REST API reference
Create the LDAP configuration for an SVM
Creates an LDAP configuration for a Storage Virtual Machine (SVM) to manage directory services. Use this configuration to define how the SVM interacts with LDAP servers or an Active Directory domain for authentication and directory lookups.
HTTP method and endpoint
POST /name-services/ldap
Introduced in
ONTAP 9.6
Usage notes
Creates an LDAP configuration for an SVM.
Important notes
  • Each SVM can have one LDAP configuration.
  • The LDAP servers and Active Directory domain are mutually exclusive fields. These fields cannot be empty. At any point in time, either the LDAP servers or Active Directory domain must be populated.
  • LDAP configuration with Active Directory domain cannot be created on an admin SVM.
  • IPv6 must be enabled if IPv6 family addresses are specified.
The following parameters are optional:
  • preferred AD servers
  • schema
  • port
  • ldaps_enabled
  • min_bind_level
  • bind_password
  • base_scope
  • use_start_tls
  • session_security
  • referral_enabled
  • bind_as_cifs_server
  • query_timeout
  • user_dn
  • user_scope
  • group_dn
  • group_scope
  • netgroup_dn
  • netgroup_scope
  • netgroup_byhost_dn
  • netgroup_byhost_scope
  • is_netgroup_byhost_enabled
  • group_membership_filter
  • skip_config_validation
  • try_channel_binding
  • restrict_discovery_to_site
Configuring more than one LDAP server is recommended to avoid a single point of failure. Both FQDNs and IP addresses are supported for the "servers" field. The Active Directory domain or LDAP servers are validated as part of this operation.
LDAP validation fails in the following scenarios:
  1. The server does not have LDAP installed.
  2. The server or Active Directory domain is invalid.
  3. The server or Active Directory domain is unreachable.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
ad_domain
string
This parameter specifies the name of the Active Directory domain used to discover LDAP servers for use by this client. This is mutually exclusive with servers during POST and PATCH.
base_dn
string
Specifies the default base DN for all searches.
base_scope
string
Specifies the default search scope for LDAP queries:
  • base - search the named entry only
  • onelevel - search all entries immediately below the DN
  • subtree - search the named DN entry and the entire subtree below the DN
bind_as_cifs_server
boolean
Specifies whether or not CIFS server's credentials are used to bind to the LDAP server.
bind_dn
string
Specifies the user that binds to the LDAP servers.
bind_password
string
Specifies the bind password for the LDAP servers.
group_dn
string
Specifies the group Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for group lookups.
string
Specifies the custom filter used for group membership lookups from an LDAP server.
group_scope
string
Specifies the default search scope for LDAP for group lookups:
boolean
Specifies whether or not netgroup by host querying is enabled.
is_owner
boolean
Specifies whether or not the SVM owns the LDAP client configuration.
ldaps_enabled
boolean
Specifies whether or not LDAPS is enabled.
min_bind_level
string
The minimum bind authentication level. Possible values are:
  • anonymous - anonymous bind
  • simple - simple bind
  • sasl - Simple Authentication and Security Layer (SASL) bind
netgroup_byhost_dn
string
Specifies the netgroup Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for netgroup by host lookups.
string
Specifies the default search scope for LDAP for netgroup by host lookups:
netgroup_dn
string
Specifies the netgroup Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for netgroup lookups.
netgroup_scope
string
Specifies the default search scope for LDAP for netgroup lookups:
port
integer
The port used to connect to the LDAP Servers.
preferred_ad_servers
array[string]
query_timeout
integer
Specifies the maximum time to wait for a query response from the LDAP server, in seconds.
referral_enabled
boolean
Specifies whether or not LDAP referral is enabled.
boolean
Specifies whether or not LDAP server discovery is restricted to site-scope.
schema
string
The name of the schema template used by the SVM.
  • AD-IDMU - Active Directory Identity Management for UNIX
  • AD-SFU - Active Directory Services for UNIX
  • MS-AD-BIS - Active Directory Identity Management for UNIX
  • RFC-2307 - Schema based on RFC 2307
  • Custom schema
servers
array[string]
session_security
string
Specifies the level of security to be used for LDAP communications:
  • none - no signing or sealing
  • sign - sign LDAP traffic
  • seal - seal and sign LDAP traffic
boolean
Indicates whether or not the validation for the specified LDAP configuration is disabled.
status
status
svm
svm
try_channel_binding
boolean
Specifies whether or not channel binding is attempted in the case of TLS/LDAPS.
use_start_tls
boolean
Specifies whether or not to use Start TLS over LDAP connections.
user_dn
string
Specifies the user Distinguished Name (DN) that is used as the starting point in the LDAP directory tree for user lookups.
