REST API reference
Retrieve LUNs
Retrieves logical unit numbers (LUNs) to access detailed information about your storage configuration and management. Use this endpoint to gather data essential for monitoring and optimizing storage resources within your environment.
HTTP method and endpoint
GET /storage/luns
Introduced in
ONTAP 9.6
Usage notes
Retrieves LUNs.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • attributes.*
  • auto_delete
  • copy.*
  • lun_maps.*
  • movement.*
  • space.physical_used
  • space.physical_used_by_snapshots
  • space.efficiency_ratio
  • statistics.*
  • vvol.bindings.*
  • metric.*
  • lun bind show
  • lun copy show
  • lun mapping show
  • lun move show
  • lun show
  • volume file clone show-autodelete
Learn more
class
string
query
False
Filter by class
location.qtree.name
string
query
False
Filter by location.qtree.name
location.qtree.id
integer
query
False
Filter by location.qtree.id
  • Max value: 4994
  • Min value: 0
location.logical_unit
string
query
False
Filter by location.logical_unit
location.node.uuid
string
query
False
Filter by location.node.uuid
  • Introduced in: 9.10
location.node.name
string
query
False
Filter by location.node.name
location.volume.uuid
string
query
False
Filter by location.volume.uuid
location.volume.name
string
query
False
Filter by location.volume.name
enabled
boolean
query
False
Filter by enabled
name
string
query
False
Filter by name
consistency_group.uuid
string
query
False
Filter by consistency_group.uuid
consistency_group.name
string
query
False
Filter by consistency_group.name
metric.latency.write
integer
query
False
Filter by metric.latency.write
  • Introduced in: 9.7
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.duration
string
query
False
Filter by metric.duration
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.other
integer
query
False
Filter by metric.throughput.other
metric.status
string
query
False
Filter by metric.status
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.iops.write
integer
query
False
Filter by metric.iops.write
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.iops.other
integer
query
False
Filter by metric.iops.other
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
os_type
string
query
False
Filter by os_type
auto_delete
boolean
query
False
Filter by auto_delete
attributes.name
string
query
False
Filter by attributes.name
  • maxLength: 4091
  • minLength: 1
attributes.value
string
query
False
Filter by attributes.value
  • maxLength: 4091
  • minLength: 1
uuid
string
query
False
Filter by uuid
status.read_only
boolean
query
False
Filter by status.read_only
status.mapped
boolean
query
False
Filter by status.mapped
status.state
string
query
False
Filter by status.state
status.container_state
string
query
False
Filter by status.container_state
integer
query
False
Filter by space.physical_used_by_snapshots
  • Introduced in: 9.16
number
query
False
Filter by space.efficiency_ratio
space.used
integer
query
False
Filter by space.used
space.size
integer
query
False
Filter by space.size
  • Max value: 140737488355328
  • Min value: 4096
space.scsi_thin_provisioning_support_enabled
boolean
query
False
Filter by space.scsi_thin_provisioning_support_enabled
space.guarantee.reserved
boolean
query
False
Filter by space.guarantee.reserved
space.guarantee.requested
boolean
query
False
Filter by space.guarantee.requested
space.physical_used
integer
query
False
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.other
integer
query
False
Filter by statistics.throughput_raw.other
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.status
string
query
False
Filter by statistics.status
vvol.is_bound
boolean
query
False
Filter by vvol.is_bound
vvol.bindings.partner.uuid
string
query
False
Filter by vvol.bindings.partner.uuid
vvol.bindings.partner.name
string
query
False
Filter by vvol.bindings.partner.name
vvol.bindings.id
integer
query
False
Filter by vvol.bindings.id
vvol.bindings.secondary_id
string
query
False
Filter by vvol.bindings.secondary_id
  • Introduced in: 9.13
create_time
string
query
False
Filter by create_time
movement.paths.destination
string
query
False
Filter by movement.paths.destination
movement.paths.source
string
query
False
Filter by movement.paths.source
movement.max_throughput
integer
query
False
Filter by movement.max_throughput
movement.progress.volume_snapshot_blocked
boolean
query
False
Filter by movement.progress.volume_snapshot_blocked
movement.progress.percent_complete
integer
query
False
Filter by movement.progress.percent_complete
  • Max value: 100
  • Min value: 0
movement.progress.failure.arguments.code
string
query
False
Filter by movement.progress.failure.arguments.code
movement.progress.failure.arguments.message
string
query
False
Filter by movement.progress.failure.arguments.message
movement.progress.failure.message
string
query
False
Filter by movement.progress.failure.message
movement.progress.failure.code
string
