Manage network IP routes
Manage network IP routes to configure and maintain routing paths within your ONTAP cluster. Use these endpoints for operations like retrieving, creating, and deleting routes, ensuring efficient network communication and resource access.
Overview
This endpoint supports the following operations: GET (collection and instance), POST, and DELETE.
Retrieving network routes
You can use the IP routes GET API to retrieve and display relevant information pertaining to the routes configured in the cluster. The API retrieves the list of all routes configured in the cluster, or a specific route. The fields that are returned in the response will differ with the configuration.
Retrieving all routes in the cluster
The following output shows the list of all routes configured in a cluster.
# The API:
/api/network/ip/routes
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/routes?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"uuid": "5fdffb0b-62f8-11e8-853d-005056b4c971",
"ipspace": {
"uuid": "84f4beb2-616c-11e8-a4df-005056b4c971",
"name": "Default",
"href": "/api/network/ipspaces/84f4beb2-616c-11e8-a4df-005056b4c971"
"svm": {
"uuid": "3243312c-62f8-11e8-853d-005056b4c971",
"name": "vs1",
"href": "/api/svm/svms/3243312c-62f8-11e8-853d-005056b4c971"
"scope": "svm",
"destination": {
"address": "10.4.3.14",
"netmask": "18",
"family": "ipv4"
"gateway": "10.4.3.1",
"href": "/api/network/ip/routes/5fdffb0b-62f8-11e8-853d-005056b4c971"
"uuid": "84c128d2-62f9-11e8-853d-005056b4c971",
"ipspace": {
"uuid": "cc71aadc-62f7-11e8-853d-005056b4c971",
"name": "ips1",
"href": "/api/network/ipspaces/cc71aadc-62f7-11e8-853d-005056b4c971"
"scope": "cluster",
"destination": {
"address": "::",
"netmask": "0",
"family": "ipv6"
"gateway": "fd20:8b1e:b255:814e::1",
"href": "/api/network/ip/routes/84c128d2-62f9-11e8-853d-005056b4c971"
"uuid": "8cc72bcd-616c-11e8-a4df-005056b4c971",
"ipspace": {
"name": "Default",
"scope": "cluster",
"destination": {
"address": "0.0.0.0",
"netmask": "0",
"family": "ipv4"
"gateway": "10.224.64.1",
"href": "/api/network/ip/routes/8cc72bcd-616c-11e8-a4df-005056b4c971"
"uuid": "d63b6eee-62f9-11e8-853d-005056b4c971",
"ipspace": {
"name": "Default",
"svm": {
"name": "vs1",
"scope": "svm",
"destination": {
"address": "fd20:8b1e:b255:814e::",
"netmask": "64",
"family": "ipv6"
"href": "/api/network/ip/routes/d63b6eee-62f9-11e8-853d-005056b4c971"
"num_records": 4,
"href": "/api/network/ip/routes?fields=*"
Retrieving a specific Cluster-scoped route
The following output shows the returned response when a specific Cluster-scoped route is requested. The system returns an error if there is no route with the requested UUID. SVM information is not returned for Cluster-scoped routes.
# The API:
/api/network/ip/routes/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/routes/84c128d2-62f9-11e8-853d-005056b4c971?fields=*" -H "accept: application/hal+json"
# The response:
"ipspace": {
"name": "ips1",
"scope": "cluster",
"destination": {
"address": "::",
"netmask": "0",
"family": "ipv6"
Retrieving a specific SVM-scoped route
The following output shows the returned response when a specific SVM-scoped route is requested. The system returns an error if there is no route with the requested UUID. The SVM object is only included for SVM-scoped routes.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/routes/d63b6eee-62f9-11e8-853d-005056b4c971?fields=*" -H "accept: application/hal+json"
# The response:
"ipspace": {
"name": "Default",
"svm": {
"name": "vs1",
"scope": "svm",
"destination": {
"netmask": "64",
"family": "ipv6"
Creating network routes
You can use the POST API to create an SVM-scoped route by specifying the associated SVM, or a Cluster-scoped route by specifying the associated IPspace.
Creating a Cluster-scoped route
IPspace is required to create a Cluster-scoped route. If the IPspace is not specified, the route will be created in the Default IPspace. The default destination will be set to "0.0.0.0/0" for IPv4 gateway addresses or "::/0" for IPv6 gateway addresses.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/network/ip/routes?return_records=true" -H "accept: application/json" -d '{ "ipspace": { "name":"ips1" }, "gateway": "10.10.10.1"}'
# The response:
"num_records": 1,
"records": [
"uuid": "ae583c9e-9ac7-11e8-8bc9-005056bbd531",
"ipspace": {
"name": "ips1"
Creating an SVM-scoped route
To create an SVM-scoped route, the associated SVM can be identified by either its UUID or name.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/network/ip/routes?return_records=true" -H "accept: application/json" -d '{ "svm": { "name":"vs0" }, "gateway": "10.10.10.1"}'
# The response:
"num_records": 1,
"records": [
"uuid": "38805a91-9ac9-11e8-8bc9-005056bbd531",
"svm": {
"name": "vs0"
Deleting network routes
You can use the DELETE API to delete a specific route identified by its UUID.
Example
Deleting a specific route
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/network/ip/routes/38805a91-9ac9-11e8-8bc9-005056bbd531"
