List clients with the most I/O activity
Retrieves a list of clients with the most I/O activity. This helps you identify which clients are generating the highest input/output operations in your environment.
HTTP method and endpoint
GET /svm/svms/{svm.uuid}/top-metrics/clients
Introduced in
ONTAP 9.11
svm.uuid |
string |
path |
True |
SVM UUID |
top_metric |
string |
query |
False |
I/O activity type
svm.name |
string |
query |
False |
Filter by svm.name |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
throughput.error.upper_bound |
integer |
query |
False |
Filter by throughput.error.upper_bound |
throughput.error.lower_bound |
integer |
query |
False |
Filter by throughput.error.lower_bound |
iops.write |
integer |
query |
False |
Filter by iops.write |
iops.read |
integer |
query |
False |
Filter by iops.read |
iops.error.upper_bound |
integer |
query |
False |
Filter by iops.error.upper_bound |
iops.error.lower_bound |
integer |
query |
False |
Filter by iops.error.lower_bound |
client_ip |
string |
query |
False |
Filter by client_ip |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
excluded_volumes |
List of volumes that are not included in the SVM activity tracking REST API. |
notice |
Optional field that indicates why no records are returned by the SVM activity tracking REST API. |
num_records |
integer |
Number of records. |
records |
array[top_metrics_svm_client] |
"next": {
"href": "/api/resourcelink"
"excluded_volumes": [
"reason": {
"code": "111411207",
"message": "The volume is offline."
"volume": {
"name": "volume1",
"notice": {
"num_records": 1,
"records": [
"client_ip": "192.168.185.170",
"iops": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 5,
"write": 10
"svm": {
"name": "svm1",
"throughput": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 12,
"write": 2
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
124519405 |
The activity tracking report for SVM svm.name returned zero records. Check whether the activity tracking enabled volumes belonging to the SVM have read/write traffic. Refer to the REST API documentation for more information on why there might be no records. |
124519406 |
Failed to get the activity tracking report for SVM svm.name. Reason: |
124519407 |
SVM wildcard queries are not supported for activity tracking reports. |
124519408 |
Activity tracking is not supported on SVM svm.name, because it is configured as a destination for SVM DR. |
124519409 |
Activity tracking is not supported on SVM svm.name, because it is configured as a destination of a MetroCluster SVM relationship and the SVM admin state is stopped. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
reason
code |
string |
Warning code indicating why the volume is not included in the SVM activity tracking REST API. |
message |
string |
Details why the volume is not included in the SVM activity tracking REST API. |
_links
self |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
top_metrics_svm_client_excluded_volume
List of volumes and their details as to why they are not included in the SVM activity tracking REST API.
reason |
volume |
notice
code |
string |
Warning code indicating why no records are returned. |
message |
string |
Details why no records are returned. |
top_metric_value_error_bounds
lower_bound |
integer |
Lower bound of the nominal value of a metric. |
upper_bound |
integer |
Upper bound of the nominal value of a metric. |
iops
error |
read |
integer |
Average number of read operations per second. |
write |
integer |
Average number of write operations per second. |
svm
_links |
name |
string |
uuid |
string |
throughput
error |
read |
integer |
Average number of read bytes received per second. |
write |
integer |
Average number of write bytes received per second. |
Aggregated information about a client's IO activity at a SVM scope.
client_ip |
string |
IP address of the client. Both IPv4 and IPv6 IP addresses are supported. |
iops |
svm |
throughput |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
