REST API reference
Create a Vscan On-Access policy
Creates a Vscan On-Access policy to configure how files are scanned for viruses on access. Use this when you need to establish or update the scanning behavior for files within an SVM.
HTTP method and endpoint
POST /protocols/vscan/{svm.uuid}/on-access-policies
Introduced in
ONTAP 9.6
Usage notes
</b>Important notes:
  • You must enable the policy on an SVM before its files can be scanned.
  • You can enable only one On-Access policy at a time on an SVM. By default, the policy is enabled on creation. * If the Vscan On-Access policy has been created successfully on an SVM but cannot be enabled due to an error, the Vscan On-Access policy configurations are saved. The Vscan On-Access policy is then enabled using the PATCH operation.
Required properties
  • svm.uuid - Existing SVM in which to create the Vscan On-Access policy.
  • name - Name of the Vscan On-Access policy. Maximum length is 256 characters.
Default property values
If not specified in POST, the following default property values are assigned:
  • enabled - true
  • mandatory - true
  • include_extensions - *
  • max_file_size - 2147483648
  • only_execute_access - false
  • scan_readonly_volumes - false
  • scan_without_extension - true
  • vserver vscan on-access-policy create
  • vserver vscan on-access-policy enable
  • vserver vscan on-access-policy disable
  • vserver vscan on-access-policy file-ext-to-include add
  • vserver vscan on-access-policy file-ext-to-exclude add
  • vserver vscan on-access-policy paths-to-exclude add
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
enabled
boolean
Status of the On-Access Vscan policy
mandatory
boolean
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.
name
string
On-Access policy name
scope
scope
svm
svm
Example request
  "name": "on-access-test",
  "scope": {
    "exclude_extensions": [
      "mp*",
      "txt"
    "exclude_paths": [
      "\\dir1\\dir2\\name",
      "\\vol\\a b",
      "\\vol\\a,b\\"
    "include_extensions": [
      "mp*",
      "txt"
    "max_file_size": 2147483648
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[vscan_on_access]
  "num_records": 1,
  "records": [
      "scope": {
          "mp*",
          "txt"
        "exclude_paths": [
          "\\vol\\a b",
          "\\vol\\a,b\\"
          "mp*",
          "txt"
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
10027043
The new On-Access policy cannot be created as the SVM has reached the maximum number of On-Access policies allowed. Delete an existing policy in order to create a new policy
10027101
The file size must be in the range 1KB to 1TB
10027107
The include extensions list cannot be empty. Specify at least one extension for inclusion
10027109
The specified CIFS path is invalid. It must be in the form "\dir1\dir2" or "\dir1\dir2\"
10027249
The On-Access policy created successfully but failed to enable the policy. The reason for enable policy operation failure might be that another policy is enabled. Disable the enabled policy and then enable the newly created policy using the PATCH operation
10027253
The number of paths specified exceeds the configured number of maximum paths. You cannot specify more than the maximum number of configured paths
10027254
The number of extensions specified exceeds the configured maximum number of extensions. You cannot specify more than the maximum number of configured extensions
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
only_execute_access
boolean
Scan only files opened with execute-access.
boolean
Specifies whether or not read-only volume can be scanned.
boolean
Specifies whether or not files without any extension can be scanned.
string
svm
name
string
uuid
string
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled
boolean
mandatory
boolean
name
string
scope
scope
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