query
False
Filter by movement.progress.failure.code
movement.progress.state
string
query
False
Filter by movement.progress.state
movement.progress.elapsed
integer
query
False
Filter by movement.progress.elapsed
lun_maps.igroup.protocol
string
query
False
Filter by lun_maps.igroup.protocol
lun_maps.igroup.igroups.name
string
query
False
Filter by lun_maps.igroup.igroups.name
  • maxLength: 96
  • minLength: 1
lun_maps.igroup.igroups.uuid
string
query
False
Filter by lun_maps.igroup.igroups.uuid
lun_maps.igroup.uuid
string
query
False
Filter by lun_maps.igroup.uuid
lun_maps.igroup.os_type
string
query
False
Filter by lun_maps.igroup.os_type
lun_maps.igroup.initiators.comment
string
query
False
Filter by lun_maps.igroup.initiators.comment
  • maxLength: 254
  • minLength: 0
lun_maps.igroup.initiators.name
string
query
False
Filter by lun_maps.igroup.initiators.name
lun_maps.igroup.name
string
query
False
Filter by lun_maps.igroup.name
lun_maps.igroup.comment
string
query
False
Filter by lun_maps.igroup.comment
  • maxLength: 254
  • minLength: 0
lun_maps.logical_unit_number
integer
query
False
Filter by lun_maps.logical_unit_number
comment
string
query
False
Filter by comment
  • maxLength: 254
  • minLength: 0
serial_number
string
query
False
Filter by serial_number
  • maxLength: 12
  • minLength: 12
qos_policy.uuid
string
query
False
Filter by qos_policy.uuid
qos_policy.name
string
query
False
Filter by qos_policy.name
copy.source.peer.uuid
string
query
False
Filter by copy.source.peer.uuid
  • Introduced in: 9.14
copy.source.peer.name
string
query
False
Filter by copy.source.peer.name
copy.source.name
string
query
False
Filter by copy.source.name
copy.source.progress.failure.arguments.code
string
query
False
Filter by copy.source.progress.failure.arguments.code
copy.source.progress.failure.arguments.message
string
query
False
Filter by copy.source.progress.failure.arguments.message
copy.source.progress.failure.message
string
query
False
Filter by copy.source.progress.failure.message
copy.source.progress.failure.code
string
query
False
Filter by copy.source.progress.failure.code
copy.source.progress.state
string
query
False
Filter by copy.source.progress.state
copy.source.progress.elapsed
integer
query
False
Filter by copy.source.progress.elapsed
copy.source.progress.volume_snapshot_blocked
boolean
query
False
Filter by copy.source.progress.volume_snapshot_blocked
copy.source.progress.percent_complete
integer
query
False
Filter by copy.source.progress.percent_complete
  • Max value: 100
  • Min value: 0
copy.source.uuid
string
query
False
Filter by copy.source.uuid
copy.source.max_throughput
integer
query
False
Filter by copy.source.max_throughput
copy.destinations.uuid
string
query
False
Filter by copy.destinations.uuid
copy.destinations.max_throughput
integer
query
False
Filter by copy.destinations.max_throughput
copy.destinations.peer.uuid
string
query
False
Filter by copy.destinations.peer.uuid
copy.destinations.peer.name
string
query
False
Filter by copy.destinations.peer.name
copy.destinations.name
string
query
False
Filter by copy.destinations.name
copy.destinations.progress.percent_complete
integer
query
False
Filter by copy.destinations.progress.percent_complete
  • Max value: 100
  • Min value: 0
copy.destinations.progress.volume_snapshot_blocked
boolean
query
False
Filter by copy.destinations.progress.volume_snapshot_blocked
copy.destinations.progress.elapsed
integer
query
False
Filter by copy.destinations.progress.elapsed
copy.destinations.progress.state
string
query
False
Filter by copy.destinations.progress.state
copy.destinations.progress.failure.arguments.code
string
query
False
Filter by copy.destinations.progress.failure.arguments.code
copy.destinations.progress.failure.arguments.message
string
query
False
Filter by copy.destinations.progress.failure.arguments.message
copy.destinations.progress.failure.message
string
query
False
Filter by copy.destinations.progress.failure.message
copy.destinations.progress.failure.code
string
query
False
Filter by copy.destinations.progress.failure.code
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[lun]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "attributes": [
          "name": "name1",
          "value": "value1"
      "class": "string",
      "comment": "string",
      "consistency_group": {
        "name": "cg1",
        "uuid": "4abc2317-4332-9d37-93a0-20bd29c22df0"
      "copy": {
        "destinations": [
            "max_throughput": 0,
            "name": "/vol/vol1/lun1",
            "peer": {
              "name": "peer1",
              "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
            "progress": {
              "elapsed": 0,
              "failure": {
                "arguments": [
                    "code": "string",
                    "message": "string"
                "code": "4",
                "message": "entry doesn't exist"
              "percent_complete": 0,
