REST API reference
Add a new SACL or DACL ACE
Adds a new SACL or DACL ACE to define specific access permissions for a user. Use this when you need to customize security settings for files and directories within a volume.
HTTP method and endpoint
POST /protocols/file-security/permissions/{svm.uuid}/{path}/acl
Introduced in
ONTAP 9.9
Usage notes
Adds the new SACL/DACL ACE. You must keep the following points in mind while using these endpoints:
  • SLAG applies to all files and/or directories in a volume hence, inheritance is not required to be propagated.
  • Set access_control field to slag while adding SLAG ACE.
  • Set access_control field to file_directory while adding file-directory ACE. By Default access_control field is set to file_directory.
  • For SLAG, valid apply_to combinations are "this-folder, sub-folders", "files", "this-folder, sub-folders, files".
Required properties
  • user - Name of the user to which the ACE applies.
  • access - Specifies whether the ACE is for DACL or SACL.
  • vserver security file-directory ntfs dacl add
  • vserver security file-directory ntfs sacl add
path
string
path
True
path
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
access
string
Specifies whether the ACL is for DACL or SACL. It is a required field. The available values are:
  • access_allow - DACL for allow access
  • access_deny - DACL for deny access
  • audit_success - SACL for success access
  • audit_failure - SACL for failure access
access_control
string
Access Control Level specifies the access control of the task to be applied. Valid values are "file-directory" or "Storage-Level Access Guard (SLAG)". SLAG is used to apply the specified security descriptors with the task for the volume or qtree. Otherwise, the security descriptors are applied on files and directories at the specified path. The value SLAG is not supported on FlexGroups volumes. The default value is "file-directory" ('-' and '_' are interchangeable).
advanced_rights
advanced_rights
Specifies the advanced access right controlled by the ACE for the account specified. You can specify more than one "advanced-rights" value by using a comma-delimited list.
apply_to
apply_to
Specifies where to apply the DACL or SACL entries. You can specify more than one value by using a comma-delimited list.
ignore_paths
array[string]
Specifies that permissions on this file or directory cannot be replaced.
propagation_mode
string
Specifies how to propagate security settings to child subfolders and files. This setting determines how child files/folders contained within a parent folder inherit access control and audit information from the parent folder. The available values are:
  • propagate - propagate inheritable permissions to all subfolders and files
  • ignore - ignore inheritable permissions
  • replace - replace existing permissions on all subfolders and files with inheritable permissions
rights
string
Specifies the access rights controlled by the ACE for the account specified. The "rights" parameter is mutually exclusive with the "advanced_rights" parameter. If you specify the "rights" parameter, you can specify one of the following "rights" values ("-" or "_" is accepted as the delimiter).
user
string
Specifies the account to which the ACE applies. You can specify either name or SID.
Example request
  "access": "access_allow",
  "access_control": "file_directory",
  "ignore_paths": [
    "/dir1/dir2/",
    "/parent/dir3"
  "propagation_mode": "string",
  "rights": "full_control",
  "user": "S-1-5-21-2233347455-2266964949-1780268902-69304"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
655865
The specified file or directory does not exist.
10485811
Access is a required field.
1260882
Specified SVM not found.
6691623
User is not authorized.
4849676
The specified Windows user or group does not exist.
10485810
User is a required field.
10485813
All values cannot be false.
advanced_rights
append_data
boolean
Append DAta
delete
boolean
Delete
delete_child
boolean
Delete Child
execute_file
boolean
Execute File
full_control
boolean
Full Control
read_attr
boolean
Read Attributes
read_data
boolean
Read Data
read_ea
boolean
Read Extended Attributes
read_perm
boolean
Read Permissions
synchronize
boolean
Synchronize
write_attr
boolean
Write Attributes
write_data
boolean
Write Data
write_ea
boolean
Write Extended Attributes
write_owner
boolean
Write Owner
write_perm
boolean
Write Permission
apply_to
files
boolean
Apply to Files
sub_folders
boolean
Apply to all sub-folders
this_folder
boolean
Apply only to this folder
file_directory_security_acl
Manages the DACLS or SACLS.
access
string
access_control
string
advanced_rights
advanced_rights
apply_to
apply_to
ignore_paths
array[string]
propagation_mode
string
rights
string
user
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
