REST API reference
Manage SSH security configuration
Retrieve or modify the SSH security configuration for a data SVM using these endpoints. Adjust key exchange algorithms, ciphers, MAC algorithms, host key algorithms, and authentication retry settings to secure SVM connections.
Overview
This endpoint is used to retrieve or modify the SSH security configuration of a data SVM.
The SSH security algorithms include key exchange algorithms, ciphers for payload encryption, MAC algorithms, host key algorithms and the maximum authentication retry attempts allowed before closing the connection. svm.uuid corresponds to the UUID of the SVM for which the SSH security setting is being retrieved or modified and it is obtained from the response body of a GET operation performed on the api/security/ssh/svms API.
Updating the SSH security parameters
Specify the algorithms in the body of the PATCH request.
# The API:
PATCH "/api/security/ssh/svms/{svm.uuid}"
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/ssh/svms/02c9e252-41be-11e9-81d5-00a0986138f7" -d '{ "ciphers": [ "aes256_ctr", "aes192_ctr" ], "key_exchange_algorithms": [ "diffie_hellman_group_exchange_sha256", "ecdh_sha2_nistp256", "diffie_hellman_group16_sha512" ], "mac_algorithms": [ "hmac_sha2_512_etm", "umac_128_etm" ], "host_key_algorithms": [ "ecdsa_sha2_nistp256", "ssh_ed25519" ],"is_rsa_in_publickey_algorithms_enabled": false, "max_authentication_retry_count": 3 }'
Retrieving the SSH security configuration of an SVM.
# The API:
GET "/api/security/ssh/svms/{svm.uuid}"
# The call:
curl -X GET "https://<mgmt-ip>/api/security/ssh/svms/02c9e252-41be-11e9-81d5-00a0986138f7"
# The response:
"ciphers": [
  "aes256_ctr",
  "aes192_ctr"
"mac_algorithms": [
  "umac_128_etm"
  "ssh_ed25519"
"max_authentication_retry_count": 3,
"svm": {
  "name": "svm1",
  "uuid": "02c9e252-41be-11e9-81d5-00a0986138f7",
      "href": "/api/svm/svms/02c9e252-41be-11e9-81d5-00a0986138f7"
    "href": "/api/security/ssh/svms/02c9e252-41be-11e9-81d5-00a0986138f7"
