REST API reference
Update the anti-ransomware package on the cluster
Updates the anti-ransomware package on the cluster to ensure the latest security measures are in place against ransomware threats.
HTTP method and endpoint
PATCH /security/anti-ransomware
Introduced in
ONTAP 9.16
Required properties
  • uri - URI of the anti-ransomware package
  • security anti-ransomware update-package-from-uri
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
nodes
array[anti_ransomware_node]
uri
string
URI of the anti-ransomware package through a server
Example request
  "nodes": [
      "name": "node1",
      "version": "1.0"
  "uri": "http://server/package"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
203161684
Autonomous Ransomware Protection (ARP) package file must be either a .tar or .tgz file.
203161685
Autonomous Ransomware Protection (ARP) package file download failed.
203161686
Autonomous Ransomware Protection (ARP) package file unzip failed.
203161687
Autonomous Ransomware Protection (ARP) package file untar failed.
203161688
Autonomous Ransomware Protection (ARP) package archive invalid. No ARP version file found.
203161689
Internal error. Filesystem error while installing Autonomous Ransomware Protection (ARP) package file.
203161690
Autonomous Ransomware Protection (ARP) package update requires an effective cluster version of 9.16.1 or later.
203161691
Autonomous Ransomware Protection (ARP) package file is invalid. The checksum verification of the ARP configuration files failed.
203161692
Autonomous Ransomware Protection (ARP) package update failed because one or more nodes are not healthy.
203161694
Failed to update the Autonomous Ransomware Protection (ARP) package file because the uri property was not specified.
name
string
Name of the node.
version
string
Anti-ransomware version.
anti_ransomware
nodes
uri
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
