REST API reference
Create the OAuth 2.0 configuration
Configures OAuth 2.0 settings to enable secure authorization for accessing resources. Set up the necessary parameters to integrate with your chosen identity provider.
HTTP method and endpoint
POST /security/authentication/cluster/oauth2/clients
Introduced in
ONTAP 9.14
Usage notes
Creates the OAuth 2.0 configuration.
Required properties
  • name
  • application
  • issuer
Optional properties
  • audience
  • client_id
  • client_secret
  • introspection.endpoint_uri
  • introspection.interval
  • remote_user_claim
  • jwks.provider_uri
  • jwks.refresh_interval
  • outgoing_proxy
  • use_local_roles_if_present
  • skip_uri_validation
  • use_mutual_tls
  • provider
  • security oauth2 client create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
application
string
The name of the application using OAuth 2.0. Required for POST operations.
audience
string
The OAuth 2.0 Audience.
client_id
string
The OAuth 2.0 client ID. Required in POST operations for remote introspection.
client_secret
string
The OAuth 2.0 client secret. Required in POST operations for remote introspection.
hashed_client_secret
string
The OAuth 2.0 client secret as a SHA256 HMAC hashed value created with the cluster UUID as its HMAC secret key.
introspection
introspection
issuer
string
The OAuth 2.0 Issuer.
jwks
jwks
name
string
The configuration name. Required for POST operations.
outgoing_proxy
string
Outgoing proxy to access external identity providers (IdPs). If not specified, no proxy is configured.
provider
string
The Identity Provider type.
remote_user_claim
string
The remote user claim.
skip_uri_validation
boolean
Indicates whether or not to validate the input URIs. Default value is false.
boolean
Indicates whether or not to use locally configured roles, if present. Default value is false.
use_mutual_tls
string
OAuth 2.0 mutual TLS authentication setting. Set this value to "none" to disable mutual TLS authentication. Set this value to "required" to enforce mutual TLS authentication for all access tokens and reject any token that does not have x5t#S256 property in the cnf section. The default value is "request" which means mutual TLS authentication is enforced only if the x5t#S256 property is present in the cnf section of the access token.
Example request
  "application": "string",
  "audience": "string",
  "client_id": "string",
  "client_secret": "string",
  "hashed_client_secret": "string",
  "introspection": {
    "endpoint_uri": "https://examplelab.customer.com/token/introspect",
    "interval": "PT1H"
  "issuer": "https://examplelab.customer.com",
  "jwks": {
    "provider_uri": "https://examplelab.customer.com/pf/JWKS",
    "refresh_interval": "PT2H"
  "name": "auth0",
  "outgoing_proxy": "https://johndoe:secretpass@proxy.example.com:8080",
  "provider": "entra",
  "remote_user_claim": "string",
  "use_mutual_tls": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
203817010
Client ID is required for remote introspection.
203817011
Client secret is required for remote introspection.
203817012
Client ID and client secret required for remote introspection.
203817013
JWKS URI should not be configured for remote introspection.
203817014
JWKS refresh interval should not be specified for remote introspection.
203817015
The token introspection endpoint is required for remote introspection.
203817016
JWKS refresh interval provided without providing JWKS URI.
203817017
Minimum supported value of JWKS refresh interval is 300 seconds.
203817018
Required parameters for either local validation or remote introspection are missing. Provide either the JWKS URI for local validation, or metadata configuration URI or token introspection endpoint with client ID and secret for remote introspection.
203817019
Failed to add new IDP client because number of maximum supported IDP clients is already reached.
203817020
Internal error. Failed to validate provider URI.
203817021
OAuth 2.0 Provider URI validation failed with error.
203817022
OAuth 2.0 Provider JWKS URI validation failed. Received empty response message from the JWKS URI.
203817023
OAuth 2.0 Provider JWKS URI validation failed. No keys were found in response message received from the JWKS URI.
203817024
Internal error. Unable to allocate memory for CURL response.
203817025
Maximum value of JWKS refresh interval is 2147483647 seconds.
203817033
OAuth 2.0 Provider Introspection endpoint validation failed. Received empty response message from the Introspection endpoint.
203817034
OAuth 2.0 Provider Introspection endpoint validation failed. Received invalid response message for Introspection request.
203817037
An entry cannot be created as another entry with the same configuration name has the same issuer and audience.
203817042
Maximum value of introspection interval is 2147483647 seconds.
string
introspection
endpoint_uri
string
The token introspection endpoint URI.
interval
string
The refresh interval for caching tokens, in ISO-8601 format. This can be set to the value "disabled" to disable caching of tokens. When set to 0, tokens are cached according to the expiry period in them. Otherwise, it can be set to a value from 1 second to 2147483647 seconds.
jwks
provider_uri
string
The URI on which the JSON Web Key Set (JWKS) are hosted.
refresh_interval
string
The refresh interval for the JSON Web Key Set (JWKS), in ISO-8601 format. This can be set to a value from 300 seconds to 2147483647 seconds.
security_oauth2
application
string
audience
string
client_id
string
client_secret
string
string
introspection
introspection
issuer
string
jwks
jwks
name
string
outgoing_proxy
string
provider
string
remote_user_claim
string
skip_uri_validation
boolean
boolean
use_mutual_tls
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
