REST API reference
Create an FPolicy configuration for an SVM
Creates an FPolicy configuration for an SVM to specify the policy scope and events that you want to monitor. This action helps you manage file access within your storage environment by defining specific rules and priorities.
HTTP method and endpoint
POST /protocols/fpolicy/{svm.uuid}/policies
Introduced in
ONTAP 9.6
Usage notes
Creates an FPolicy policy configuration for the specified SVM. To create an FPolicy policy, you must specify the policy scope and the FPolicy events to be monitored.
Important notes:
  • A single policy can monitor multiple events.
  • An FPolicy engine is an optional field whose default value is set to native. A native engine can be used to simply block the file access based on the file extensions specified in the policy scope.
  • To enable a policy, the policy priority must be specified. If the priority is not specified, the policy is created but it is not enabled.
  • The "mandatory" field, if set to true, blocks the file access when the primary or secondary FPolicy servers are down.
Required properties
  • svm.uuid - Existing SVM in which to create the FPolicy policy.
  • events - Name of the events to monitor.
  • name - Name of the FPolicy policy.
  • scope - Scope of the policy. Can be limited to exports, volumes, shares or file extensions.
  • priority- Priority of the policy (ranging from 1 to 10).
Default property values
  • mandatory - true
  • engine - native
  • fpolicy policy scope create
  • fpolicy policy create
  • fpolicy enable
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
engine
fpolicy_engine_reference
FPolicy external engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
name
string
Specifies the name of the policy.
passthrough_read
boolean
Specifies whether passthrough-read should be allowed for FPolicy servers registered for the policy. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. Offline files are files that have been moved to secondary storage.
persistent_store
string
Specifies the persistent storage name. This can then be used to enable persistent mode for FPolicy events.
priority
integer
Specifies the priority that is assigned to this policy.
privileged_user
string
Specifies the privileged user name for accessing files on the cluster using a separate data channel with privileged access. The input for this field should be in "domain\username" format.
scope
scope
svm
svm
Example request
  "allow_privileged_access": true,
  "enabled": true,
  "engine": {
    "name": "string"
  "events": [
    "event_cifs",
    "event_open"
  "name": "fp_policy_1",
  "persistent_store": "ps1",
  "priority": 1,
  "privileged_user": "mydomain\\testuser",
  "scope": {
    "exclude_export_policies": [
      "string"
    "exclude_extension": [
      "string"
    "exclude_shares": [
      "string"
    "exclude_volumes": [
      "vol1",
      "vol_svm1",
    "include_export_policies": [
      "string"
    "include_extension": [
      "string"
    "include_shares": [
      "sh1",
      "share_cifs"
    "include_volumes": [
      "vol1",
      "vol_svm1"
  "svm": {
    "uuid": "string"
Status: 201, Created
num_records
integer
Number of Records
records
array[fpolicy_policy]
  "num_records": 1,
  "records": [
      "enabled": true,
      "engine": {
        "name": "string"
      "events": [
        "event_cifs",
        "event_open"
      "priority": 1,
      "scope": {
          "string"
          "string"
        "exclude_shares": [
          "string"
          "vol1",
          "vol_svm1",
          "string"
          "string"
        "include_shares": [
          "sh1",
          "share_cifs"
          "vol1",
          "vol_svm1"
      "svm": {
        "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
9764875
An FPolicy event does not exist
9764888
An FPolicy engine does not exist
9764898
An FPolicy policy cannot be created without defining its scope
9765027
FPolicy creation is successful but it cannot be enabled as the priority is already in use by another policy
9765037
FPolicy creation failed as passthrough-read cannot be enabled for policy without privileged user
9765038
Passthrough-read policies are not supported with asynchronous external engine
9765056
The specified Persistent Store does not exist
9765059
Persistent Store feature is not supported with native engine
9765060
Persistent Store feature is not supported with synchronous engine
9765061
Persistent Store feature is not supported with mandatory screening
9765065
A valid privileged user name must be in the form "domain-name\user-name"
9765066
The privileged user contains characters that are not allowed
string
name
string
The name of the FPolicy external engine.
FPolicy events
name
string
scope
check_extensions_on_directories
boolean
Specifies whether the file name extension checks also apply to directory objects. If this parameter is set to true, the directory objects are subjected to the same extension checks as regular files. If this parameter is set to false, the directory names are not matched for extensions and notifications are sent for directories even if their name extensions do not match. Default is false.
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
object_monitoring_with_no_extension
boolean
Specifies whether the extension checks also apply to objects with no extension. If this parameter is set to true, all objects with or without extensions are monitored. Default is false.
svm
uuid
string
SVM UUID
fpolicy_policy
engine
events
mandatory
boolean
name
string
passthrough_read
boolean
persistent_store
string
priority
integer
privileged_user
string
scope
scope
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