              "state": "string"
            "uuid": "1bc327d5-4654-5284-a116-f182282240b4"
        "source": {
          "name": "/vol/vol2/lun1",
          "peer": {
            "name": "peer1",
          "progress": {
            "elapsed": 0,
            "failure": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
            "state": "string"
          "uuid": "03c05019-40d9-3945-c767-dca4c3be5e90"
      "create_time": "2018-06-04 15:00:00 -0400",
      "location": {
        "logical_unit": "lun1",
        "node": {
          "name": "node1",
        "qtree": {
          "id": 1,
          "name": "qt1"
        "volume": {
          "name": "volume1",
      "lun_maps": [
          "igroup": {
            "igroups": [
                "name": "igroup1",
            "initiators": [
                "comment": "my comment",
                "name": "iqn.1998-01.com.corp.iscsi:name1"
            "name": "igroup1",
            "os_type": "string",
            "protocol": "string",
      "metric": {
        "duration": "PT15S",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 06:20:13 -0500"
      "movement": {
        "paths": {
          "destination": "/vol/vol1/lun1",
          "source": "/vol/vol2/lun2"
        "progress": {
          "elapsed": 0,
          "failure": {
            "arguments": [
                "code": "string",
                "message": "string"
            "code": "4",
          "state": "string"
      "name": "/vol/volume1/qtree1/lun1",
      "qos_policy": {
        "name": "qos1",
      "serial_number": "string",
      "space": {
        "efficiency_ratio": 2.5,
        "physical_used": 1073741824,
        "physical_used_by_snapshots": 1073741824,
        "size": 1073741824,
        "used": 0
      "statistics": {
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "status": {
        "container_state": "string",
        "state": "online"
      "svm": {
        "name": "svm1",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "vvol": {
        "bindings": [
            "id": 1,
            "partner": {
            "secondary_id": "0000D20000010000h"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
attributes
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
Optional in POST.
_links
_links
name
string
The attribute name.
value
string
The attribute value.
source
The source LUN for a LUN clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST to create a new LUN as a clone of the source.
Valid in PATCH to overwrite an existing LUN's data as a clone of another.
clone
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: auto_delete, qos_policy, space.guarantee.requested and space.scsi_thin_provisioning_support_enabled.
When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: class, auto_delete, lun_maps, serial_number, status.state, and uuid.
Persistent reservations for the patched LUN are also preserved.
consistency_group
The LUN's consistency group. This property is populated for LUNs that are members of a consistency group. If the LUN is a member of a child consistency group, the parent consistency group is reported. A LUN's consistency group is the consistency group of its containing volume.
_links
_links
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
namespace
The source namespace for convert operation. This can be specified using property convert.namespace.uuid or convert.namespace.name. If both properties are supplied, they must refer to the same NVMe namespace.
Valid in POST. A convert request from NVMe namespace to LUN cannot be combined with setting any other LUN properties. All other properties of the converted LUN come from the source NVMe namespace.
convert
This sub-object is used in POST to convert a valid in-place NVMe namespace to a LUN. Setting a property in this sub-object indicates that a conversion from the specified NVMe namespace to LUN is desired.
peer
The SVM peer relationship object for an inter-SVM LUN copy operation. The peer SVM in the relationship is the source SVM and the local SVM is the destination SVM.
This is only populated by GET when the LUN copy is inter-SVM.
_links
_links
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
code
string
Argument code
message
string
Message argument
error
Error information provided if the asynchronous LUN copy operation fails.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
progress
Properties related to the progress of an active or recently completed LUN copy.
elapsed
integer
The amount of time that has elapsed since the start of the LUN copy, in seconds.
failure
error
percent_complete
integer
The percentage completed of the LUN copy.
state
string
The state of the LUN copy.
boolean
This property reports if volume snapshots are blocked by the LUN copy. This property can be polled to identify when volume snapshots can be resumed after beginning a LUN copy.
destinations
A LUN copy operation in which the containing LUN is the source of the copy.
