Manage role privilege path
Use these endpoints to manage role privilege paths, including retrieving, modifying, or deleting access levels for REST API paths or command paths within a role. This functionality is essential for customizing access control in your ONTAP environment.
Overview
A role can comprise of multiple tuples and each tuple consists of a REST API path or command/command directory path and its access level. If the tuple refers to a command/command directory path, it may optionally be associated with a query. These APIs can be used to retrieve or modify the associated access level and optional query. They can also be used to delete one of the constituent REST API paths or command/command directory paths within a role. The REST API path can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
Ontap S3 APIs
– /api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
The role can be SVM-scoped or cluster-scoped.
Specify the owner UUID and the role name in the URI path. The owner UUID corresponds to the UUID of the SVM for which the role has been created and can be obtained from the response body of a GET request performed on one of the following APIs:
/api/security/roles for all roles
/api/security/roles/?scope=svm for SVM-scoped roles
/api/security/roles/?owner.name=
The access level for paths in pre-defined roles cannot be updated. |
Updating the access level for a REST API path in the privilege tuple of an existing role
# The API:
PATCH "/api/security/roles/{owner.uuid}/{name}/privileges/{path}"
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fprotocols" -d '{"access":"all"}'
Updating the access level for a command/command directory path in the privilege tuple of an existing role
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/netp%20port" -d '{"access":"readonly","query":"-type if-group|vlan"}'
Updating the access level for a resource-qualified endpoint in the privilege tuple of an existing role
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fstorage%2Fvolumes%2F742ef001-24f0-4d5a-9ec1-2fdaadb282f4%2Ffiles" -d '{"access":"readonly"}'
Retrieving the access level for a REST API path in the privilege tuple of an existing role
# The API:
GET "/api/security/roles/{owner.uuid}/{name}/privileges/{path}"
# The call:
curl -X GET "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fprotocols"
# The response:
"owner": {
"uuid": "aaef7c38-4bd3-11e9-b238-0050568e2e25"
"name": "svm_role1",
"path": "/api/protocols",
"access": "all",
"href": "/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fprotocols"
Retrieving the access level for a command/command directory path in the privilege tuple of an existing role
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/net%20port"
# The response:
"owner": {
"path": "net port",
"query":"-type if-group|vlan",
"access": "readonly",
"href": "/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/net%20port"
Retrieving the access level for a resource-qualified endpoint in the privilege tuple of an existing role
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fstorage%2Fvolumes%2Fd0f3b91a-4ce7-4de4-afb9-7eda668659dd%2F%2Fsnapshots"
# The response:
"owner": {
"path": "/api/storage/volumes/d0f3b91a-4ce7-4de4-afb9-7eda668659dd/snapshots",
"access": "all",
"href": "/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fstorage%2Fvolumes%2Fd0f3b91a-4ce7-4de4-afb9-7eda668659dd%2Fsnapshots"
Deleting a privilege tuple, containing a REST API path, from an existing role
# The API:
DELETE "/api/security/roles/{owner.uuid}/{name}/privileges/{path}"
# The call:
curl -X DELETE "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fprotocols"
Deleting a privilege tuple, containing a command/command directory path, from an existing role
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/net%20port"
Deleting a privilege tuple, containing a resource-qualified endpoint, from an existing role
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fstorage%2Fsvm%2F6e000659-9a16-11ec-819e-005056bb1a7c%2Ftop-metrics%2Ffiles"
