REST API reference
Manage SAN vVol bindings
Manage SAN vVol bindings to create, delete, and discover associations between VMware virtual volumes and protocol endpoint LUNs. These operations facilitate access to vVol LUNs through existing protocol endpoint mappings, supporting many-to-many bindings and reference-counted associations.
Overview
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
Class protocol_endpoint and vvol LUNs support many-to-many vVol bindings. A LUN of one class can be bound to zero or more LUNs of the opposite class.
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
The vVol binding REST API allows you to create, delete, and discover vVol bindings.
Creating a vVol binding
# The API:
POST /api/protocols/san/vvol-bindings
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/san/vvol-bindings' -H 'Accept: application/hal+json' -d '{ "svm": { "name": "svm1" }, "protocol_endpoint": { "name": "/vol/vol1/pe1" }, "vvol" : { "name": "/vol/vol1/vvol1" } }'
Retrieving all vVol bindings
# The API:
GET /api/protocols/san/vvol-bindings
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/vvol-bindings' -H 'Accept: application/hal+json'
# The response:
"records": [
      "uuid": "2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4",
      "name": "/vol/vol1/pe1",
          "href": "/api/storage/luns/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4"
    "vvol": {
      "uuid": "28c02623-42fa-4f5f-a984-a02044bfc005",
      "name": "/vol/vol1/vvol1",
          "href": "/api/storage/luns/28c02623-42fa-4f5f-a984-a02044bfc005"
        "href": "/api/protocols/san/vvol-bindings/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4/28c02623-42fa-4f5f-a984-a02044bfc005"
    "vvol": {
      "uuid": "a8d4ba93-918f-40ad-a1e4-4d7b244bdcdf",
      "name": "/vol/vol1/vvol2",
          "href": "/api/storage/luns/a8d4ba93-918f-40ad-a1e4-4d7b244bdcdf"
        "href": "/api/protocols/san/vvol-bindings/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4/a8d4ba93-918f-40ad-a1e4-4d7b244bdcdf"
"num_records": 2,
    "href": "/api/protocols/san/vvol-bindings"
Retrieving a specific vVol binding
# The API:
GET /api/protocols/san/vvol-bindings/{protocol_endpoint.uuid}/{vvol.uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/vvol-bindings/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4/28c02623-42fa-4f5f-a984-a02044bfc005' -H 'Accept: application/hal+json'
# The response:
"vvol": {
"svm": {
  "uuid": "bf295ccc-a6bb-11eb-93e8-005056bb470f",
  "name": "svm1",
      "href": "/api/svm/svms/bf295ccc-a6bb-11eb-93e8-005056bb470f"
"id": 2411392,
"is_optimal": true,
"count": 1,
Deleting a vVol binding
# The API:
DELETE /api/protocols/san/vvol-bindings/{protocol_endpoint.uuid}/{vvol.uuid}
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/protocols/san/vvol-bindings/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4/28c02623-42fa-4f5f-a984-a02044bfc005' -H 'Accept: application/hal+json'