_links
_links
max_throughput
integer
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN copy. See property copy.source.max_throughput for further details.
name
string
The fully qualified path of the LUN copy destination composed of a "/vol" prefix, the volume name, the optional qtree name, and base name of the LUN.
peer
peer
progress
progress
uuid
string
The unique identifier of the LUN copy destination.
peer
Set this in POST to specify the source SVM for an inter-SVM LUN copy. Only populated by GET when the LUN copy is inter-SVM.
_links
_links
name
string
uuid
string
progress
elapsed
integer
failure
error
percent_complete
integer
state
string
Valid in PATCH when an LUN copy is active. Set to paused to pause a LUN copy. Set to replicating to resume a paused LUN copy.
boolean
source
The source LUN of a LUN copy operation in which the containing LUN is the destination of the copy.
Valid in POST except when creating a LUN clone. A LUN copy request cannot be combined with setting any other LUN properties except the destination location. All other properties of the destination LUN come from the source LUN.
_links
_links
max_throughput
integer
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN copy. This property can be used to throttle a transfer and limit its impact on the performance of the source and destination nodes. The specified value will be rounded up to the nearest megabyte.
If this property is not specified in a POST that begins a LUN copy, throttling is not applied to the data transfer.
For more information, see Size properties in the docs section of the ONTAP REST API documentation.
Valid only in a POST that begins a LUN copy or a PATCH when a LUN copy is already in process.
  • format: int64
  • x-nullable: true
name
string
The fully qualified path of the LUN copy source composed of a "/vol" prefix, the volume name, the optional qtree name, and base name of the LUN.
Set this property in POST to specify the source for a LUN copy operation.
peer
peer
progress
progress
uuid
string
The unique identifier of the LUN copy source.
copy
This sub-object applies to LUN copy operations. A LUN can be copied with a POST request that supplies copy.source properties.
Copying a LUN is an asynchronous activity begun by a POST request that specifies the source of the copy in the copy.source properties. The data for the LUN is then asynchronously copied from the source to the destination. The time required to complete the copy depends on the size of the LUN and the load on the cluster. The copy sub-object is populated while a LUN copy is in progress and for two (2) minutes following completion of a copy.
While LUNs are being copied, the status of the LUN copy operations can be obtained using a GET of the source or destination LUN that requests the copy properties. If the LUN is the source LUN for one or more copy operations, the copy.destinations array is populated in GET. If the containing LUN is the destination LUN for a copy operation, the copy.source sub-object is populated in GET. The LUN copy operation can be further modified using a PATCH on the properties on the copy.source sub-object of the copy destination LUN.
There is an added computational cost to retrieving property values for copy. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
destinations
array[destinations]
An array of destination LUNs of LUN copy operations in which the containing LUN is the source of the copy.
source
source
node
The cluster node that hosts the LUN.
_links
_links
name
string
uuid
string
qtree
The qtree in which the LUN is optionally located. Valid in POST and PATCH.
If properties name and location.qtree.name and/or location.qtree.id are specified in the same request, they must refer to the same qtree.
A PATCH that modifies the qtree of the LUN is considered a rename operation.
_links
_links
id
integer
The identifier for the qtree, unique within the qtree's volume.
name
string
The name of the qtree.
volume
The volume in which the LUN is located. Valid in POST and PATCH.
If properties name and location.volume.name and/or location.volume.uuid are specified in the same request, they must refer to the same volume.
A PATCH that modifies the volume of the LUN begins an asynchronous LUN movement operation.
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
location
The location of the LUN within the ONTAP cluster. LUNs support rename and move between volumes. Valid in POST and PATCH.
logical_unit
string
The base name component of the LUN. Valid in POST and PATCH.
If properties name and location.logical_unit are specified in the same request, they must refer to the base name.
A PATCH that modifies the base name of the LUN is considered a rename operation.
node
node
qtree
qtree
volume
volume
self
igroups
_links
self_link
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiators
The initiators that are members of the initiator group.
comment
string
A comment available for use by the administrator.
name
string
Name of initiator that is a member of the initiator group.
igroup
The initiator group to which the LUN is mapped.
