REST API reference
Manage storage tape devices
Access tape device endpoints to retrieve information about storage tapes in the cluster. Use these endpoints to manage tape devices by setting their online status, assigning aliases, or adjusting their position.
Retrieving storage tape information
The storage tape GET API retrieves all of the tapes in the cluster.
1) Retrieving a list of tapes from the cluster
The following example returns the list of tapes in the cluster:
# The API:
/api/storage/tape-devices
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/tape-devices" -H "accept: application/hal+json"
# The response:
"records": [
    "node": {
      "uuid": "4083be52-5315-11eb-a839-00a0985ebbe7",
      "name": "st-8020-1-01",
          "href": "/api/cluster/nodes/4083be52-5315-11eb-a839-00a0985ebbe7"
    "device_id": "2d.0",
        "href": "/api/storage/tape-devices/4083be52-5315-11eb-a839-00a0985ebbe7/2d.0"
    "node": {
    "device_id": "2d.0L1",
        "href": "/api/storage/tape-devices/4083be52-5315-11eb-a839-00a0985ebbe7/2d.0L1"
    "node": {
    "device_id": "qeg-tape-brocade2-8g:0.126",
        "href": "/api/storage/tape-devices/4083be52-5315-11eb-a839-00a0985ebbe7/qeg-tape-brocade2-8g%3A0.126"
    "node": {
    "device_id": "stsw-broc6510-01:11.126",
        "href": "/api/storage/tape-devices/4083be52-5315-11eb-a839-00a0985ebbe7/stsw-broc6510-01%3A11.126"
    "node": {
    "device_id": "stsw-broc6510-01:15.126",
        "href": "/api/storage/tape-devices/4083be52-5315-11eb-a839-00a0985ebbe7/stsw-broc6510-01%3A15.126"
    "node": {
    "device_id": "stsw-broc6510-01:15.126L1",
        "href": "/api/storage/tape-devices/4083be52-5315-11eb-a839-00a0985ebbe7/stsw-broc6510-01%3A15.126L1"
    "node": {
    "device_id": "stsw-broc6510-01:22.126",
        "href": "/api/storage/tape-devices/4083be52-5315-11eb-a839-00a0985ebbe7/stsw-broc6510-01%3A22.126"
    "node": {
    "device_id": "stsw-broc6510-01:23.126",
        "href": "/api/storage/tape-devices/4083be52-5315-11eb-a839-00a0985ebbe7/stsw-broc6510-01%3A23.126"
"num_records": 7,
    "href": "/api/storage/tape-devices"
2) Retrieving a specific tape device from the cluster
The following example returns the requested tape device. If there is no tape with the requested UID, an error is returned.
# The API:
/api/storage/tape-devices/{node.uuid}/{device_id}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/tape-devices/5f5275eb-5315-11eb-8ac4-00a0985e0dcf/2d.0" -H "accept: application/hal+json"
# The response:
"node": {
  "uuid": "5f5275eb-5315-11eb-8ac4-00a0985e0dcf",
  "name": "st-8020-1-02",
      "href": "/api/cluster/nodes/5f5275eb-5315-11eb-8ac4-00a0985e0dcf"
"type": "tape",
"description": "IBM LTO-6 ULT3580",
"alias": {
  "name": "st7",
  "mapping": "SN[1068000245]"
"aliases": [
    "name": "st7",
"wwnn": "5001697722ee0010",
"wwpn": "5001697722ee0011",
"serial_number": "1068000245",
"interface": "sas",
"device_state": "offline",
"formats": [
  "LTO-4/5 Native Density",
  "LTO-4/5 Compressed",
  "LTO-6 2.5TB",
  "LTO-6 6.25TB Compressed"
"storage_port": {
  "name": "2d"
"file_number": -1,
"block_number": -1,
"residual_count": 0,
"density": "low",
"device_names": [
    "rewind_device": "rst0l",
    "no_rewind_device": "nrst0l",
    "unload_reload_device": "urst0l"
    "rewind_device": "rst0m",
    "no_rewind_device": "nrst0m",
    "unload_reload_device": "urst0m"
    "rewind_device": "rst0h",
    "no_rewind_device": "nrst0h",
    "unload_reload_device": "urst0h"
    "rewind_device": "rst0a",
    "no_rewind_device": "nrst0a",
    "unload_reload_device": "urst0a"
"reservation_type": "off",
    "href": "/api/storage/tape-devices/5f5275eb-5315-11eb-8ac4-00a0985e0dcf/2d.0"
Updating a tape device
The tape PATCH API allows the tape device to be set online or offline, positioned, and given an alias.
1) Taking a tape device offline
The following example takes a tape device offline:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/tape-devices/5f5275eb-5315-11eb-8ac4-00a0985e0dcf/2d.0" -H "accept: application/hal+json" -H "Content-Type: application/hal_json" -d '{"online": "false"}'
# The response:
"job": {
  "uuid": "9e544626-306e-11ec-8c2e-00a098b81daa",
      "href": "/api/cluster/jobs/9e544626-306e-11ec-8c2e-00a098b81daa"
2) Bringing a tape device online
The following example brings a tape device online:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/tape-devices/5f5275eb-5315-11eb-8ac4-00a0985e0dcf/2d.0" -H "accept: application/hal+json" -H "Content-Type: application/hal_json" -d '{"online": "true"}'
# The response:
"job": {
3) Giving a tape device an alias
The following example assigns an alias to a tape device:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/tape-devices/5f5275eb-5315-11eb-8ac4-00a0985e0dcf/2d.0" -H "accept: application/hal+json" -H "Content-Type: application/hal_json" -d '{"aliases": [{"name": "st0"}]}'
# The response:
4) Removing a tape device's aliases
The following example clears any aliases previously assigned to a tape device:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/tape-devices/5f5275eb-5315-11eb-8ac4-00a0985e0dcf/2d.0" -H "accept: application/hal+json" -H "Content-Type: application/hal_json" -d '{"aliases": []}'
# The response:
5) Rewinding a tape device
The following example rewinds a tape device:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/tape-devices/5f5275eb-5315-11eb-8ac4-00a0985e0dcf/2d.0" -H "accept: application/hal+json" -H "Content-Type: application/hal_json" -d '{"position": {"operation": "rewind"}}'
# The response:
"job": {
6) Forwarding the tape five files
The following example moves the tape forward five file records:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/tape-devices/5f5275eb-5315-11eb-8ac4-00a0985e0dcf/2d.0" -H "accept: application/hal+json" -H "Content-Type: application/hal_json" -d '{"position": {"operation": "fsf", "count": 5}}'
# The response:
"job": {
  "uuid": "954c20d5-306e-11ec-8c2e-00a098b81daa",
      "href": "/api/cluster/jobs/954c20d5-306e-11ec-8c2e-00a098b81daa"
