-wide passphrase. This is not audited.
key_backup
string
Backup of the onboard key manager's key hierarchy. It is required to save this backup after configuring the onboard key manager to help in the recovery of the cluster in case of catastrophic failures.
status
code
integer
Code corresponding to the status message. Returns 0 if the setup is complete. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
message
string
Current state of the key manager indicating any additional steps to perform to finish the setup. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
_links
_links
name
string
uuid
string
volume_encryption
code
integer
Code corresponding to the status message. Returns a 0 if volume encryption is supported in all nodes of the cluster.
message
string
Reason for not supporting volume encryption.
supported
boolean
Set to true when volume encryption support is available on all nodes of the cluster.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