_links
_links
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
igroups
array[igroups]
The existing initiator groups that are members of the group. Optional in POST.
This property is mutually exclusive with the initiators property during POST.
This array contains only the direct children of the initiator group. If the member initiator groups have further nested initiator groups, those are reported in the igroups property of the child initiator group.
Zero or more nested initiator groups can be supplied when the initiator group is created. The initiator group will act as if it contains the aggregation of all initiators in any nested initiator groups.
After creation, nested initiator groups can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/igroups endpoint. See POST /protocols/san/igroups/{igroup.uuid}/igroups and DELETE /protocols/san/igroups/{igroup.uuid}/igroups/{uuid} for more details.
initiators
array[initiators]
The initiators that are members of the group.
name
string
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed.
The protocol of an initiator group cannot be changed after creation of the group.
uuid
string
lun_maps
A LUN map is an association between a LUN and an initiator group.
When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
_links
_links
igroup
igroup
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through the Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value. This property is not supported when the provisioning_options.count property is 2 or more.
  • readCreate: 1
  • x-nullable: true
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
paths
The fully qualified LUN path names involved in the LUN movement.
destination
string
The fully qualified path of the LUN movement destination composed of a "/vol" prefix, the volume name, the optional qtree name, and base name of the LUN.
source
string
The fully qualified path of the LUN movement source composed of a "/vol" prefix, the volume name, the optional qtree name, and base name of the LUN.
error
Error information provided if the asynchronous LUN movement operation fails.
arguments
Message arguments
code
string
Error code
message
string
Error message
progress
Properties related to the progress of an active or recently completed LUN movement.
elapsed
integer
The amount of time that has elapsed since the start of the LUN movement, in seconds.
failure
error
percent_complete
integer
The percentage completed of the LUN movement.
state
string
The state of the LUN movement.
Valid in PATCH when an LUN movement is active. Set to paused to pause a LUN movement. Set to replicating to resume a paused LUN movement.
boolean
This property reports if volume snapshots are blocked by the LUN movement. This property can be polled to identify when volume snapshots can be resumed after beginning a LUN movement.
movement
This sub-object applies to LUN movement between volumes. A LUN can be moved to a new volume with a PATCH request that changes either the volume portion of property name, location.volume.uuid, or location.volume.name. If the volume is changed using more than one of these properties, the supplied properties used must refer to the same volume.
Moving a LUN between volumes is an asynchronous activity begun by a PATCH request. The data for the LUN is then asynchronously copied from the source volume to the destination volume. The time required to complete the move depends on the size of the LUN and the load on the cluster. The movement sub-object is populated while a LUN movement is in progress and for two (2) minutes following completion of a movement.
While the LUN is being moved, the status of the LUN movement operation can be obtained using a GET for the LUN that requests the movement properties. The LUN movement operation can be further modified using a PATCH on the properties on the movement sub-object.
There is an added computational cost to retrieving property values for movement. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
max_throughput
integer
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN movement. This property can be used to throttle a transfer and limit its impact on the performance of the source and destination nodes. The specified value will be rounded up to the nearest megabyte.
If this property is not specified in a POST that begins a LUN movement, throttling is not applied to the data transfer.
This property is valid only in a POST that begins a LUN movement or a PATCH when a LUN movement is already in process.
  • format: int64
  • x-nullable: true
paths
paths
progress
progress
qos_policy
The QoS policy for the volume provisioned to host the LUN. This property is only supported when the request provisions a new volume. This property is mutually exclusive with the LUN granular qos_policy. If no qos_policy is provided at LUN or volume granularity, a volume granular policy is set based on the storage_service.name, which defaults to the most performant service available.
_links
self_link
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
snapshot_policy_reference
This is a reference to the snapshot policy.
_links
_links
name
string
uuid
string
storage_service
Determines the placement of the LUN based on the value specified. This property is only supported for regular and vvol LUNs. Valid in POST.
object_stores
tiering
The tiering placement and policy definitions for the volume provisioned to host the LUN. This property is only supported when the request provisions a new volume.
object_stores
array[object_stores]
Object stores to use. Used for placement.
policy
string
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold.
FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH.
all ‐ Allows tiering of both snapshots and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks.
auto ‐ Allows tiering of both snapshot and active file system user data to the cloud store
none ‐ Volume blocks are not be tiered to the cloud store.
snapshot_only ‐ Allows tiering of only the volume snapshots not associated with the active file system.
