REST API reference
Update an FC interface
Updates an FC interface to modify its attributes or configuration settings. This is typically done to ensure the interface aligns with your network requirements or changes in the network environment.
HTTP method and endpoint
PATCH /network/fc/interfaces/{uuid}
Introduced in
ONTAP 9.6
  • network interface modify
uuid
string
path
True
The unique identifier for the FC interface.
Request Body
Name Type Description
comment
string
A user configurable comment. Optional in POST; valid in PATCH. To clear a prior comment, set the property to an empty string in PATCH.
enabled
boolean
The administrative state of the FC interface. The FC interface can be disabled to block all FC communication with the SVM through this interface. Optional in POST and PATCH; defaults to true (enabled) in POST.
location
location
The location of the FC interface is defined by the location of its port. An FC port is identified by its UUID, or a combination of its cluster node name and port name. Either the UUID or the cluster node name and port name are required for POST. To move an interface, supply either the port UUID or the cluster node name and port name in a PATCH.
location.node and location.port refer to the current location of the FC interface. This can be different from location.home_node and location.home_port in instances where the FC interface has failed over to its HA partner node. The location.node, location.port, and location.is_home properties are not available for interfaces on the inactive side of a MetroCluster relationship.
name
string
The name of the FC interface. Required in POST; optional in PATCH.
port_address
string
The port address of the FC interface. Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the FC interface when the SVM performs a port login (PLOGI).
This is useful for obtaining statistics and diagnostic information from FC switches.
This is a hexadecimal encoded numeric value.
state
string
The current operational state of the FC interface. The state is set to down if the interface is not enabled.
If the cluster node hosting the port is down or unavailable, no state value is returned.
uuid
string
The unique identifier of the FC interface. Required in the URL.
wwnn
string
The world wide node name (WWNN) of the FC interface SVM. The WWNN is generated by ONTAP when Fibre Channel Protocol or the NVMe service is created for the FC interface SVM.
  • example: 20:00:00:50:56:b4:13:01
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
wwpn
string
The world wide port name (WWPN) of the FC interface. The WWPN is generated by ONTAP when the FC interface is created.
  • example: 20:00:00:50:56:b4:13:a8
  • readOnly: 1
  • x-nullable: true
Example request
  "comment": "string",
  "location": {
    "home_node": {
      "name": "node1",
    "home_port": {
      "name": "0a",
      "node": {
        "name": "node1"
    "node": {
      "name": "node1",
    "port": {
      "name": "0a",
      "node": {
        "name": "node1"
  "name": "fc_lif1",
  "port_address": "5060F",
  "state": "string",
  "uuid": "bce9827d-4d8f-60af-c771-6e8e9af2c6f0",
  "wwnn": "20:00:00:50:56:b4:13:01",
  "wwpn": "20:00:00:50:56:b4:13:a8"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966140
An interface with the same name already exists.
1966217
The specified port is not valid on the node provided.
1966238
The node or port of an active SAN data interface cannot be changed.
1966702
The destination node is not healthy.
5373982
An invalid WWN was specified. The length is incorrect.
5373983
An invalid WWN was specified. The format is incorrect.
5374579
The SAN Kernel Agent on the node is unavailable.
5374870
A partial failure occurred; renaming the interface failed. Correct the error and resubmit the request.
5374871
The Fibre Channel port identified by the specified UUID does not refer to the same port as that identified by the specified node name and/or port name.
5374872
If either location.port.node.name or location.port.name is supplied, both properties must be supplied.
5375057
An FC port with the provided UUID does not exist.
72089674
You cannot move a Fibre Channel interface configured for the NVMe over FC data protocol.
string
home_node
name
string
uuid
string
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
home_port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
node
name
string
uuid
string
port
name
string
node
node
uuid
string
location
home_node
home_node
home_port
home_port
is_home
boolean
Indicates if the FC interface is currently on its home node.
node
node
port
port
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
name
string
uuid
string
fc_interface
A Fibre Channel (FC) interface is the logical endpoint for FC network connections to an SVM. An FC interface provides FC access to storage within the interface SVM using either Fibre Channel Protocol or NVMe over Fibre Channel (NVMe/FC).
An FC interface is created on an FC port which is located on a cluster node. The FC port must be specified to identify the location of the interface for a POST or PATCH operation that relocates an interface. You can identify the port by supplying either the cluster node and port names or the port UUID.
comment
string
enabled
boolean
location
location
name
string
port_address
string
state
string
uuid
string
wwnn
string
  • readOnly: 1
  • x-nullable: true
wwpn
string
  • readOnly: 1
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
