Manage global cache settings
Retrieve and manage global nameservice cache settings using these endpoints. Access and update cache configuration to optimize performance in your ONTAP environment.
Overview
This API is used to retrieve and manage global nameservice cache settings.
Retrieving a global nameservice cache setting
The following example shows how to use the cache setting GET endpoint to retrieve the global nameservice cache setting.
# The API:
GET /api/name-services/cache/setting
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/setting" -H "accept: application/hal+json"
# The response:
"eviction_time_interval": "P2D",
"remote_fetch_enabled": true
Updating a global nameservice cache setting
The following example shows how to use the cache setting PATCH endpoint to update the global nameservice cache setting.
# The API:
PATCH /api/name-services/cache/setting
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/setting" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"eviction_time_interval\": \"PT2H\" }"