The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy it is 31 days.
Options that are applied to the operation.
storage_service
storage_service
qos_policy
The QoS policy for the LUN. Both traditional and adaptive QoS policies are supported. If both property qos_policy.uuid and qos_policy.name are specified in the same request, they must refer to the same QoS policy. To remove the QoS policy from a LUN, leaving it with no QoS policy, set the property qos_policy.name to an empty string ("") in a PATCH request. Valid in POST and PATCH.
_links
_links
name
string
The name of the QoS policy. To remove the QoS policy from a LUN, leaving it with no QoS policy, set this property to an empty string ("") in a PATCH request. Valid in POST and PATCH.
uuid
string
The unique identifier of the QoS policy. Valid in POST and PATCH.
guarantee
Properties that request and report the space guarantee for the LUN.
requested
boolean
The requested space reservation policy for the LUN. If true, a space reservation is requested for the LUN; if false, the LUN is thin provisioned. Guaranteeing a space reservation request for a LUN requires that the volume in which the LUN resides is also space reserved and that the fractional reserve for the volume is 100%. Valid in POST and PATCH. This property is caller settable as described above.
reserved
boolean
Reports if the LUN is space guaranteed.
If true, a space guarantee is requested and the containing volume and aggregate support the request. If false, a space guarantee is not requested or a space guarantee is requested and either the containing volume or aggregate do not support the request.
space
The storage space related properties of the LUN.
efficiency_ratio
number
The storage efficiency ratio of the LUN without snapshots. (Logical Used / Used) This property is not available on the LUN object in the REST API and is not reported for GET requests. See the containing volume object for this information.
guarantee
guarantee
physical_used
integer
The number of bytes consumed on the disk by the LUN, excluding snapshots. This property is not available on the LUN object in the REST API and is not reported for GET requests. See the containing volume object for this information.
integer
The number of bytes consumed on the disk by the LUN's snapshots. This property is not available on the LUN object in the REST API and is not reported for GET requests. See the containing volume object for this information.
boolean
To leverage the benefits of SCSI thin provisioning, it must be supported by your host. SCSI thin provisioning uses the Logical Block Provisioning feature as defined in the SCSI SBC-3 standard. Only hosts that support this standard can use SCSI thin provisioning in ONTAP.
When you disable SCSI thin provisioning support in ONTAP, you turn off the following SCSI thin provisioning features:
  • Unmapping and reporting space usage for space reclamation
  • Reporting resource exhaustion errors
The value of this property is not propagated to the destination when a LUN is cloned as a new LUN or copied; it is reset to false. The value of this property is maintained from the destination LUN when a LUN is overwritten as a clone.
  • Default value: 1
  • x-nullable: true
size
integer
The total provisioned size of the LUN. The LUN size can be increased but not decreased using the REST interface.
The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The actual minimum and maximum sizes vary depending on the ONTAP version, ONTAP platform and the available space in the containing volume and aggregate.
  • example: 1073741824
  • format: int64
  • Min value: 4096
  • x-nullable: true
used
integer
The amount of space consumed by the main data stream of the LUN.
This value is the total space consumed in the volume by the LUN, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways SAN filesystems and applications utilize blocks within a LUN, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the LUN blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
  • x-nullable: true
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
status
Status information about the LUN.
container_state
string
The state of the volume and aggregate that contain the LUN. LUNs are only available when their containers are available.
mapped
boolean
Reports if the LUN is mapped to one or more initiator groups.
There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
read_only
boolean
Reports if the LUN allows only read access.
state
string
The state of the LUN. Normal states for a LUN are online and offline. Other states indicate errors.
svm
The SVM in which the LUN is located.
_links
_links
name
string
uuid
string
partner
The LUN partner that this LUN is bound to. If this LUN is a vvol class LUN, the partner is a protocol_endpoint class LUN.
_links
_links
name
string
The name of the partner LUN.
uuid
string
The unique identifier of the partner LUN.
bindings
A vVol binding with which the LUN is associated.
_links
_links
id
integer
The ONTAP internal identifier assigned to the vVol binding. The bind identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
This property was included in early releases of the REST API for vVols and is maintained for backward compatibility. See the secondary_id property, which replaces id.