user_scope
string
Specifies the default search scope for LDAP for user lookups:
Example request
  "ad_domain": "example.com",
  "base_dn": "dc=domainB,dc=example,dc=com",
  "base_scope": "string",
  "bind_dn": "cn=Administrators,cn=users,dc=domainB,dc=example,dc=com",
  "bind_password": "abc",
  "group_dn": "cn=abc,users,dc=com",
  "group_membership_filter": "",
  "group_scope": "string",
  "min_bind_level": "string",
  "netgroup_byhost_dn": "cn=abc,users,dc=com",
  "netgroup_byhost_scope": "string",
  "netgroup_dn": "cn=abc,users,dc=com",
  "netgroup_scope": "string",
  "port": 389,
  "preferred_ad_servers": [
    "11.11.11.11"
  "schema": "ad_idmu",
  "servers": [
      "10.10.10.10",
      "domainB.example.com"
  "session_security": "string",
  "status": {
    "code": 65537300,
    "dn_message": [
      "string"
    "ipv4": {
      "code": 65537300,
      "dn_messages": [
        "string"
      "message": "string",
      "state": "string"
    "ipv4_state": "string",
    "ipv6": {
      "code": 65537300,
      "dn_messages": [
        "string"
      "state": "string"
    "ipv6_state": "string",
    "state": "string"
  "svm": {
    "name": "svm1",
  "user_dn": "cn=abc,users,dc=com",
  "user_scope": "string"
Status: 201, Created
num_records
integer
Number of LDAP records.
records
array[ldap_service]
  "num_records": 1,
  "records": [
      "port": 389,
        "11.11.11.11"
      "servers": [
          "10.10.10.10",
      "status": {
        "code": 65537300,
        "dn_message": [
          "string"
        "ipv4": {
          "code": 65537300,
          "dn_messages": [
            "string"
          "state": "string"
        "ipv6": {
          "code": 65537300,
          "dn_messages": [
            "string"
          "state": "string"
        "state": "string"
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262186
LDAP Servers cannot be used with Active Directory domain and/or preferred Active Directory servers
2621488
Invalid SVM context
2621706
The specified SVM UUID is incorrect for the specified SVM name
4915203
The specified LDAP schema does not exist
262222
The specified LDAP servers or preferred Active Directory servers contain duplicate server entries
4915229
DNS resolution failed due to an internal error. Contact technical support if this issue persists
4915231
DNS resolution failed for one or more of the specified LDAP servers. Verify that a valid DNS server is configured
23724132
DNS resolution failed for all the specified LDAP servers. Verify that a valid DNS server is configured
4915234
The specified LDAP server or preferred Active Directory server is not supported because it is one of the following: multicast, loopback, 0.0.0.0, or broadcast
4915248
LDAP servers cannot be empty or "-". Specified Active Directory domain is invalid because it is empty or "-" or it contains either the special characters or "-" at the start or end of the domain)
4915251
STARTTLS and LDAPS cannot be used together
4915257
The LDAP configuration is invalid. Verify that bind-dn and bind password are correct
4915258
The LDAP configuration is invalid. Verify that the Active Directory domain or servers are reachable and that the network configuration is correct
4915259
LDAP configurations with Active Directory domains are not supported on admin SVM.
4915265
The specified bind password or bind DN is invalid
4915264
Certificate verification failed. Verify that a valid certificate is installed
13434916
The SVM is in the process of being created. Wait a few minutes, and then try the command again.
23724130
Cannot use an IPv6 name server address because there are no IPv6 LIFs
4915252
LDAP Referral is not supported with STARTTLS, with session security levels sign, seal or with LDAPS.
4915266
LDAP site discovery restriction cannot be applied to a mixed version cluster.
656477
Need default site to be specified to enable site restriction.
4915206
CIFS server is not configured for the vserver. LDAP client configuration requires CIFS server for binding.
4915261
Cannot use port "389" when "ldaps_enabled" is "true".
4915255
Base DN specified in the LDAP client configuration is not available.
4915268
The bind_as_cifs_server field cannot be set to true when the CIFS server is in workgroup mode.
4915269
The bind_as_cifs_server field cannot be set to true when the CIFS server is in realm mode.
string
ipv4
code
integer
Code corresponding to the error message. If there is no error, it is 0 to indicate success.
dn_messages
array[string]
message
string
Provides additional details on the error.
state
string
Status of the LDAP service.
ipv6
code
integer
dn_messages
array[string]
message
string
state
string
status
code
integer
This field is no longer supported. Use ipv4.code or ipv6.code instead.
dn_message
array[string]
ipv4
ipv4
ipv4_state
string
This field is no longer supported. Use ipv4.state instead.
ipv6
ipv6
ipv6_state
string
This field is no longer supported. Use ipv6.state instead.
message
string
This field is no longer supported. Use ipv4.message or ipv6.message instead.
state
string
The status of the LDAP service for the SVM. The LDAP service is up if either ipv4_state or ipv6_state is up. The LDAP service is down if both ipv4_state and ipv6_state are down.
svm
name
string
uuid
string
ldap_service
ad_domain
string
base_dn
string
base_scope
string
bind_as_cifs_server
boolean
bind_dn
string
bind_password
string
group_dn
string
string
group_scope
string
boolean
is_owner
boolean
ldaps_enabled
boolean
min_bind_level
string
netgroup_byhost_dn
string
string
netgroup_dn
string
netgroup_scope
string
port
integer
array[string]
query_timeout
integer
referral_enabled
boolean
boolean
schema
string
  • Custom schema
servers
array[string]
session_security
string
boolean
status
status
svm
svm
try_channel_binding
boolean
use_start_tls
boolean
user_dn
string
user_scope
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