  • example: 1
  • readOnly: 1
  • x-ntap-deprecated: 9.13.1
  • x-nullable: true
partner
partner
secondary_id
string
The identifier assigned to the vVol binding, known as the secondary LUN ID. The identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
The format for a secondary LUN ID is 16 hexadecimal digits (zero-filled) followed by a lower case "h".
vvol
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
See POST /protocols/san/vvol-bindings to learn more about creating vVol bindings and DELETE /protocols/san/vvol-bindings to learn more about deleting vVol bindings.
There is an added computational cost to retrieving property values for vvol. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
bindings
array[bindings]
Bindings between the LUN, which must be of class protocol_endpoint or vvol, and LUNs of the opposite class.
A class vvol LUN must be bound to a class protocol_endpoint LUN in order to be accessed. Class protocol_endpoint and vvol LUNs allow many-to-many bindings. A LUN of one class is allowed to be bound to zero or more LUNs of the opposite class. The binding between any two specific LUNs is reference counted. When a binding is created that already exists, the binding count is incremented. When a binding is deleted, the binding count is decremented, but the LUNs remain bound if the resultant reference count is greater than zero. When the binding count reaches zero, the binding is destroyed.
The bindings array contains LUNs of the opposite class of the containing LUN object.
There is an added computational cost to retrieving property values for vvol.bindings. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
is_bound
boolean
Reports if the LUN is part of a VMware virtual volume (vVol) bind relationship. This is true if the LUN is of class protocol_endpoint or vvol and has one or more bindings to a LUN of the opposite class. This is false if the LUN is of class regular or unbound.
lun
A LUN is the logical representation of storage in a storage area network (SAN).
A LUN must be mapped to an initiator group to grant access to the initiator group's initiators (client hosts). Initiators can then access the LUN and perform I/O over a Fibre Channel (FC) fabric using the FC Protocol or a TCP/IP network using iSCSI.
See the LUN object model to learn more about each of the properties supported by the LUN REST API.
A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<lun>" where the qtree name is optional.
A LUN can be created to a specified size using thin or thick provisioning. A LUN can then be renamed, resized, cloned, moved to a different volume and copied. LUNs support the assignment of a QoS policy for performance management or a QoS policy can be assigned to a volume containing one or more LUNs.
_links
_links
attributes
array[attributes]
An array of name/value pairs optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Valid in POST except when creating a LUN clone. A cloned can already have attributes from its source. You can add, modify, and delete the attributes of a LUN clone in separate requests after creation of the LUN.
Attributes can be added/modified/removed for an existing LUN using the /api/storage/luns/{lun.uuid}/attributes endpoint. For further information, see DOC /storage/luns/{lun.uuid}/attributes .
There is an added computational cost to retrieving property values for attributes. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • readCreate: 1
auto_delete
boolean
This property marks the LUN for auto deletion when the volume containing the LUN runs out of space. This is most commonly set on LUN clones.
When set to true, the LUN becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the LUN is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new LUN is false.
class
string
The class of LUN.
Optional in POST.
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
consistency_group
consistency_group
copy
copy
create_time
string
The time the LUN was created.
enabled
boolean
The enabled state of the LUN. LUNs can be disabled to prevent access to the LUN. Certain error conditions also cause the LUN to become disabled. If the LUN is disabled, check the status.state property to determine if the LUN is administratively disabled (offline) or has become disabled as a result of an error. A LUN in an error condition can be brought online by setting the enabled property to true or brought administratively offline by setting the enabled property to false. Upon creation, a LUN is enabled by default. Valid in PATCH.
location
location
lun_maps
array[lun_maps]
The LUN maps with which the LUN is associated.
There is an added computational cost to retrieving property values for lun_maps. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more. These properties are supported for GET only.
metric
metric
movement
movement
name
string
The name of the LUN. Valid in POST and PATCH.
A PATCH that modifies the qtree and/or base name portion of the LUN path is considered a rename operation.
A PATCH that modifies the volume portion of the LUN path begins an asynchronous LUN movement operation.
os_type
string
The operating system type of the LUN.
Required in POST when creating a LUN that is not a clone of another. Disallowed in POST when creating a LUN clone.
qos_policy
qos_policy
serial_number
string
The LUN serial number. The serial number is generated by ONTAP when the LUN is created.
  • maxLength: 12
  • minLength: 12
  • readOnly: 1
  • x-nullable: true
space
space
statistics
statistics
status
status
svm
svm
uuid
string
The unique identifier of the LUN. The UUID is generated by ONTAP when the LUN is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
  • x-nullable: true
vvol
vvol
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
